Old Nov 29, 2011, 12:09 PM
Steph280 is offline
Find More Posts by Steph280
1.21 Gigawatts!
Steph280's Avatar
Irvine, CA, USA
Joined Oct 2000
I didn't know this plane even existed. Now I must get one...dang just missed the free shipping codes yesterday!
Steph280 is offline Find More Posts by Steph280
Old Nov 29, 2011, 12:41 PM
X30PILOT is offline
Find More Posts by X30PILOT
X30PILOT's Avatar
Joined Aug 2007
I just took delivery of the A-10 yesterday and I am very impressed with the kit.
X30
X30PILOT is offline Find More Posts by X30PILOT
Old Dec 04, 2011, 08:19 PM
ysolomon is offline
Find More Posts by ysolomon
Another one on the way...
ysolomon's Avatar
Plano, Texas
Joined Feb 2009
OK, three of us are building this A-10, all three use exactly the same setup, so we better be right...
Plane: http://www.nitroplanes.com/projet-004-a10-kit.html (but you already know that...)
Fan: CS 70mm 10 Blades: http://www.x-flight.com.hk/index.php...20Expiried!&s=
Motor: Cyclone 2500kV Outrunner, 4mm shaft: http://rc-castle.com/shop/product_in...oducts_id=1697
ESC: Turnigy dlux 100A: http://www.hobbyking.com/hobbyking/s...dProduct=16367
UBEC: Turnigy 7.5A: http://www.hobbyking.com/hobbyking/s...idProduct=6320
Rudder Servo: http://www.hobbyking.com/hobbyking/s...idProduct=7026
Aileron Servos: Hitec HS-82MG
Flaps servos: Hitec HS-225BB
Elevator servo: Hitec HS-225BB
Landing Gear: RC Lander: http://parkrcmodels.com/product_info...oducts_id=1084
Steering servo: Cyclone: http://rc-castle.com/shop/product_in...roducts_id=322
Some parts arrived, we are still waiting for others. I will try to take photos and update this thread.
ysolomon is offline Find More Posts by ysolomon
Old Dec 05, 2011, 02:49 PM
Steph280 is offline
1.21 Gigawatts!
Steph280's Avatar
Irvine, CA, USA
Joined Oct 2000
I picked one up as well. Have the CS 10 blade fans coming, with a couple cheap outrunner Turnigy motors to test with. I suspect I will be running 6S with a motor of ~2000kv.
I was surprised to see they ship the wing in one piece, which creates an extraordinary long box. But it looks good so far.
Old Dec 05, 2011, 05:18 PM
torque roll is offline
Find More Posts by torque roll
A Texan abroad
torque roll's Avatar
Joined Oct 2011
Those ten blades sound sweet together........
Flip Flop knowz what the people want!
torque roll is offline Find More Posts by torque roll
Old Dec 17, 2011, 02:32 PM
A Texan abroad
Joined Oct 2011
Hey guys, would any of these work?
http://www.hobbyking.com/hobbyking/s...70mm_EDF_.html
http://www.hobbyking.com/hobbyking/s...ner_900w_.html
Old Dec 17, 2011, 05:16 PM
erh7771 is offline
Find More Posts by erh7771
Joined Nov 2005
Originally Posted by torque roll View Post
3300 would work for around 4lbs of thrust on 4s 90 amps
2100 would work for 40 amps on 4s around 40oz of thrust and on 5s around 3.5pds of thrust between 50 and 55 amps
erh7771 is offline Find More Posts by erh7771
Old Dec 17, 2011, 07:26 PM
A Texan abroad
Joined Oct 2011
4s??? I was going to do a 2650 or 3000 3 cell setup for each fan. Is there room for a 2650mah 4cell? Will the 3300 even fit? The motor shaft looks too small.
Old Dec 17, 2011, 09:46 PM
ysolomon is offline
ysolomon's Avatar
Plano, Texas
Joined Feb 2009
We are going to use 6S 5000mAh to feed both fans in parallel.
Old Dec 17, 2011, 10:22 PM
A Texan abroad
Joined Oct 2011
So, a set of two 3s 2650's (5300mah total) should do fine.
This is truly a stretch, but did anybody run one 4-cell 2650 for each motor? Just doesn't seem like there'd be enough room in there. And even If you could fit them, it would proabably be too nose heavy.
Also, I think I would rather use the 2100 motor. No adapter needed.
Old Dec 18, 2011, 02:33 AM
raido56 is offline
Find More Posts by raido56
Flying!!! Got to love it
raido56's Avatar
United States, PA, Philadelphia
Joined Jun 2006
[QUOTE=erh7771;20165067]3300 would work for around 4lbs of thrust on 4s 90 amps
It would be a bit higher than 90 amps for sure.
Here are my readings on the 10 blade C/S fan with a 3200 kV motor with a 4s 2650 40C pack at WOT.
Keep em flying
raido56/ Herb
raido56 is offline Find More Posts by raido56
Old Dec 18, 2011, 04:37 AM
ysolomon is offline
ysolomon's Avatar
Plano, Texas
Joined Feb 2009
If you are talking about 3S 2650mAh for each motor, than I'm actually talking about twice as much. If you look at it in terms of Watts-hour (Wh), then you are talking about 2x 3Sx 2650 = 2 x 11.1 x 2.65 = 58.83Wh, while I'm talking about 1x 6S x 5000mAh = 22.2V x 5 = 111Wh. Double.
Also, I was facing the same decision on another twin engine (although prop on the other one): do I feed both motors with one battery or have a separate battery for each? There are three options here (there are more, but I will illustrate with 3...). Let's say we agree that each motor should have approximately 55Wh feeding it (which, at about 1000W maximum throttle should give you 3:20 flight time (60 x 55 / 1000).
(1) You can decide to have a single 6S 5000mAh battery feed both motors in parallel. Each motor at full throttle will take about 1000W / 22.2V = 45A.
(2) You can have two 6S 2500mAh batteries, each feeding one motor, still taking 45A from the battery.
(3) You can have two 3S 5000mAh batteries, each feeding one motor. However, this time each motor will take 1000W / 11.1V = 90A.
There is a forth option: a single 3S battery, but now you will need 10000mAh, and the two motors together will take 180A, which is really a lot...
My preference is to feed the motors with 6S and lower amp rather than 3S (or even 4S) and higher amp, for several reasons. One--I prefer to drive higher voltage than higher current. Higher current will required thicker wires (10AWG? 8AWG?) while lower current will allow me to use lighter, thinner wires (12AWG? 14AWG?). Since you have to run long wires from the ESC to the motors here--this is a consideration. Second--I really don't like high current running through all the electronics.. Maybe a personal preference, but that's my preference...
So, I would rather feed the motors with 6S 2500mAh each, versus 3S 5000mAh each. Now it leaves the 1x 6S 5000mAh versus 2x 6S 2500mAh. To get 2x 1000W (or 111A) from a 5000mAh battery, I need it to have 22C (111A / 5Ah) discharge current. So, even a 25C battery should be enough. I'm planning on putting a 35C or 40C battery (quite common) and be happy...
Finally--in order to get some 40K rpm from the motor/battery combination, if you choose a 6S / 22.2V battery, you will need 40K/22.2V = 1,800Kv motor (plus due to load, so let's say 2,100kV--the motor you already chose...) However, if you want to get 40K rpm with a 3S battery, you will need a 40K / 11.1V = 3,600Kv motor (with load, maybe a 4,200Kv motor). It seems that your motor is better in getting 40K rpm (1000W on this fan?) from a 22.2V battery than from a 3S battery.
Just my two cents...
Old Dec 18, 2011, 10:13 AM
X30PILOT is offline
X30PILOT's Avatar
Joined Aug 2007
Iíll be running 2 Cyclone 2500 kv motors on my A-10 on one 6s battery.
I have used this setup with great success in my Starmax twin 70mm F-14, with the stock fans. These fans are cheap Sapac clones. I will be installing HET fans in the A-10. If I am going to glue in the fan shroud, I want to put in a decent fan. Hereís a short video of the F-14 with a 6s 4000 mah battery. At 6 pounds 5 ounces, itís got plenty of power at this weight.
X30
F-14 flight 3 (3 min 3 sec)
Old Dec 18, 2011, 12:28 PM
ysolomon is offline
ysolomon's Avatar
Plano, Texas
Joined Feb 2009
I was about to call you and tell you "hey, somebody else out there is using our exact setup!" before I realized it was actually you...
Old Dec 18, 2011, 06:54 PM
ysolomon is offline
ysolomon's Avatar
Plano, Texas
Joined Feb 2009
The flaps are installed in place. Done exactly per the instructions, with one deviation: replaced the hinges with the robart 308 steel pin hinge points. Installing it is a bit tricky, and I didn't know what to expect from those two 1.5mm flexibly metal wire, but I'm very happy with the results.
Alert RC Nitro Tech (UK Only) - 10% OFF!!! artuan00 Hot Online Deals 2 Oct 24, 2011 06:41 AM
Question 10% vs. 15% nitro fuels? DanF Beginner Training Area (Fuel) 30 Oct 19, 2011 05:08 PM
Question Good Plane for a 7 or 9 0r 10 nitro engine Rob1962 1/2A Planes 7 Oct 08, 2011 04:25 PM
For Sale Trade 1/10 nitro buggy for micro plane dinopilot Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 1 May 06, 2011 03:38 PM
Help! Nitro-plane A-10 kit ? cyclops2 Foamies (Kits) 3 Nov 08, 2008 07:49 AM
