Old May 21, 2012, 09:26 PM
TheLeabres is offline
Find More Posts by TheLeabres
TheLeabres's Avatar
The Netherlands, ZH, Wassenaar
Joined Sep 2010
Originally Posted by dbar101219 View Post
I have a formosa 2 almost ready fly, but i don't think it has enough motor I put its tale on a scale and it weights about 900 grams when I go to full throttle it goes down to about 500 grams. Does anyone think that enough thrust to hand launch? this is the motor and esc I have in it with a 8/6 prop
http://www3.towerhobbies.com/cgi-bin...?&I=LXAUFX&P=0
thanks for any help
It's advertised for warbirds, probably 800mm WS. That motor is 1000 kv and you want to use an 8X6 on a heavy model like Mosa 2? The motor looks to be 400 size, 28mm diameter. Can you weigh it and tell us the weight? 300 watts but probably with 4S and 10" prop.
It's looking doubtful.
TheLeabres is offline Find More Posts by TheLeabres
Old May 21, 2012, 09:36 PM
twn Chen is offline
Find More Posts by twn Chen
Taiwan, 北市
Joined Dec 2010
The mentioned motor looks like a 450 size outrunner, it's a 1000KV one as said by its tech note, in my idea you need to apply full throttle more often, if it's 300W indeed, to power your Formosa II. And always use a prop 10 x 6 and 3S 1500 - 2200mAh 25C lipo with this motor for better performance. I'd suggest using a setup of 480 size or bigger one instead for making Formosa II more spirited.
Chen
p.s. Its tech note suggest using this motor on GWS warbirds, the 36" span ones, rather than Formosa II.
twn Chen is offline Find More Posts by twn Chen
Old May 21, 2012, 09:56 PM
dbar101219 is online now
Find More Posts by dbar101219
United States, OK, Tulsa
Joined Nov 2011
it weights 50 grams
dbar101219 is online now Find More Posts by dbar101219
Old May 21, 2012, 10:00 PM
Joined Nov 2011
Chen
i email integy and this is what they said
Please check to see if you are installing it on park flyer size airplane like the GWS slow stick or GWS type war bird. If that's the case, most people use 3S LiPo pack with approx. 2200mAh capacity. For prop. size, use 8x4 and never more than 9x6 depending on weather conditions. Make sure the motor and ESC receive sufficiency cooling, do not let them overheat and they'll last a long time.
Old May 21, 2012, 10:03 PM
Joined Nov 2011
this is my first electric plane and Im lost when it comes to motor size
Old May 21, 2012, 10:19 PM
arnav is online now
Find More Posts by arnav
I live my life 12oz at a time
arnav's Avatar
United States, FL, Miami
Joined Nov 2011
Then you may find this article useful: How to Determine a Model's Power Requirement. I did...
arnav is online now Find More Posts by arnav
Old May 21, 2012, 10:44 PM
Joined Nov 2011
that helps my ? is do you think it will fly? there is someone at my field flying a formosa 2 on a 200 watt motor so I thought that this 300 watt would plenty power
im finding out that its not that cut and dry. I have been on hobbyking looking at motors thats not alot of help I would like to get a motor the is 28?? cm in size so it will fit on the motor mount that i have installed
thanks
Old May 21, 2012, 10:48 PM
bartricky is offline
Find More Posts by bartricky
Shelter Kitty "Orange Death"
bartricky's Avatar
United States, FL, Monroe
thanks for any help
Says is a 300W, more than enough power... I would try at least a 10x6.
Under powered is really hard to fly.
bartricky is offline Find More Posts by bartricky
Old May 21, 2012, 10:56 PM
arnav is online now
arnav's Avatar
Joined Nov 2011
All these are known to have worked well with the Mosa 2:
Tower Pro 2408-21
BX 1060KV
AXI 2212/26
Revolution Shop 300 Watt Outrunner
Hacker A30-16M
Walkera 3200
Himax 3610
Hacker A30-16M
himaxx 2812-1080
Tower Prop 2915-5 Delta
Tower Pro BM 2908-10
Turnigy Aerodrive 1300kv
eflite 6 series
Turnigy 35-30C 1100Kv motor
E-flitePark 480
TR3542-1000kv
eflite 450
E-Flite power 10
Rimfire 35-36-1000
Power UP 25 Sport motor (900 kv)
E-Flite power 15 (which is the one I am using....)
Pick one?
Old May 21, 2012, 11:06 PM
wolfewinde is offline
Find More Posts by wolfewinde
My Co-Pilots Rock!!
wolfewinde's Avatar
United States, FL, Clearwater
Joined May 2011
I would use a more powerful motor - at least a Power 10 (375 watts), but probably a power 15 (575 watts). I think a 480 is still a bit too small
I am using an Eflite Power 10 on my 47" Techone Swift - similar in size and weight to the Mosa 2 - with an APC 11 x 5.5 prop and 2200 mah 3s batts and it flies very, very well.
I had Mosa 2 with a power 25 on it and that plane was not overpowered. I will use a power 15 on the next one , though
Arnav - have you flown your Mosa 2 yet?
Wolfe
wolfewinde is offline Find More Posts by wolfewinde
Old May 21, 2012, 11:12 PM
arnav is online now
arnav's Avatar
Joined Nov 2011
Wolfe, how you've been? We missed you... Good to have you back... It feels like you didn't stop by in ages (which means like 2 days? ) Have you been flying? I hope all is well.
Yes, I did (see here). Thanks for all the help!
Old May 21, 2012, 11:18 PM
My Co-Pilots Rock!!
wolfewinde's Avatar
Joined May 2011
Heya Arnav,
Wow you did a nice job on that plane - sounds like you got off to a good start with her - good for you.
Yes, i have been flying quite a bit - mostly my Techone Swift lately - flies a lot like the Mosa 2
Haven't posted on the GWS thread too much since I have yet to rebuild my new Mosa 2 and the Mosa 1 also needs some repairs so I haven't been flying GWS planes much lately.
I am really glad to hear you like the Mosa and had a good maiden
Wolfe
Old May 21, 2012, 11:23 PM
edwen303 is offline
Find More Posts by edwen303
edwen303's Avatar
United States, CA, Corona
Joined Jan 2010
Hi Dbar,
Underpowered plane can still fly okay. If you are using 8x6, it will give you good speed; for more thrust, try 9x5 prop.
Like other fellows said, 2200mah 3s battery with at least 20C rating will give you better performance, aka better thrust and better speed.
Bench test on your prop/battery combo before flying, mainly to see if ESC can handle your combo at full throttle without getting too warm. Once airborne, the actual load on current and ESC will be lower than static test. If your combo makes ESC a bit too warm, make sure ESC cooling is good. Never had a mosa 2, but I modified my GWS 190 by opening cooling channels in the front and back of battery compartment, also drilled cooling holes at the belly of rear fuse. It is not necessary as I flew her most at 2/3 throttle, around 30 A and 300W. Mosa 2 should be at this weight range, so 300 W should be sufficient.
Good luck with your maiden!
edwen303 is offline Find More Posts by edwen303
Old May 21, 2012, 11:27 PM
edwen303 is offline
edwen303's Avatar
Joined Jan 2010
Tower Pro 2408-21
BX 1060KV
AXI 2212/26
Hacker A30-16M
Walkera 3200
Himax 3610
Hacker A30-16M
himaxx 2812-1080
eflite 6 series
E-flitePark 480
TR3542-1000kv
eflite 450
E-Flite power 10
Rimfire 35-36-1000
Pick one?
Pretty surprise to see TP 2408-21 in the list! It would run 15 A at 3s with 7x5 or 8x4 prop, under 200 Watts! Guess for sport flying and light build, one can get away with 200W for Mosa 2
arnav is online now
arnav's Avatar
Joined Nov 2011
Wolfe, Thanks! I share my success with you. The Mosa 2 recommendation was all you... I would have never found out about this airplane had you not told me about it.... I love it. Can't wait to go again this weekend.
Yippee! All the modern good things corporations have brought us. cyclops2 Life, The Universe, and Politics 77 Nov 17, 2011 09:00 AM
Help! all the parts needed for a new GWS slow stick NP kit ? cyclops2 Foamies (Kits) 1 Sep 08, 2011 01:33 PM
Discussion Of all the stupid things done by NHS ... this has got to take the cake! logan5 Life, The Universe, and Politics 13 Jun 16, 2011 11:17 AM
Sold Four GWS Naro Max BB Servos $28 for all four. tryharder Aircraft - General - Radio Equipment (FS/W) 2 Mar 23, 2011 12:23 PM
