Well here is the motor I am using
http://www.headsuprc.com/servlet/the...0-Sport/Detail It is supposed to be capable of 250 watts. I have tried an APC 10x5 E prop and an off brand 9 x 6 three blade so far. Neither prop has been wonderful. Wolfe |
Well I scrounged around and came up with an APC 9 x 7.5E prop. I will give that a try and see what happens. Not sure when the weather will cooperate again - maybe late this afternoon, but it looks on the edge
Pitts - I might consider a trade - what do you have that you would be willing to part with? Mine is not busted up at all, just a crack in the cowl. Will try to put up a pic later. Wolfe |
- Let'd be clear I'm not comparing EPS with EPO, I'm comparing the generation I warbirds - Spit, Me109, Corsair, P51 and Zero which were all around 34-36" wingspan with the generation II - P40, FW 190 which are up around 40" wingspan and quite a bit more substantial in their structure. There is a weight penalty with EPO but not that big! Iv'e got gen II birds in both EPS and EPO and I would probably use the same motor in both.And by the way I hate 3 bladers. Might look good but they don't work as efficiently as two bladers in the sizes we use - something to do with Mr Reynolds I'm told |
For a crash (no pun intended) course on props see here http://www.airfieldmodels.com/inform...propellers.htm
and his story is "In our realm, the most efficient propellers are two bladed. Because the diameter of our propellers is so small, multiple blade propellers disturb the air that the trailing blade is entering. Therefore, 3 and 4 blade propellers are less efficient." |
United States, NJ, Frenchtown
Joined Mar 2003
I disagree !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
The molecules of air are the same size in any scale. There for. The small prop blades we use ....slide in between the molecules easier & with less friction !!!!!!!!!!!!!!! We are more efficient when using 3 or more blades.
I have looked and looked and really can not get any "Technical" Motor Specifications or Motor constants to allow for On-Line estimator work given a Propeller size/Pitch, Battery selection and ESC. I looked at: http://www.headsuprc.com/servlet/the...0-Sport/Detail I looked at: http://www.flybrushless.com/search and nothing. I would use the APC 9 X 7.5 Slow Flyer and measure your AMP (current) draw and see if this comes anywhere close to the maximum Rated for this Powerup 450 in as far as AMPs and Watts. The reason I am recommending the SLOW FLYER "is" because this model needs Thrust and Airspeed as it is pretty heavy 28oz. I have used APC SLOW FLYER with very good results on various models and it does the model very good. Carlos
Latest blog entry: E-Flite Retract Y-Connector Cable...
| Thread Tools | |
| Yippee! All the modern good things corporations have brought us. | cyclops2 | Life, The Universe, and Politics | 77 | Nov 17, 2011 09:00 AM |
| Help! all the parts needed for a new GWS slow stick NP kit ? | cyclops2 | Foamies (Kits) | 1 | Sep 08, 2011 01:33 PM |
| Discussion Of all the stupid things done by NHS ... this has got to take the cake! | logan5 | Life, The Universe, and Politics | 13 | Jun 16, 2011 11:17 AM |
| Sold Four GWS Naro Max BB Servos $28 for all four. | tryharder | Aircraft - General - Radio Equipment (FS/W) | 2 | Mar 23, 2011 12:23 PM |
