Old Sep 01, 2012, 01:55 PM
arnav is offline
Find More Posts by arnav
I live my life 12oz at a time
arnav's Avatar
United States, FL, Miami
Joined Nov 2011
Thank you! Sorry... i pressed the elevator trim button down to add up elevator. I need to point the nose up....
arnav is offline Find More Posts by arnav
Old Sep 01, 2012, 03:42 PM
bartricky is offline
Find More Posts by bartricky
Shelter Kitty "Orange Death"
bartricky's Avatar
United States, FL, Monroe
arnav
Those larger wheels and gear may be messing with your trim.
They do so well as a belly lander.
bartricky is offline Find More Posts by bartricky
Old Sep 01, 2012, 05:01 PM
arnav is offline
arnav's Avatar
Joined Nov 2011
isn't climbing when lowering throttle is an indication of a luck of down-thrust angle though?
It is tempting to take the wheels of but I feel like I can learn more with them on (e.g. holding rudder when taking of, three point lendings etc'). Maybe Mosa #3...
Old Sep 01, 2012, 05:08 PM
JDMJim is offline
Find More Posts by JDMJim
JDMJim's Avatar
United States, IL, Joliet
Joined Jul 2011
I swapped wheels on my Wildcat400 and it sorta holds when I up or down elevator. it's weird....But I swapped wheels to a slightly wider foam tire from rubber. It had bad ground handling with 3 rubber tires. It's much better with a rubber tail wheel and foamies on the front
JDMJim is offline Find More Posts by JDMJim
Old Sep 01, 2012, 05:58 PM
arnav is offline
arnav's Avatar
Joined Nov 2011
Funny, that is exactly what I have!
and of course you were right about the Cessna <-> Formosa issue relations. It was time to switch to a new one...
Old Sep 01, 2012, 08:25 PM
Vince_TT is offline
Find More Posts by Vince_TT
United States, PA, Philadelphia
Joined Dec 2011
The reason I am asking is because two possibilities for nose pointing up (ballooning) at landing. First is too much down thrust, the second is tail heavy. If you need "up trim" to bring nose up for level flight, you are nose heavy. So I think, I can be totally wrong, you have too much down thrust.
Vince_TT is offline Find More Posts by Vince_TT
Old Sep 01, 2012, 08:29 PM
bartricky's Avatar
With the longer gear(more leverage) and larger wheels the drag may be enough to pull the nose down at higher power settings. Then if you trim up to compensate you will be out of trim when you reduce power.
The beauty of symmetrical wings is that, when properly trimmed, they will hold attitude at different power settings.
Or you may just have too much downthrust.
I would ditch the gear and get a Fun Cub to practice touch and goes.
Old Sep 02, 2012, 11:33 AM
arnav is offline
arnav's Avatar
Joined Nov 2011
haha... The weeds where I fly are like Velcro. Its more like touch and no go...
Have you ever been there? Its called Ives Estates Park.
It was the downthurst... I added two washers at the bottom of the X mount and the ballooning disappeared. Thanks for all the help everyone.
Its interesting, the heads up rc power 15 seems to generate more thrust than the e-filte power 15. With an 11x8 prop:
E-flite Power 15:
Peak Amp: 30A
Peak Watt: 365
Heads up RC Power up 15:
Peak Amp: 47
Peak Watt: 534
Unfortunately both measurements are with a batteries in storage mode so actual figures would be higher.
So now I have unlimited vertical with less then half a throttle... You think I should Prop Down?
All kidding aside I will prop down, I now get to fly 5mins instead of 7...
Old Sep 06, 2012, 05:02 PM
dazza44 is offline
Find More Posts by dazza44
who put that tree there
dazza44's Avatar
Joined Jun 2010
im in process of repainting my at-6.
the scheme is a captured one in german markings found a cpl of pics..
ive noticed has a two tone dark grey??
and a stripe on wing (yellow or possible white with black edges)
not sure if stripe on both wings..
any input i would be grateful...
dazza44 is offline Find More Posts by dazza44
Old Sep 07, 2012, 06:09 PM
rafe_b is offline
Find More Posts by rafe_b
Joined Jan 2009
A T-6 with German markings? Can't offer much help, just fighting off the urge to hurl chunks.
rafe_b is offline Find More Posts by rafe_b
Old Sep 07, 2012, 06:16 PM
Mike F is offline
Find More Posts by Mike F
Brookings, OR.
Joined Dec 2005
Captured AT6
You should see my GWS captured Cub. I like your AT 6. I'll dig out a picture and post my captured Luftwaffe J3. Most interesting subject.
Mike F
Mike F is offline Find More Posts by Mike F
Old Sep 07, 2012, 10:22 PM
JDMJim is offline
JDMJim's Avatar
Joined Jul 2011
I kinda wonder how Germany could have captured one....they came here and stole it?
Old Sep 08, 2012, 06:28 AM
dazza44 is offline
dazza44's Avatar
Joined Jun 2010
haha they took quite a few when they overrun france.
they even made a training manual in german for em..
Old Sep 08, 2012, 06:30 AM
dazza44 is offline
dazza44's Avatar
Joined Jun 2010
Mike F
it makes a interesting subject i find,away from the normal schemes..
Old Sep 08, 2012, 11:33 AM
Mike F is offline
Brookings, OR.
Joined Dec 2005
Captured allied aircraft
Check this site out. http://www.pipercubforum.com/luftcubs.htm.
Mike F
Yippee! All the modern good things corporations have brought us. cyclops2 Life, The Universe, and Politics 77 Nov 17, 2011 09:00 AM
Help! all the parts needed for a new GWS slow stick NP kit ? cyclops2 Foamies (Kits) 1 Sep 08, 2011 01:33 PM
Discussion Of all the stupid things done by NHS ... this has got to take the cake! logan5 Life, The Universe, and Politics 13 Jun 16, 2011 11:17 AM
Sold Four GWS Naro Max BB Servos $28 for all four. tryharder Aircraft - General - Radio Equipment (FS/W) 2 Mar 23, 2011 12:23 PM
