Old Oct 07, 2012, 09:25 PM
cyclops2 is offline
Find More Posts by cyclops2
United States, NJ, Frenchtown
Joined Mar 2003
Look in the ...Power Systems section... I posted a question.
When is it too much current.??
Phil ( Dr KIWI ) said go for it.
I think this bird needs to fly at night. Flat black should work over enemy terrortory.
Rich
Oh. I have a really beat up old P-51 with the parts in it. so the weight is accurate & the thrust. Hopefully prop speed will be close to calculated.
cyclops2 is offline Find More Posts by cyclops2
Old Oct 07, 2012, 09:29 PM
Hit N Run is offline
Find More Posts by Hit N Run
Fly it low.. and fly it fast!
Hit N Run's Avatar
United States, MA, Westport
Joined Nov 2011
If Dr Kiwi says go for it, then I totally agree! The man definitely knows his stuff!
Hit N Run is offline Find More Posts by Hit N Run
Old Oct 07, 2012, 09:32 PM
cyclops2 is offline
Joined Mar 2003
The real problem will be getting the COG right with so little battery & motor weights.
I may have to grind away some tail weight. I can get carried away on removing weight.
Rich
Old Oct 07, 2012, 09:44 PM
Hit N Run's Avatar
Joined Nov 2011
Rich
Agreed! Removing weight from the tail end is a MUST. The question is, how to do it.
You can shave away at the foam from the inside of the fuse to get ride of some weight. You'd be surprised.... a little goes a long way in altering the CG when you take weight from as far back in the fuse as you possibly can.
Also, digging out the battery compartment so you can slide that lipo as far forward as possible will help you out.
It is definitely going to be a heck of a challenge. I have faith in you though!
If you put your mind to it, anything is possible!
Old Oct 07, 2012, 10:09 PM
phoam is offline
Find More Posts by phoam
fly 'em if ya got 'em!
phoam's Avatar
Aguanga, Ca
Joined Mar 2010
Rich
Hey Rich, maybe I should have pointed out that the naked NPS one there at Tower is made of EPO foam, so although it's a tough bird it's probably not the best pick if you're striving to keep this one lean, as it will be heavier than your previous one.
I wanted to keep mine light as well and so I chose the first one that I linked to because it's EPS. The ad doesn't specify what type of foam the naked one is, however, I bought a naked NPS Corsair and a naked NPS Spit and they both turned up as EPO, but I knew that going into it and I plan to overpower them.
phoam is offline Find More Posts by phoam
Old Oct 08, 2012, 07:47 AM
cyclops2 is offline
Joined Mar 2003
Is the newer tougher plane actually a stronger material?
Old Oct 08, 2012, 08:21 AM
arnav is online now
Find More Posts by arnav
I live my life 12oz at a time
arnav's Avatar
United States, FL, Miami
Joined Nov 2011
EPO is tougher yes, but at the expense of some weight (which is why some people still prefer EPS). Myself I prefer EPO:
- Easier to glue as it is CA safe.
- Easier to fix (boiling water method works better).
- Easier to paint as it accepts wider paint selection.
- Less brittle and doesn't shutter to a million pieces when it meets the ground..
arnav is online now Find More Posts by arnav
Old Oct 08, 2012, 12:54 PM
cyclops2 is offline
Joined Mar 2003
Thanks amav.
I presume I still need to get any molding release off the plastic to have paint stick ? What is used ? Any brands or types of paints work better ?
Old Oct 08, 2012, 01:06 PM
cyclops2 is offline
Joined Mar 2003
The plane has a 1 to 2 ratio of balance. Nose is 7". The tail is 14". Both measured from the wing COG point. So a I think I can do .3 to .4 oz off the tail. .2 oz. from the cockpit. .6 from the battery area. .
I am running a 3 cell 400 mah Cheetah pack..
Old Oct 08, 2012, 02:30 PM
arnav is online now
arnav's Avatar
Joined Nov 2011
"molding release off the plastic to have paint stick?" No no, you don't have to do anything. The paint will stick without a problem. Some people sand any marking from the molding. I never do. On EPO I have used:
- Cheapy no brand name spray paint from HD.
- HD's Rust-Oleum spray paint.
- Krylon Shortcut spray paint
- Many others are known to work as well.
Always be sure to test the paint first on an extra piece of foam to make sure it doesn't melt it. You may want to apply wbpu as well for a better visual affect and to further strengthen the Plane.
Old Oct 08, 2012, 03:08 PM
cyclops2 is offline
Joined Mar 2003
I avoid wbpu like death.
I wind up with a beautiful gloss & 2 to 3 extra ounces. I never sand.
Old Oct 08, 2012, 03:09 PM
arnav is online now
arnav's Avatar
Joined Nov 2011
why? I did it on the last Mosa and really liked the results?
Old Oct 08, 2012, 03:49 PM
cyclops2 is offline
Joined Mar 2003
I just noticed with clean glasses You are arnav..Thought it was amav. At 75 I miss things.
You are right about a nice finish. I completly sanded & filled every imperfection on the C47 & 4 engine Cargotrans. My planes are mostly Olive Drab. Bought a gallon from H D. I thin that Latex a lot.
You convinced me
Rich
Old Oct 08, 2012, 03:59 PM
arnav is online now
arnav's Avatar
Joined Nov 2011
When you don't clean your glasses, you don't realize you CA'd your fingers.
When you CA your fingers, you can't disconnect your LI-PO from the charger.
When you don't disconnect the LI-PO from the charger, fires start.
Don't start fires!
If it makes you feel better, I don't wear glasses, and looking at it it really does look like amav (even with my $500 monitor)...
Old Oct 08, 2012, 04:35 PM
cyclops2 is offline
Joined Mar 2003
Yippee! All the modern good things corporations have brought us. cyclops2 Life, The Universe, and Politics 77 Nov 17, 2011 09:00 AM
Help! all the parts needed for a new GWS slow stick NP kit ? cyclops2 Foamies (Kits) 1 Sep 08, 2011 01:33 PM
Discussion Of all the stupid things done by NHS ... this has got to take the cake! logan5 Life, The Universe, and Politics 13 Jun 16, 2011 11:17 AM
Sold Four GWS Naro Max BB Servos $28 for all four. tryharder Aircraft - General - Radio Equipment (FS/W) 2 Mar 23, 2011 12:23 PM
