scotland
Joined Jul 2003
he works in the tower... fat farmer FOM you'll probably know him can't say much more on here , persec and all that..... Ive got a cargo trans as well, now flying it on a 3s 800mah lipo. might get round to painting it one day fun to fly and realistic from a distance if you squint your eyes
Joined Oct 2012
Help, Brand new at this. I have two slow sticks. There is a problem with the vertical stabilizers breaking. Any idea why? I glued them to the fuselage. The glue held; the fabric and /or foam broke above where the stabilizer was attached.
Thanks for your thoughts. |
Pete, I think the vert stab is vulnerable to breakage if the SS noses over and ends up upside down, or perhaps even in a stiff crosswind, just 'cause it's really thin foam that isn't well supported. I've always glued on carbon fiber stuts at a 45 degree angle beginning at the center of the vert stab down to the horizontal stab for a solution.
Joined Oct 2012
How about reinforcing the stabilizer itself with a credit card or cardboard(not my ideas, got them off the internet)
How did you attach the struts. I have a little bit of fiber glass rod but its very thin (used it on the wings) Not clear how you would go about attaching. |
Taiwan, 北市
Joined Dec 2010
Hi Pete,
Probably Phoam meant that you glue the fiber-glass or carbon rod to the tail feathers, with its one end to the vertical stab and the other end to the horizontal stab, and do the same on the other side of the vertical & horizontal stab. These will make two triangles if you look at the tail from the rear end of your Slow Stick to its nose after gluing the two rods. I think your way works, too. I did glue a piece of bamboo skewer to the side of vertical stab, make the skewer penetrate the horizontal stab, for my buddy couple months ago, it worked so far. Phoam's way works best, and makes your SS look more classical. |
Taiwan, 北市
Joined Dec 2010
United States, PA, Pittsburgh
Joined Oct 2011
Joined Jan 2009
EPO Formosa-II arrived tonight, lightning delivery from headsuprc.
I was a bit annoyed to find that my memory from the first two was exactly correct. GWS just completely dropped the ball with the landing gear attachment on this plane, even to the point of completely ignoring the issue in their manual. Sigh. I knew that. I was just hoping I'd mis-remembered. The other change from the first two is that GWS has decided to ditch the box. The plane's bits are simply stuffed into a large plastic bag. I guess it saves shipping costs, but alas a number of parts were dinged from rubbing against one another. Just venting a bit here. I'll come up with something or other for the LG, and the dings are no big deal... on par with the sort of hangar rash you'd expect after a few outings. |
I just built my second Mosa II and the first EPO one only a few weeks back. It is weird becuase I got mine from headsuprc as well and it came with a box... What is the serial number on it?
On the first Mosa II build i simply used parkzone t-28 mains at wolfe's recommendation. They fit right in there (and I have secured it with drilled ply as well). So If you are lazy, you can go down that route. I liked it but it wasn't providing as much prop clearance for my weed field. On this Mosa build I used the provided plastic pieces, made a rectangular hole in ply and secured them this way. I then drilled them and used fairly thick piano wire with 2-3/4 dubro wheels. I love it! It took maybe an hour to do. There are pics a few pages back. Of course they are those that advocate dropping the wheels altogether. If you are going to paint it anyway, you can use the opportunity to spackle the holes. I also really like how it came out with 2 applications of wpbu (before and after the paint) at Vince's recommendation. Definitely makes the Plane hangar rash proof, more rigid in the air, and a bit crash proof as well (tested first hand last week). Added weight is negligible compared to the added strength. I am definitely going to do it on future foam planes. Good luck! Let us know how it goes... I am hoping to fix mine tomorrow as a test bed for the new Futaba radio,,, |
Your fiberglass rods will work just the same. 2mm is about the right size. In this link I explain how I built the main wing, but from the photo you can see my tailplane struts. Also note the vertical flat carbon rod at the back of the vert stab making it virtually impossible to fold the vert stab. It compliments the struts and helps to stiffen the rudder too: http://www.rcgroups.com/forums/showp...ostcount=14369 |
| Thread Tools | |
| Yippee! All the modern good things corporations have brought us. | cyclops2 | Life, The Universe, and Politics | 77 | Nov 17, 2011 09:00 AM |
| Help! all the parts needed for a new GWS slow stick NP kit ? | cyclops2 | Foamies (Kits) | 1 | Sep 08, 2011 01:33 PM |
| Discussion Of all the stupid things done by NHS ... this has got to take the cake! | logan5 | Life, The Universe, and Politics | 13 | Jun 16, 2011 11:17 AM |
| Sold Four GWS Naro Max BB Servos $28 for all four. | tryharder | Aircraft - General - Radio Equipment (FS/W) | 2 | Mar 23, 2011 12:23 PM |
