Old May 04, 2012, 11:58 PM
twn Chen is offline
Find More Posts by twn Chen
Taiwan, 北市
Joined Dec 2010
Originally Posted by dbar101219 View Post
i have the four little block but there not one for the motor im sending some pictures of what i have that is close but it is plastic do you think it work
Yes, the stick that was shown on the picture you posted is for fixing motor mount on, it's 10mm square one. But I do not know why they applied the plastic one instead of the original wooden one. It might be for enviornmental reason, plastic one could be recycled.
Chen
twn Chen is offline Find More Posts by twn Chen
Old May 05, 2012, 12:33 AM
TheLeabres is offline
Find More Posts by TheLeabres
TheLeabres's Avatar
The Netherlands, ZH, Wassenaar
Joined Sep 2010
I used this to build 5 or 6 GWS models, gluing fuselage halves. Bonds great without brittleness. The key is to enough but not too much or it fails or you'll have to keep it rubber band for 3 days for complete cure. If you put just the right amount (experiment with scrap foam) it's dry in 2 minutes or less. It's about the same as the vulcanization process used in patching inner tubes. I put on a very thin layer (less than paper width), then blow for a few seconds, then hold the two surfaces tightly againt each other with even pressure (but not too much to break anything) for about a minute (gotta use muscle on this!)
UHU Por Glue - a close up look (3 min 2 sec)
TheLeabres is offline Find More Posts by TheLeabres
Old May 05, 2012, 12:50 AM
TheLeabres's Avatar
Joined Sep 2010
Started build on GWS Pico Tiger Moth SG Slope Glider version:
First start off with two kits, because you know the appeal of these things and a buddy will want to buy one off you later - and you get the double the fun of painting/building.
Then lay out the pieces and paint. For spray paint, all I can find in India is imported stuff from Thailand but I like the quality and the smoky look already.
Old May 05, 2012, 02:55 AM
TheLeabres's Avatar
Joined Sep 2010
GWS Pico Tiger Moth NPS Version Unpainted
Save time and use time lapse when spray painting the GWS Pico Tger Moth Slope Glider version. Comes all white so the paint scheme options are infinite. Spray about 12 inches away so the propellant loses its sting before hitting the foam. Otherwise, the propellant eats the foam and you get tiny pits, more air drag but, like a golf ball, more lift too! lol!
Also, the NPS version doesn't have the GWS version of monokote on the wing/tail.
http://www.rcgroups.com/forums/showt...4#post21524120
Old May 05, 2012, 04:03 AM
nemoskull is offline
Find More Posts by nemoskull
Pilot, Co-pilot, Navagator
nemoskull's Avatar
United States, AZ, Yuma
Joined Sep 2009
were can one buy a new pico tiger moth these days? it seems every place i seen out of stock.
nemoskull is offline Find More Posts by nemoskull
Old May 05, 2012, 04:54 AM
TheLeabres's Avatar
Joined Sep 2010
Tower Hobbies
http://www3.towerhobbies.com/cgi-bin...?&I=LXCGKT&P=0
Old May 05, 2012, 08:25 AM
GiusedtoBe is offline
Find More Posts by GiusedtoBe
GiusedtoBe's Avatar
Tennessee
Joined Apr 2009
GWS P-40 upgrades
Had this great flying plane for about 2 years or more as a belly lander. Was in need of some minor repairs and one thing lead to another. I had some changesun rotaters sitting around so I added them and flaps. Resulting plane has a new lease on life and flies just as good as before even with the additional weight. Does not ballon at all and with a tad of lead in the tail to balance it out it slows to a crawl with the flaps and lands quite easily.
Regards,
Alan
GiusedtoBe is offline Find More Posts by GiusedtoBe
Old May 06, 2012, 07:23 AM
TheLeabres's Avatar
Joined Sep 2010
Update on the NPS Pico Moth build - using the AX 2308N 1100kv brushless Micro Motor from HobbyKing
I've used 5 of these motors, all with good results.
Factory Spec.
Kv: 1100rpm/v
Lipo Range: 2-3 cell
Suggested prop: 8x4 ~ 9x5
Best current range: 6~10A
Weight: 44g
Shaft diameter: 3mm
Stator: 23 x 8mm
Test Data.
Battery: 11.5v
Current: 9.7A
Propeller: 8x3.8
Thrust: 550g
Speed: 8520rpm
I'm using the upper 10mm hole and with the stick mount it lines up perfectly with the cowling.
Old May 06, 2012, 10:01 AM
bartricky is offline
Find More Posts by bartricky
Shelter Kitty "Orange Death"
bartricky's Avatar
United States, FL, Monroe
Mosa1 Pilot Figure..
Took my orinthopter outdoors for the first time. I can see how the micros can get away with a little wind.
bartricky is offline Find More Posts by bartricky
Old May 06, 2012, 10:50 AM
Pat Daily is online now
Find More Posts by Pat Daily
Pat Daily's Avatar
United States, VA, Chesterfield
Joined Mar 2001
My Zero (powered with a PJS 300) and my Swiss Float Moth yesterday at Shangri-La south in central Virginia.
Pat Daily is online now Find More Posts by Pat Daily
Old May 06, 2012, 12:46 PM
TheLeabres's Avatar
Joined Sep 2010
Those models are beautiful Pat!
Old May 06, 2012, 12:54 PM
davylah is offline
Find More Posts by davylah
Ex RAF Techie
davylah's Avatar
North East England
Joined Jun 2010
I second that, beautifull models!
So here's a question for you guys - I have a Spitfire and a ME109 in my loft but can't decide which one to do next. Whichever it is will get retracts and full custom decals and colour scheme. Any thoughts?
davylah is offline Find More Posts by davylah
Old May 06, 2012, 01:06 PM
TheLeabres's Avatar
Joined Sep 2010
I haven't built the Spit yet (though it's in my cart at Tower Hobbies) but I am fond oy me Me109. I flew her belly lander and she was just very graceful coming in on short grass.
Just guessing that with all equal setup (servos, motor, ESC, battery, prop) between the two, the Me109 goes faster, pehaps better streamlined perhaps better GWS job on molding the airfoil. With that, she can go faster with the heavier weight of paint, decals, retracts. And with faster stall speed, can't do a slow fly by to admire the craftsmanship? If you want the extras to go on something for the speed, my vote goes to the Me109. What motor, prop size, and battery are you putting in?
Old May 06, 2012, 01:36 PM
davylah is offline
Ex RAF Techie
davylah's Avatar
North East England
Joined Jun 2010
I've already built a Spitfire and found it great to fly. Absolutely no vices and was even predictable at the stall point. I've retired it now, before it gets too scruffy so will be using the same gear from the old one......
It will get a 1400kv Brushless with 8x4 prop and 3S1500mAh Lipo, a well proven setup in the previous Spitfire (Althought not in the pic above!)
Old May 06, 2012, 04:47 PM
Roger Lombard is offline
Find More Posts by Roger Lombard
Confused? Who, me?
Roger Lombard's Avatar
United Kingdom, England, North York
Joined Jan 2005
I happened upon this thread today http://www.rcgroups.com/forums/showt...light=hurrican
Started nearly five years ago when, at the time, there were no foamie Hurricanes on the market at all. Scorpio had done an abomination with rudder elevator only but it was deservedly neglected by the market and died. Despite the boss having suggested we start the thread nothing came of it because "there was no demand" so we got things like the J10 instead. Anyone want to hazard a guess how many foam Hurricanes there are now? And how many other manufacturers bothered with the J10?
Roger Lombard is offline Find More Posts by Roger Lombard
Yippee! All the modern good things corporations have brought us. cyclops2 Life, The Universe, and Politics 77 Nov 17, 2011 09:00 AM
Help! all the parts needed for a new GWS slow stick NP kit ? cyclops2 Foamies (Kits) 1 Sep 08, 2011 01:33 PM
Discussion Of all the stupid things done by NHS ... this has got to take the cake! logan5 Life, The Universe, and Politics 13 Jun 16, 2011 11:17 AM
Sold Four GWS Naro Max BB Servos $28 for all four. tryharder Aircraft - General - Radio Equipment (FS/W) 2 Mar 23, 2011 12:23 PM
