Old Jan 28, 2012, 11:51 AM
wolfewinde is offline
Find More Posts by wolfewinde
My Co-Pilots Rock!!
wolfewinde's Avatar
United States, FL, Clearwater
Joined May 2011
Good luck on the maiden, Metal. Let us know how it goes.
Windy here today. Got in just one flight on my Formosa this morning and decided it was too windy.
I would like to re-maiden my Nitro P-40 now that the retracts are glued in LOL. Got a very short flight on her a couple days ago, but she was really nose heavy, so I brought her down to adjust the CG and retracts fell out the minute she touched down.
She should handle 10 MPH, still debating ...
Wolfe
wolfewinde is offline Find More Posts by wolfewinde
Old Jan 28, 2012, 12:02 PM
cyclops2 is offline
Find More Posts by cyclops2
United States, NJ, Frenchtown
Joined Mar 2003
Brushless set up for the 4 engined C-130
2.3 oz. of Y & 10 amp esc. Good thing this will keep the thrust to weight at 1 : 1
I am a RTF of 22 to 24 oz. & thrust of a worst case of 25 to 27 oz.
My wife said due to the cost of finishing this CHEAP sloper, I may have to go back to work.
Rich
cyclops2 is offline Find More Posts by cyclops2
Old Jan 28, 2012, 12:23 PM
My Co-Pilots Rock!!
wolfewinde's Avatar
Joined May 2011
Well she should fly with a 1:1 thrust ratio. When is the maiden?
Wolfe
Old Jan 28, 2012, 12:31 PM
cyclops2 is offline
Joined Mar 2003
Hi Wolfe.
At least 4 days off. The added picture is the complete 4 ESCs. My first 4 engined Brushless.
The other 4 engine was with 4..400s brushes. & 1 50 amp ESC......Neat & simple.
Old Jan 28, 2012, 01:02 PM
My Co-Pilots Rock!!
wolfewinde's Avatar
Joined May 2011
I have never set up a multi-engine plane with brushless motors - looks like LOTS of wires LOL. Do you use a triple "Y" to get them all down to one battery?
Metal - my 3D experience is extremely limited so far - maybe a dozen flight all together. Haven't wrecked any planes so far but I keep them up pretty high. On low rates, with only about 35% throws, they aren't any harder to fly than any low wing fighter. On high rates, even with massive expo, they are pretty quick - hard to keep up with for me.
Wolfe
Old Jan 28, 2012, 01:59 PM
metalguy is offline
Find More Posts by metalguy
always something to learn...
metalguy's Avatar
Tacoma, WA
Joined Jan 2011
Wolfe, I am sure the 3D stuff is fun, and eventually I may get one, but I have to get my confidence up on the faster models first. I maidened the AT-6 today, and I am very impressed. It flies pretty fast, but it sure handles well. It flies like it is on rails, and it looks like I nailed the CG first try. The factory marks it behind the main spar, and I moved it forward of the main spar, considering the tail-heavy comments on the thread for it. I was a little apprehensive, being the plane was only $69.00 complete, minus RX, and battery, and aside from a few quirks I fixed before I flew it, it appears to be a good value, and will be a LOT of fun.
A brushless setup on multiple motors (at least on my C-47 twin) is not too bad. two brushless ESC's, and a y connector, with one wire cut from it works fine. I think I cut the brown wire, and that was it. -----Metalguy
metalguy is offline Find More Posts by metalguy
Old Jan 28, 2012, 02:00 PM
cyclops2 is offline
Joined Mar 2003
All the red leads of the ESCs are soldered in the + hole of the connector. The real BUNDLE is the long leads of the 3 receiver Ys.
I am on the fence on cutting off all excess Y lengths & resolder & heat shrink the splices. Right now it is almost 3' long. You convinced me to reduce all Y leads to 3" long. Except the receiver plug.
Thanks Woflewinde.
Old Jan 28, 2012, 02:11 PM
cyclops2 is offline
Joined Mar 2003
Metalguy
I found the C-47 a pleasure to do brushless also. It glides forever.
Rich
Old Jan 28, 2012, 02:23 PM
elau is offline
Find More Posts by elau
United States, FL
Joined Dec 2002
I just ordered a Formosa I NPS EPO. This will be my third Formosa I. This is my fleet favorite. Is there a thread on building this EPO plane? I want to see if there are any new building tipos / mods especially for placement of my 3s 2200mah lipo.
elau is offline Find More Posts by elau
Old Jan 28, 2012, 02:27 PM
My Co-Pilots Rock!!
wolfewinde's Avatar
Joined May 2011
I would just sand out the battery compartment before you put the fuse together so you can slide the battery pretty far forward. I use a 1300 in mine - old foam though - and it sits in the cockpit area without sliding forward at all.
Wolfe
Old Jan 28, 2012, 02:50 PM
Roger Lombard is offline
Find More Posts by Roger Lombard
Confused? Who, me?
Roger Lombard's Avatar
United Kingdom, England, North York
Joined Jan 2005
There's nothing special about the EPO version except it's tougher, heavier and (in my experience) has a more snakeskin finish than the old EPS. The moulds are the same, just stoked with EPO feedstock instead of EPS.
Getting the battery compartment the right size before you glue the halves is always good with all the older designs - they were designed to run with AA nicad's and an AA is 14mm - 0.55" in diameter. Pretty much all 3 cell lipos, and some 2 cells are thicker than that.
You might find some help here http://www.rcgroups.com/forums/showt...hlight=formosa
and that thread has links to take you all sorts of other Formosa threads.
I'd add that before you put the cowl on I'd either glass it on the inside or line it with fibreglass cross weave tape. Unless you're a genius at keeping the chin off the ground on landing, especially if you're flying without l/g, that cowl can take a beating.
Also trial fit your motor, cowl and prop before you glue the motor stick in place. Depending on your set up you may need to shorten the stick or sometimes not push it the whole way home. A stick that's too long is easy, a stick that's too short is a real pain in the . Ask me how I know these things
Roger Lombard is offline Find More Posts by Roger Lombard
Old Jan 28, 2012, 10:14 PM
elau is offline
United States, FL
Joined Dec 2002
Also trial fit your motor, cowl and prop before you glue the motor stick in place. Depending on your set up you may need to shorten the stick or sometimes not push it the whole way home. A stick that's too long is easy, a stick that's too short is a real pain in the . Ask me how I know these things [/QUOTE]
Roger. Thanks for the input. The link is very helpful!!!
Old Jan 29, 2012, 07:27 AM
cyclops2 is offline
Joined Mar 2003
Done
Much better 4 engined ESC group of wires. Only 1 ESC is supplying BEC voltage to the receiver. A final wrapping of the heat shrink area with good Black plastic electrical tape.
Then the soldering & heat shrinking of the12 motor leads. I am getting there.
Then a power run at WOT to get the maximum current & thrust readings.
Rich
Old Jan 29, 2012, 07:33 AM
twn Chen is offline
Find More Posts by twn Chen
Taiwan, 北市
Joined Dec 2010
Rich,
Let me know what the currents and thrust readings are. Thank you.
It seems your Cargotrans will be with more than enough thrust.
Chen
twn Chen is offline Find More Posts by twn Chen
Old Jan 29, 2012, 07:45 AM
cyclops2 is offline
Joined Mar 2003
Hi Chen.
I am retired. 74. So my work loads vary greatly. Today is a nice winter day in New Jersey. So I will continue cutting down & cutting up 20 + trees that wet ground & high winds have blown over. Wired in a 18 kilowatt generator past week. Retirement really means.
MORE TIRED.
Rich
Yippee! All the modern good things corporations have brought us. cyclops2 Life, The Universe, and Politics 77 Nov 17, 2011 09:00 AM
Help! all the parts needed for a new GWS slow stick NP kit ? cyclops2 Foamies (Kits) 1 Sep 08, 2011 01:33 PM
Discussion Of all the stupid things done by NHS ... this has got to take the cake! logan5 Life, The Universe, and Politics 13 Jun 16, 2011 11:17 AM
Sold Four GWS Naro Max BB Servos $28 for all four. tryharder Aircraft - General - Radio Equipment (FS/W) 2 Mar 23, 2011 12:23 PM
