Old Oct 23, 2011, 01:44 PM
randyde is offline
Find More Posts by randyde
The Villages Florida
Joined Jul 2008
Build Log
Nouveau
Well its time for a new project, the last two have been tugs, was drawn to this commuter launch by a club member (Castaways, of the Villages Fl).
The original plan was about 35" lg, but we enlarged them to 43" x 10" beam,
The boat has some unusual hull lines, with a canoe stern, cant wait to do that, May do the cabin in cherry, I have to speak tp "Ed Lokken" about using iron on "Band-It veneer. Maybe next week will start cutting ply.
randyde is offline Find More Posts by randyde
Old Oct 23, 2011, 03:01 PM
patmat2350 is offline
Find More Posts by patmat2350
Vita ex Machinis
patmat2350's Avatar
United States, MI, West Bloomfield Township
Joined Dec 2004
That's a handsome boat...
patmat2350 is offline Find More Posts by patmat2350
Old Oct 25, 2011, 12:19 PM
CurtisP40 is offline
Find More Posts by CurtisP40
CurtisP40's Avatar
Joined Oct 2011
Nice boat. Interested in how you plank it.
CurtisP40 is offline Find More Posts by CurtisP40
Old Oct 29, 2011, 06:15 PM
randyde is offline
Joined Jul 2008
Nouveau
Worked all day cutting out ribs(3/16) and the keel (1/4), (11:00am to 7:00pm) lots of sanding and cutting, time for cold one, have to wait for my planking order, so maybe middle of next week for more progress.
Old Oct 30, 2011, 10:06 PM
telusboats is offline
Find More Posts by telusboats
Joined May 2010
Nouveau
I too have the plans for that boat. I have studied the plans and article . I hope you keep posting your progress so I can see how it turns out.
Don
telusboats is offline Find More Posts by telusboats
Old Oct 31, 2011, 06:21 AM
woodybob is offline
Find More Posts by woodybob
WooHoo!
woodybob's Avatar
Lake Balboa, CA
Joined Jun 2007
Sure is, found this here...
woodybob is offline Find More Posts by woodybob
Old Nov 03, 2011, 08:32 AM
randyde is offline
Joined Jul 2008
Noveau
Did a little dry fitting this morn, very interesting shape to the hull of this boat, but I think the rear filler piece is not there yet, needs a little more material, still waiting for my planking to arrive, so its of to the lake to take the "Nancy M" for a spin.
Old Nov 03, 2011, 06:18 PM
CurtisP40's Avatar
Joined Oct 2011
This will be a beautiful boat!
Old Nov 04, 2011, 07:38 PM
craig_c is offline
Find More Posts by craig_c
Spreckels Lake, GGP, SF, CA
craig_c's Avatar
USA, CA, San Francisco
Joined Apr 2007
This thread added to WOODIES: Wooden Pleasure Craft Build Logs listing.
Path: RCGroups -> Boats -> Scale Boats ->"WOODIES..."
craig_c is offline Find More Posts by craig_c
Latest blog entry: Ah, To be young again...
Old Nov 17, 2011, 01:22 PM
randyde is offline
Joined Jul 2008
Nouveau
Haven't had time to really do much work, but today, got all the ribs clamped up and ready for planking (may use 2" balsa), it took alot of adjusting, sanding, readjusting......don't know if the plan is a little off or the enlarging or just my tracing may have been off, but we are ready to go.
Found a launch out of Rhode Island, Watch hill, "Aphroite", it has a simular stern, ( see pics, no that is not me building the model ) I dont think Mr Massey the designer of the "Nouveau" describe the stern correctly as a "canoe stern", I believe a "torpedo stern " is more correct, (correct me if Im wrong)
Old Nov 19, 2011, 05:31 PM
randyde is offline
Joined Jul 2008
Nouveau
Started planking...installed the "Garboards", I can see a lot of "wet" balsa, using 1/2 wide planking, maybe when I get to the "Sheer" may use somthing wider, will see, but have to go slow with this hull.
Old Nov 19, 2011, 08:16 PM
EdLokken is offline
Find More Posts by EdLokken
The Villages, Fl.
Joined Oct 2002
Randy, a great subject. Can't wait to see more progress.
Ed
EdLokken is offline Find More Posts by EdLokken
Old Nov 19, 2011, 09:03 PM
Aerominded is offline
Find More Posts by Aerominded
Monterey Bay California
Joined Feb 2004
Originally Posted by randyde View Post
I can see a lot of "wet" balsa, using 1/2 wide planking...
Think "heat"... I use a clean soldering iron to bend balsa. You can work it almost like sheet metal. no waiting for the soak/dry cycle. heat and fit. done!
Aerominded is offline Find More Posts by Aerominded
Old Nov 19, 2011, 09:37 PM
ozoneone is offline
Find More Posts by ozoneone
King of The Moon
ozoneone's Avatar
NYC
Joined Jun 2003
Can you explain this?
ozoneone is offline Find More Posts by ozoneone
Old Nov 19, 2011, 09:51 PM
Joined Feb 2004
Sure. what I do is clamp my soldering iron to my workbench so that the "wand" (for lack of a better term) hangs out over the edge of the bench. Turn on the power and wait for it to come up to temp. When it's ready, I take my strip of balsa and make a few passes over the wand (direct contact with the shank) until the wood is heated, bending and twisting as needed (much like working sheet metal with an english wheel) to fit the hull forms I have set up on the strong back. the wood, when heated will hold the shape that I want, with no stress once cooled. "Steaming" wood has a similar effect. the idea is to heat the cells of the wood which actually become somewhat "elastic" allowing it to bend and take a set when cooled. Yes, the surface of the wood can scortch using this method but that is easily taken care of with sand paper.
Of course, caution should be used with this method.
I think Micro Mark may sell purpose made tools for this.
Discussion quelqu'un peut m'aider avec le branchement de mon nouveau Dragon link?? sadva Canada 0 Jun 19, 2011 05:45 AM
Discussion Ooooh La La! - Le Nouveau Pixel 2 est arrivé....................eventually! skirmish Slope 31 May 24, 2007 03:45 PM
Discussion UP Nouveau UFO...??? gpw Foamies (Kits) 51 Aug 09, 2006 07:10 AM
