Heya Kimber,
The thing about airplanes is that each one is designed for a certain "style of flight" and the trick is to "tap into that style and maximize it". I am not a big fan of ignoring the "essence of an airplane" and making it into to something it was not meant to be. Sooooooooo..... That little Pico Slow Stick was meant to be a lazy, low powered, light weight little floater. I think you will compromise that by going with a 2200 mah 2s. You are going to add a lot of unnecessary weight which will not help the airplane fly well and will contribute to a lot more damage if you crash it. I know it is pain to keep buying new batteries all the time, but I really think you would get much better performance out of a small 2 cell - about 800 mah give or take a little, but no more than a 1000 mah I really don't mean to be a jerk about this - just meaning to offer some advice that you are totally welcome to ignore LOL I really hope it fly's well for you, regardless of what batteries you end up using Wolfe |
I would try to make those work - at least to start out. Perhaps you can move them forward - even if you don't use the stock battery holder. A little velcro and a rubber band goes a long way sometimes
If that is not possible, a little weight on the front is probably better, and less weight overall, than the 2200 Wolfe |
As for the aileron servos, I used a 2-servo setup in the wings. Initially I attempted to use the stock control rods with a single servo, but the shape of the gullwing proved to toss practicality right out the window with the aileron linkage. So I ended up carving out servo pockets at the end of the factory channel for the leads in the bottom of wing. I forget, what size motor does yours balance with? What size 3S? I'm gonna use 3S 1300s with this one. |
Will need to move the wing back a bit, redo the push rods, but it will be right. Not sure about their spec;s, they show a AUW of 200g with a 150g battery recommended.????? |
| Thread Tools | |
| Yippee! All the modern good things corporations have brought us. | cyclops2 | Life, The Universe, and Politics | 77 | Nov 17, 2011 09:00 AM |
| Help! all the parts needed for a new GWS slow stick NP kit ? | cyclops2 | Foamies (Kits) | 1 | Sep 08, 2011 01:33 PM |
| Discussion Of all the stupid things done by NHS ... this has got to take the cake! | logan5 | Life, The Universe, and Politics | 13 | Jun 16, 2011 11:17 AM |
| Sold Four GWS Naro Max BB Servos $28 for all four. | tryharder | Aircraft - General - Radio Equipment (FS/W) | 2 | Mar 23, 2011 12:23 PM |
