Old Feb 16, 2012, 08:10 PM
wolfewinde is offline
Find More Posts by wolfewinde
My Co-Pilots Rock!!
wolfewinde's Avatar
United States, FL, Clearwater
Joined May 2011
Heya Carlos,
According to Heads up...
GWS EP1060: 37 ounces of thrust at 19 amps. Good choice for maximum performance.
The motor is rated for a max of 22 amps for 30 seconds.
I'm guessing that 9 x7.5 E probably pulls a touch more amps than the 1060, but not much, so should be OK if i stay out of WOT except for short bursts. The ESC came down cool on the test flight tonight. I will keep a close watch on it in flights to come and try to get this set up on a watt meter soon.
Thanks for taking the time to try to help, I appreciate that.
Wolfe
wolfewinde is offline Find More Posts by wolfewinde
Old Feb 16, 2012, 08:18 PM
Hit N Run is offline
Find More Posts by Hit N Run
Fly it low.. and fly it fast!
Hit N Run's Avatar
United States, MA, Westport
Joined Nov 2011
Originally Posted by wolfewinde View Post
Well I don't know about 2 vs 3 blades - haven't used 3 blades much.
BUT - I did sneak in one flight one the P-40 just before dusk and she did fly much better on the 9 x 7.5 prop. She is faster, but the speed does seem to agree with her.
Wolfe
Well, i'm glad it's flying better. That's good news!
Hit N Run is offline Find More Posts by Hit N Run
Old Feb 16, 2012, 08:19 PM
My Co-Pilots Rock!!
wolfewinde's Avatar
Joined May 2011
Thanks, Hit n Run
Wolfe
Old Feb 16, 2012, 08:21 PM
Hit N Run's Avatar
Joined Nov 2011
Originally Posted by Roger Lombard View Post
Woah! - Let'd be clear I'm not comparing EPS with EPO, I'm comparing the generation I warbirds - Spit, Me109, Corsair, P51 and Zero which were all around 34-36" wingspan with the generation II - P40, FW 190 which are up around 40" wingspan and quite a bit more substantial in their structure. There is a weight penalty with EPO but not that big! Iv'e got gen II birds in both EPS and EPO and I would probably use the same motor in both.
Yeah, mine are all in that 34"-36" range and EPS, I have had them all for over 4 years now.
I had two P-51's but a telephone pole jumped in front of me one day and she pretty much blew up!
Old Feb 16, 2012, 08:22 PM
Hit N Run's Avatar
Joined Nov 2011
Thanks, Hit n Run
Wolfe
I guess these warbirds just want to fly fast.
Old Feb 16, 2012, 08:23 PM
twn Chen is offline
Find More Posts by twn Chen
Taiwan, 北市
Joined Dec 2010
Wolf,
A well balanced prop will generate more thrust and draws less Amps. I'd suggest getting all of your props balanced.
Chen
twn Chen is offline Find More Posts by twn Chen
Old Feb 16, 2012, 09:12 PM
Mooneypilot60h is offline
Find More Posts by Mooneypilot60h
Zupp Dave
Joined Feb 2012
New member - First Post
Greetings - I'm a neophyte flyer. My girlfriend bought me a Brookstone helicopter for christmas, you know the indoor infrared type. I now have 5 planes and three helicopters. I recently completed my first build. Wolfe on this thread gave me a GWS F-4U Corsair. Wolfe was with me tonight on her maiden flight. What a thrill! I have about 15-20 hours in building it and I didn't crash on her maiden flight. Thanks Wolfe! SInce I don't have any experience other then the GWS Corsair, I suppose you'll have to take this with a grain of salt. I found this model simple to build. I evidently got it put together pretty straight because it flew very true and smooth. Of course I had a good instructor too! I'll definitely build more GWS planes.
Check out my pics
Mooneypilot60h is offline Find More Posts by Mooneypilot60h
Old Feb 16, 2012, 09:21 PM
My Co-Pilots Rock!!
wolfewinde's Avatar
Joined May 2011
Hey Dave
Good to see you on the thread and thanks for posting the pics.
For general info purposes, Dave has only been flying airplanes for about three weeks, and yet was able to maiden his first warbird build with no problems and pull off a nearly perfect landing to boot.. He is also a real life pilot, so he understands the aerodynamics of flight better than most. If he keeps learning at his present rate, I will be taking lessons from him before long LOL.
Chen - I seem to have lost one of the rubber grommets for my balancer - I do usually balance props - guess I need to order a new balancer if I don't find the missing piece pretty soon
Wolfe
Old Feb 16, 2012, 09:28 PM
Hit N Run's Avatar
Joined Nov 2011
Check out my pics
Welcome to the addiction!
It's great when you have someone with experience to guide you. My father got me into this hobby many years ago and I hope to pass the fun along to my son as well.
Your Corsair looks GREAT! Nice job on the build, and congrats on a successful maiden flight! (those are the scariest because you don't know what to expect)
Old Feb 16, 2012, 09:32 PM
Zupp Dave
Joined Feb 2012
I can see after my first build that patience is key. I'm glad I did a bunch of test before attempting a first flight. I probably went through a full battery (cumulatively) testing linkages, taxiing etc. I sure learned a lot from this build. The next one probably will not take as long to build. Luckily I avoided a catastrophe with some patience.
Old Feb 16, 2012, 09:39 PM
Zupp Dave
Joined Feb 2012
Thanks "Hit"
You got that right about an addiction! I'm completely hooked! What a kick in the pants! Got my alarm clock set, can't wait for tomorrow morning to come!! Is that bad?.....
Old Feb 16, 2012, 09:45 PM
My Co-Pilots Rock!!
wolfewinde's Avatar
Joined May 2011
I still remember my first GWS Corsair flight about 12 years ago. It was my first attempt at a warbird. I took off from a driveway, went about 40 feet and climbed up to about 15 ft and she rolled over and slammed back into the concrete. Lots of pieces, very dejected pilot. I had spent hours on that airplane.
Wolfe
Old Feb 16, 2012, 09:49 PM
twn Chen is offline
Taiwan, 北市
Joined Dec 2010
Hi Mooneypilot60h,
Welcome to enter this great hobby. You have good freind, Wolfe, to fly with at your field. You'll not be free from this sound addiction from now on.
Chen
Old Feb 16, 2012, 10:04 PM
metalguy is online now
Find More Posts by metalguy
always something to learn...
metalguy's Avatar
Tacoma, WA
Joined Jan 2011
Welcome, Mooney! These are very fun planes, and MUCH cheaper than the real deal....-------Metalguy
metalguy is online now Find More Posts by metalguy
Old Feb 16, 2012, 10:34 PM
Zupp Dave
Joined Feb 2012
Thanks for the welcomes!
Thanks guys,
I plan on practicing take offs and landings, precision traffic pattern work for the most part for the near future. I'll be working in some aileron rolls, chandelles and loops too at a safe altitude. I recently joined Largo Flying Club which has a runway. I figure learning to grease landings is a worthwhile endeavor to minimizing hot glue burns on my fingers. I may even put flaps on my p-47 to facilitate slower landing speeds. Then retracts - oh geez here goes the addiction thing again!
More later..............I'll keep you posted
Dave
Yippee! All the modern good things corporations have brought us. cyclops2 Life, The Universe, and Politics 77 Nov 17, 2011 10:00 AM
Help! all the parts needed for a new GWS slow stick NP kit ? cyclops2 Foamies (Kits) 1 Sep 08, 2011 02:33 PM
Discussion Of all the stupid things done by NHS ... this has got to take the cake! logan5 Life, The Universe, and Politics 13 Jun 16, 2011 12:17 PM
Sold Four GWS Naro Max BB Servos $28 for all four. tryharder Aircraft - General - Radio Equipment (FS/W) 2 Mar 23, 2011 01:23 PM
