Old Jan 09, 2013, 02:14 PM
Kimber is offline
Find More Posts by Kimber
Hobby King Hater
Kimber's Avatar
USA
Joined Mar 2005
The way our weather has been, Brad said he may just tie a string
on it, rip an old sheet up, make a tail and take it out and fly is as
a kite..
Kimber is offline Find More Posts by Kimber
Old Jan 09, 2013, 04:29 PM
phoam is online now
Find More Posts by phoam
fly 'em if ya got 'em!
phoam's Avatar
Aguanga, Ca
Joined Mar 2010
Originally Posted by twn Chen View Post
Be reminded that the newer thicker foam is not as tough as the older thinner one.
Chen,
I wonder how this could be, since the thicker wing is made of the same foam as the thinner one? I'm also curious as to the type of foam an SS wing is made of? It is never advertised or discussed.
My thinner wings sure seem like they would snap under less tension than the thicker wings, but I've been wrong before.
Rick
phoam is online now Find More Posts by phoam
Old Jan 09, 2013, 04:33 PM
PittSpecial is online now
Find More Posts by PittSpecial
Right Rudder
PittSpecial's Avatar
USA, FL, Orlando
Joined Nov 2010
a kite..
Here is my Slow Stick Blog:
http://www.rcgroups.com/forums/showthread.php?t=1566388
Teaser Picture...............
PittSpecial is online now Find More Posts by PittSpecial
Old Jan 09, 2013, 06:32 PM
twn Chen is offline
Find More Posts by twn Chen
Taiwan, 北市
Joined Dec 2010
Oh you put a big motor on your SS, a 480 class, Carlos. It seems you'd like to launch your SS as a rocket. A cool idea !
twn Chen is offline Find More Posts by twn Chen
Old Jan 09, 2013, 07:10 PM
twn Chen is offline
Taiwan, 北市
Joined Dec 2010
Originally Posted by phoam View Post
Chen,
Rick
The foam used on the older thinner wing was the same as ordinary depron sheets, while the foam of the thicker wing was different and softer, that's why GWS had to add its thickness for keeping the same strength as the thinner one. But I found that the thicker one is still easier to get snapped than the thinner one under the same tension, something like soft grade balsa sheet vs medium hard balsa sheet, same thick ones. Oh well, balsa is way better than those foams in my idea.
And look at the latest GWS Beaver's wing, and the wings of Pico Cub, Pico Stick, Pico TM, they were all covered by a very thin coat, why ? Same reason for the strength needed. The wings of the oldest versions of all these birds did not come with the thin coat on their tops, and they looked even whiter, why ? Same reason applied. I think that they could not find out the same foam material in China as what they originally applied in Taiwan, as a result adding thickness or the top coat became a must on all these birds. The good thing is they look thicker and tougher, the downside is they are slightly heavier and not as tough as what they look like. Fortunately, brushless motors plus lipo give more power on these birds, but I'd like to add reinforcements to their tail feathers if I have to build them up.
Old Jan 09, 2013, 07:13 PM
Right Rudder
USA, FL, Orlando
Joined Nov 2010
Yes, I have to manage throttle otherwise the trailing edges start to flutter.
And, YES, I did install the Upgrade Carbon Fiber Tubes for both the Leading Edge and Trailing Edges.
Old Jan 09, 2013, 07:52 PM
Kimber is offline
Hobby King Hater
Kimber's Avatar
USA
Joined Mar 2005
Well, ours is ugly too! Not a lot you can do about it??
Charging a battery now to do a watt check and see what prop
were might need, someone recommended a 9X4.7SF, but
everyone is out of them.
Edit:
128w, 10.7A at full throttle, 2s 1800mah battery, 9X4.5thin
571g, 20.1oz, 1.258lbs. That's dead on 100w per pound.
And we have had the wing on twice and broke all but one of
the rubber bands that came with it. One broke while Brad had
it on the CoG stand and it hit him in the mouth......
Old Jan 09, 2013, 07:56 PM
Right Rudder
USA, FL, Orlando
Joined Nov 2010
Kimber,
http://www.ebay.com/itm/APC-Landing-...item231dfe81f8
Old Jan 09, 2013, 07:58 PM
twn Chen is offline
Taiwan, 北市
Joined Dec 2010
Carlos,
I noticed that you put tubes, tube kind, to the wing mount for extending the four hooks on it, it's a very good idea. It's a pain for applying rubbers on them. I'll tell my old flying buddy your great idea. Thank you.
Old Jan 09, 2013, 08:02 PM
Right Rudder
USA, FL, Orlando
Joined Nov 2010
Carlos,
I used 5-minute epoxy to adhere on the short Plastic Nibbles (GWS Plastic Wing Mount Assembly). I don't think CA will work too well due to the stresses of the Rubber Bands and during mounting.
After cutting the Hollow Aluminum Tubes, make sure you sand the cut end so, you do not cut yourself!!!
Old Jan 09, 2013, 08:07 PM
Kimber is offline
Hobby King Hater
Kimber's Avatar
USA
Joined Mar 2005
Originally Posted by PittSpecial View Post
We don't do Ebay, Will wait for HURC to get some in.
No hurry, the weather is terrible...
Opps, forgot,,
Thank you
Old Jan 09, 2013, 08:09 PM
twn Chen is offline
Taiwan, 北市
Joined Dec 2010
Carlos,
I thought that plastic tube might work on it, the idea of Hollow Aluminum Tubes is way much better. Thank you again for such a thoughtful advice.
Old Jan 09, 2013, 08:16 PM
twn Chen is offline
Taiwan, 北市
Joined Dec 2010
Kimber,
Be reminded to locate the CoG correctly as I'm afraid yours might be a little tail heavy unless you'd like to move the wing backward. Check the location of motor and its size on Carlos' SS, these might affect the CG location quite a bit.
Old Jan 09, 2013, 08:21 PM
Right Rudder
USA, FL, Orlando
Joined Nov 2010
Opps, forgot,,
Thank you
THANK YOU, FOR THE THANK YOU!
Kimber is offline
Hobby King Hater
Kimber's Avatar
USA
Joined Mar 2005
Kimber,
It balanced at 4". We had to move the wing up 1/2 from
recommended setting. The battery is 140g.
Yippee! All the modern good things corporations have brought us. cyclops2 Life, The Universe, and Politics 77 Nov 17, 2011 09:00 AM
Help! all the parts needed for a new GWS slow stick NP kit ? cyclops2 Foamies (Kits) 1 Sep 08, 2011 01:33 PM
Discussion Of all the stupid things done by NHS ... this has got to take the cake! logan5 Life, The Universe, and Politics 13 Jun 16, 2011 11:17 AM
Sold Four GWS Naro Max BB Servos $28 for all four. tryharder Aircraft - General - Radio Equipment (FS/W) 2 Mar 23, 2011 12:23 PM
