Old Jan 29, 2012, 08:08 AM
twn Chen is offline
Find More Posts by twn Chen
Taiwan, 北市
Joined Dec 2010
Hi Rich,
Oh that's a lot to be done, it's very hard for ordinary people. You are great !
Keep up your good work and take your time !
Chen
twn Chen is offline Find More Posts by twn Chen
Old Jan 29, 2012, 08:59 AM
bartricky is offline
Find More Posts by bartricky
Shelter Kitty "Orange Death"
bartricky's Avatar
United States, FL, Monroe
Well I dusted off my old EPS Zero yesterday.
It's been awhile since I've flown it but it was as sweet as ever, just great fun to throw around.
I must have nailed the mods the first time as it has a bad rep stock. I have 200w and it handles it fine.
A sweetheart.
Early pic before black cowl...
bartricky is offline Find More Posts by bartricky
Old Jan 29, 2012, 09:33 AM
wolfewinde is offline
Find More Posts by wolfewinde
My Co-Pilots Rock!!
wolfewinde's Avatar
United States, FL, Clearwater
Joined May 2011
Grats on getting the Zero going again, Bar. Sounds like its a good thing you are retired, Rich - you have a lot to do.
Pretty windy here last couple of days so not much flying - not looking good in the near future either.
Wolfe
wolfewinde is offline Find More Posts by wolfewinde
Old Jan 29, 2012, 02:19 PM
CNILE is offline
Find More Posts by CNILE
Joined Dec 2011
Gws a-10
After 20 years, I am getting (back) into this.
My GWS A-10 arrived yesterday. After looking it over, and trying to understand the assembly manual, I think I am going to use it as a pattern for a pusher flat foamy(for now).
I have the EDF55-300H/G8.
I have read that these were underpowered. That's fine, as my reaction time has gone out of the window.I plan on using this as an advanced trainer,anyway.
Has anyone done a build tutorial video on this, all I can find are flight/crash stuff.
CNILE is offline Find More Posts by CNILE
Old Jan 29, 2012, 02:54 PM
cyclops2 is offline
Find More Posts by cyclops2
United States, NJ, Frenchtown
Joined Mar 2003
Thanks Woflewinde.
I can now EASILY put the stacked 4 ESCs in the upper compartment with the R & E servos / rec. / battery . under the wing compartment
Question about the 3 cell.. ma. hr sizes. I hve GWS 3 bladed contr rotating sets of 5" x 3"
And a set of 4" x 4" same direction.
The 5" x 3" pull 3.8 amp at WOT......44 mph & 8.5 oz of thrust each.
The 4" x 4" pull 2.5 amp at WOT......61 mph & 4.8 oz of thrust each.
I hope The computer is close enough on these little guys. Soo What size battery should I use ? I do sport flying. No 3D or vertical stuff. currents would be 12 amps WOT or 10 amps WOT. I assume I can fly at 1/2 those speeds & amps. ??
Can I do around a 25C - 50C 1000 mahr 3 cell Turnigy Nano ?
The plane weighs 17 oz RTF .....with no battery in it.
Rich
cyclops2 is offline Find More Posts by cyclops2
Old Jan 29, 2012, 03:03 PM
cyclops2 is offline
Joined Mar 2003
Wahoo
Hello CNILE.
I did a A-10 Pusher long ago. Skip the fans. A rear prop will have you pulling along side the F-15.
I also did that as a pusher with a 5980 KV helicopter motor. Verticle takeoffs.
I was able to comfortably fly the A-10 pusher on the old Black & decker LIFEPO4 1100 mahr cells A123 brand.
Old Jan 29, 2012, 03:48 PM
PittSpecial is online now
Find More Posts by PittSpecial
Right Rudder
PittSpecial's Avatar
USA, FL, Orlando
Joined Nov 2010
Ed's GWS Tiger Moth TM400 with Mega 16/15/7 Power!
After all these years (2004 vintage) Ed's GWS Tiger Moth (TM400) still flys just fantastic!
Eds GWS Tiger Moth TM400 01-29-2012 (3 min 58 sec)
PittSpecial is online now Find More Posts by PittSpecial
Old Jan 29, 2012, 03:55 PM
Right Rudder
USA, FL, Orlando
Joined Nov 2010
Two Slow Stick with Brushless Power!
Here is Henry kneeling and making some adjustments to his new GWS SLOW STICK using the Himax HA2025 in the Cobri Gearbox! It flew fantastic and Henry Loved it!
I brought my own GWS SLOW STICK and it is powered with the direct drive BP Hobbies A2217-9 Outrunner and swing the APC Slow Flyer 10 X 7 and using nothing more than 3-Cell, 1350mAH (Thunder Power) Pro-Lites, 25C, Li-POLYs and it zooms with zest appeal.
Old Jan 29, 2012, 04:10 PM
Right Rudder
USA, FL, Orlando
Joined Nov 2010
Video GWS SLOW STICK(s)!
GWS Slow Stick and PZ micro P-51D 01-29-2012 (2 min 53 sec)
Old Jan 29, 2012, 04:57 PM
My Co-Pilots Rock!!
wolfewinde's Avatar
Joined May 2011
Cyclops - that harness is impressive - nice work. Seems like a 20C would be enough, but I always get the 30c batteries now. That plane should carry a little weight, so maybe a 1300 3s or 1800 3s - I don't have much experience with 1000 3s - might be enough, but I wonder how long your flight times would be
Pitt - nice videos
Cnile - never flew a Warthog so I can't help with that one - sorry
Old Jan 29, 2012, 07:04 PM
twn Chen is offline
Taiwan, 北市
Joined Dec 2010
Hi Pitt Carlos,
Nice videos & pictures ! Thank you.
Hi Rich,
I'd second Wolfe's idea.
A 3S 25-50C 1000mAh lipo might be as heavy as a 3S 1300 or even 1500 20C one. I think the 20 -25C 1300 one will bring you more flight minutes, sport flying ones.
Chen
Old Jan 29, 2012, 07:28 PM
bartricky's Avatar
Most of my SS batts are 3s 1300 30-35C.
I found the biggest improvement in flight time came from using a regular prop and not a slowfly.
With the bigger motors there is no need for a slowfly prop unless you are lifting a lot of extra weight.
I use a 1300kv and a 9050 prop for 200W. This is the same setup I use on most of my parkies.
Old Jan 29, 2012, 08:12 PM
cyclops2 is offline
Joined Mar 2003
I went with HD props when possible, due to the high rpms.
Rich
Old Jan 31, 2012, 01:35 PM
Lilbanks96 is offline
Find More Posts by Lilbanks96
Lilbanks96's Avatar
United States, IA, Greenfield
Joined Apr 2010
I decided to mod the spitfire to a bigger motor. I took my Scorpion 480 from the Slow Stick and threw it in the Spitfire.
Man! This thing is fast! Lots and Lots of Power!!
Lots and Lots of Fun!!
Happy Flying!
Lilbanks96 is offline Find More Posts by Lilbanks96
Old Jan 31, 2012, 01:41 PM
My Co-Pilots Rock!!
wolfewinde's Avatar
Joined May 2011
That would be fast with a 480. Glad it is working for you
Wolfe
Yippee! All the modern good things corporations have brought us. cyclops2 Life, The Universe, and Politics 77 Nov 17, 2011 09:00 AM
Help! all the parts needed for a new GWS slow stick NP kit ? cyclops2 Foamies (Kits) 1 Sep 08, 2011 01:33 PM
Discussion Of all the stupid things done by NHS ... this has got to take the cake! logan5 Life, The Universe, and Politics 13 Jun 16, 2011 11:17 AM
Sold Four GWS Naro Max BB Servos $28 for all four. tryharder Aircraft - General - Radio Equipment (FS/W) 2 Mar 23, 2011 12:23 PM
