Old Jan 21, 2012, 04:02 PM
wolfewinde is offline
Find More Posts by wolfewinde
My Co-Pilots Rock!!
wolfewinde's Avatar
United States, FL, Clearwater
Joined May 2011
Welcome
Wolfe
wolfewinde is offline Find More Posts by wolfewinde
Old Jan 21, 2012, 04:08 PM
cyclops2 is offline
Find More Posts by cyclops2
United States, NJ, Frenchtown
Joined Mar 2003
Which Island ?
cyclops2 is offline Find More Posts by cyclops2
Old Jan 22, 2012, 12:20 AM
metalguy is offline
Find More Posts by metalguy
always something to learn...
metalguy's Avatar
Tacoma, WA
Joined Jan 2011
Welcome, Aeronca.-----Metalguy
metalguy is offline Find More Posts by metalguy
Old Jan 23, 2012, 08:37 AM
cyclops2 is offline
Joined Mar 2003
Details Details
Had a bunch of GWS wheels from several planes. So I put on wheels. They just happen to look very scale like. The AC-130 does have the nose wheel much farther back. Fill & slot for a farther back. The rear wheels will need slight grinding away of the ends of the wheel wells. Good DIY plane.
I am working with a slope kit. It is using up a lot of spare parts from other kits. Should still be under 20 oz RTF.
What the heck. Do the steering nose wheel in the new location. Have the plastic & metal parts.
Worst case the plane will still be a 20 oz with about 20 oz of thrust. First plane with about 1 to 1 on thrust and steering. Does the plane steer well or do the 4 fixed main wheels cause turning problems ?
Rich
Old Jan 23, 2012, 08:51 AM
cyclops2 is offline
Joined Mar 2003
Airleron servo
Used 2 Sullivan .032" Golden flex push rods for equal action & hopefully lighter set up.
Time to put in those pre wired Hyperion 12 mm & gearboxes.
Did drill out the bottom of the foam engine housings to get motor air flow thru.
Rich
Old Jan 23, 2012, 09:06 AM
cyclops2 is offline
Joined Mar 2003
Rudder & elevator time.
2 more Sullivan .032" Goldies arrived.
I will try & do my usual, put all servo, rods, wiring, ESCs, battery and anything else, attached to 1 of the sides of the plane. It allows easier COG findings & a full electrical checkout of everything before closing up.
Normally I just put a couple of RTV Silicone dots around the body seam for COG testing with power. I have had a couple of bad GWS COG solo flights. LOVE 2 foot deep grass.
I hand toss at 2' above the grass with no props.
What was the best COGs on a no power glide ?
Rich
Old Jan 23, 2012, 09:25 AM
davylah is offline
Find More Posts by davylah
Ex RAF Techie
davylah's Avatar
North East England
Joined Jun 2010
Rich
I think you'll be just fine with the steerable nose wheel. Mine steers and retracts! Also, it steers on the ground just fine, the 4 wheel bogey doesn't seem to give any problems
davylah is offline Find More Posts by davylah
Old Jan 23, 2012, 09:35 AM
davylah is offline
Ex RAF Techie
davylah's Avatar
North East England
Joined Jun 2010
Rich
I have never found a GWS plane that flew right with the CofG where GWS said it should be. Every single one flew tail heavy if built in accordance with the instructions, so I've taken to moving it forwards as a matter of course. Remember, a nose heavy plane flies badly, a tail heavy plane flies once!!!
The CofG on both my Cargotranses is at 50mm from leading edge, right in the middle of the spar/wiring groove. They fly very predictably like this, and my C-130K (shorty) even takes a small plastic soldier with parachute in the back, to drop out of the opening ramp.
Old Jan 23, 2012, 09:47 AM
My Co-Pilots Rock!!
wolfewinde's Avatar
Joined May 2011
What is the wingspan on that plane, Davey?
Wolfe
Old Jan 23, 2012, 10:13 AM
tarheal63 is offline
Find More Posts by tarheal63
tarheal63's Avatar
United States, TN, Murfreesboro
Joined Mar 2010
I am starting a build on a 109, I want to glass it from the start, but I am having a tough time finding .75 in a quantity large enough to do the bird. Anyone out there got any suggestions?
tarheal63 is offline Find More Posts by tarheal63
Old Jan 23, 2012, 10:15 AM
My Co-Pilots Rock!!
wolfewinde's Avatar
Joined May 2011
I would not glass it - you are just going to add weight and the lighter they are the better they fly. If anything, just glass the ailerons to stiffen them up a bit
Wolfe
Old Jan 23, 2012, 10:28 AM
davylah is offline
Ex RAF Techie
davylah's Avatar
North East England
Joined Jun 2010
Wolfe
The wingspan on the Cargotrans is 1120mm
Old Jan 23, 2012, 10:34 AM
davylah is offline
Ex RAF Techie
davylah's Avatar
North East England
Joined Jun 2010
Wolfe
I agree, I've never glassed a GWS plane, and wouldn't in the future. You will have to add loads of ballast up front to get the CofG in limits, and it will never fly slowly.
My Co-Pilots Rock!!
wolfewinde's Avatar
Joined May 2011
Pretty good sized airplane, then
Wolfe
Old Jan 23, 2012, 10:38 AM
davylah is offline
Ex RAF Techie
davylah's Avatar
North East England
Joined Jun 2010
Wolfe
Yeah, I love them to bits. My stretched one looks even bigger too. It was more difficult than I imagined to make the fuselage plugs line up perfectly. I didn't want to end up with a big banana shaped Hercules!
Yippee! All the modern good things corporations have brought us. cyclops2 Life, The Universe, and Politics 77 Nov 17, 2011 09:00 AM
Help! all the parts needed for a new GWS slow stick NP kit ? cyclops2 Foamies (Kits) 1 Sep 08, 2011 01:33 PM
Discussion Of all the stupid things done by NHS ... this has got to take the cake! logan5 Life, The Universe, and Politics 13 Jun 16, 2011 11:17 AM
Sold Four GWS Naro Max BB Servos $28 for all four. tryharder Aircraft - General - Radio Equipment (FS/W) 2 Mar 23, 2011 12:23 PM
