Old Sep 21, 2003, 05:06 AM
Nicke is offline
Find More Posts by Nicke
hem.bredband.net/b254298
Nicke's Avatar
Sweden, sthlm
Joined Nov 2001
Free program to measure rpm using sound?
I saw someone mention that there are free programs that use the soundcard to determine prop rpm, but no mention of where to find them.
So does anyone know if such programs exist, and where to find them?
Nicke is offline Find More Posts by Nicke
Old Sep 21, 2003, 07:44 AM
mmormota is offline
Find More Posts by mmormota
mmormota's Avatar
Budapest
Joined Jul 2003
Re: Free program to measure rpm using sound?
You can use your soundcard az a digital storage oscilloscope.
There are free programs on the net, a useful one:
http://polly.phys.msu.su/~zeld/oscill.html
To use this program to measure rpm, you need a measuring head to convert the spin of the prop to electrical signal.
Possibilities:
magnetic method: a small piece of magnet (5*5*1 NdFeB or similar, size not critical) glued to the center of the prop (cellux etc), and a coil is the sensor (about 5 cm diameter, 10-20 turns, not critical), the soundcard input connected to the coil pins
optical method: a phototransistor in series with a 1k resistor and a battery, the soundcard input connected to the resistor pins
With the scope program you can check easily the new windings on a CDRom motor too: spin the motor with a drill and measure the signal on the coils, any shorts or asymmetries are clearly visible... In this case the voltage is too high to connect directly, you need 2 resistors to lower the signal (1k, 100k)
mmormota is offline Find More Posts by mmormota
Old Sep 21, 2003, 10:59 AM
agriebel is offline
Find More Posts by agriebel
agriebel's Avatar
Madison WI
Joined Aug 2003
I see radio shack has the photoresistors. Now I need to know what type of battery and how to wire the mess together. I assume that you aim the photoresistor at the spinning prop.
agriebel is offline Find More Posts by agriebel
Site Sponsor
Old Sep 21, 2003, 12:55 PM
Nicke is offline
Nicke's Avatar
Sweden, sthlm
Joined Nov 2001
Thanks for the link!
I was about to hack my old microphone to get the connector, but thought i should try it as is first. Since the blades generate pressure when they pass, i thought why not try?
So i held the microphone just behind the prop (1/4-1/2 inch), and ran the program. the waveform was very clear, and using the fourier transform i found that the rpm of my cd motor was 12240 with a gunther prop, which seemed reasonable.
I also tried my miniac with 4,2x2 prop on 3 lipolys, and according to this method it spins at 25800 rpm, which again seems reasonable.
So - no need to start building sensors, if you have a microphone!!!
Old Sep 21, 2003, 01:20 PM
agriebel is offline
agriebel's Avatar
Madison WI
Joined Aug 2003
Cool, I hadn't thought of that!
Site Sponsor
Old Sep 21, 2003, 01:34 PM
agriebel is offline
agriebel's Avatar
Madison WI
Joined Aug 2003
Which control is the fourier transform button?
Site Sponsor
Old Sep 21, 2003, 01:46 PM
mmormota is offline
mmormota's Avatar
Budapest
Joined Jul 2003
Nice idea!
Don't forget to divide the rpm with the number of blades.
Old Sep 21, 2003, 10:33 PM
mmormota is offline
mmormota's Avatar
Budapest
Joined Jul 2003
The one with the colorful stripes.
To get a numerical value, move the cursor to the maximum, and watch the frequency at the bottom of the window.
Multiply the result with 30 in case of a 2 blade prop, or with 20 at 3 blades.
Old Sep 21, 2003, 11:23 PM
Happy|Harry is offline
Find More Posts by Happy|Harry
veni,vidi, roto volubilis
Happy|Harry's Avatar
Aberdeen, Scotland
Joined Jul 2003
could you tell me all of the buttons to depress to get the correct reading
(a screenshot would do) and also which number do you use for the calculations?
F? or I?
phil
Happy|Harry is offline Find More Posts by Happy|Harry
Old Sep 23, 2003, 04:42 AM
Nicke is offline
Nicke's Avatar
Sweden, sthlm
Joined Nov 2001
I'll see if I can make some instructions when i get home from work. It's quite simple.
Old Sep 24, 2003, 03:15 AM
Aberdeen, Scotland
Joined Jul 2003
Any success on the screenshot or instructions?
phil
Old Sep 24, 2003, 11:28 AM
Nicke is offline
Nicke's Avatar
Sweden, sthlm
Joined Nov 2001
Oh sorry. totally forgot when i got home.
Anyway, I made some shots now. In both images, the white cross is where the cursor was. It disappears when taking screenshot...
To measure RPM:
Press the "play" button. Turn on the motor, and hold the microphone a few mm behind the prop, about half the blade out. While doing this, press the "pause" button.
You the have to play around with the T and Y1 slider to see the curve nicely. Note the distance between two peaks, with one in between as you can see in this case it reads 14.99 ms. To get rpm; rpm = 60*1000/14,99 = 4003 rpm. However, this is not very precise. This is just to verify that the reading in the fourier transform seems reasonable. SO now:
Old Sep 24, 2003, 11:33 AM
Nicke is offline
Nicke's Avatar
Sweden, sthlm
Joined Nov 2001
Press the fourier button (the color striped one). Again, play around with the T and Y1 sliders to get a clear curve. Usually, prop rpm turns out as the highest peak, also with the lowest frequency (the one most to the left).
Put the cursor at that peak, and read the frequency in the status bar (127,1Hz). Calculate RPM = 30*F = 127,1*30 = 3813 RPM, which is close to the 4003 rpm, but probably more precise since it uses more data.
That formula is for two bladed props.
3 blades: RPM = 20*F
4 blades: RPM = 15*F
Old Sep 24, 2003, 11:36 AM
agriebel is offline
agriebel's Avatar
Madison WI
Joined Aug 2003
Great, thanks much...
Site Sponsor
Old Sep 24, 2003, 12:00 PM
Aberdeen, Scotland
Joined Jul 2003
Cool thanks
now all i need is to finish my thrust measurement rig and i can get the full
range of readings
phil
Question How to Measure CDROM RPM Using Frequency Counter van-c Electric Motor Design and Construction 20 Aug 18, 2006 10:15 PM
Question How to measure the rpm's of a EDF??? mrbaseballny Electric Ducted Fan Jet Talk 13 Jan 06, 2005 12:04 PM
Doppler Velocity & RPM Using Microphone PhilLin Modeling Science 4 Sep 19, 2003 11:19 AM
anyone tried using sound for control? anatom Scratchbuilt Indoor and Micro Models 12 Feb 18, 2003 10:46 PM
measure RPM? Mark Electric Ducted Fan Jet Talk 0 Jan 14, 2003 04:35 PM
