This thread is privately moderated by Damian Couzoff, who may elect to delete unwanted replies.
Old Oct 23, 2011, 04:59 AM
Damian Couzoff is offline
Find More Posts by Damian Couzoff
Damian Couzoff's Avatar
Melbourne,Victoria,Australia
Joined Apr 2010
Gallery
Seagull models-KA8B (3 metre span)
This model has a tow release fitted, and working,and 250mm electric spoilers that l fitted, which replace the existing outdated letterbox spoilers.It has a low wing loading of only 15 oz/sq foot.Maiden flight went well on 6/11/2011,off the slope.Added extra lead to the nose,to balance at 60mm,wing loading is now 16.5 oz/sq foot,total flying weight 2.9 kg.Flys well,and is very stable.
Damian Couzoff is offline Find More Posts by Damian Couzoff
Old Feb 22, 2012, 06:09 PM
96td is offline
Find More Posts by 96td
Joined Nov 2006
aerotow realease
hi there Damian,
i've just bought a m/plex dg300 which had been winch launched and i would to fit an aerotow realease.
I was hoping you might have a positive setup
you could recommend.
Thanking you in advance
Chris Hunt
96td is offline Find More Posts by 96td
Old Feb 23, 2012, 01:45 AM
Joined Apr 2010
Originally Posted by 96td View Post
hi there Damian,
Chris Hunt
Hi Chris,my MPX DG 300 does not have a tow release fitted,its built for slope only,coming in at a heavy 7kg flying weight.HobbyKing sell aerotow releases,which would be suitable for the task.A high torque digital servo is also required,mounted securely.I hope to hear from you,how your DG 300 flies,as there must not be to many left still flying today.The wortmann airfoil is perfect for thermalling,especially if you have the extended wing tips to 4.25 metre span,and if its built light.regards damian
Old May 22, 2012, 04:13 PM
joevella is offline
Find More Posts by joevella
Joined May 2012
Has anyone ever launched one of these Ka8's from a winch? Thanks.
joevella is offline Find More Posts by joevella
Old May 24, 2012, 03:46 AM
Joined Apr 2010
The wings are NOT designed to be winch launched,this glider is designed for aerotowing or slope flying.
Discussion Seagull models-KA8B (3 metre span) Damian Couzoff Scale Sailplanes 107 Jun 23, 2014 02:35 AM
Discussion First scale soarer around 3 metre span Elma Fudd Scale Sailplanes 34 Sep 15, 2010 07:22 AM
