Old Oct 22, 2011, 11:44 PM
Jake1050 is offline
Find More Posts by Jake1050
Joined Jul 2011
Is my Thunder AC6 broke? (now with youtube video)
Got my new charger the other day. Finally got around to plugging it in and trying it out on one of my (also new) sky lipo 11.1 3000 mah batteries. Plugged it in and started it up just like in the youtube video. Walk away and come back 5 minutes later and the timer has stopped and the display is flashing and an audible clicking sound is heard.
Unplugged it and tried it agian and same thing. It just flashes and clicks. So I dig the 12 volt alligator clips out and try to run it off of my battery. From the battery it seems to work fine.
Please help.
Jake1050 is offline Find More Posts by Jake1050
Old Oct 22, 2011, 11:50 PM
KCinNC is online now
Find More Posts by KCinNC
that's gonna leave a scar
United States, NC, Mooresville
Joined Aug 2007
i have had one for over a year and it works great !! double check to make sure you have the correct battery info selected before you start charging...you will get an errror signal if not correct !
KCinNC is online now Find More Posts by KCinNC
Old Oct 23, 2011, 12:10 AM
Jake1050 is offline
Joined Jul 2011
The only thing I did wrong is I had the regular charging selected instead of balance and I had the balance lead plugged in but that should not have caused a problem. And the fact that when connected to a battery it works fine leads me to believe its may be a bad AC power supply.
Old Oct 23, 2011, 12:19 AM
BGR is offline
BGR
Find More Posts by BGR
BGR
Foam Junkie
United States, CA, Oceanside
Joined Dec 2003
It sounds like the internal power supply may not be up to the task of charging that battery. Are you charging it at 1C (3 amps)?
BGR is offline Find More Posts by BGR
Old Oct 23, 2011, 12:29 AM
Jake1050 is offline
Joined Jul 2011
I had it set for 3 amps. But now when I simply plug the unit into the wall (with no battery attached) the display flashes fast with an audible clicking sound. When I connect a 12 volt battery it works normally.
Old Oct 23, 2011, 12:30 AM
Jake1050 is offline
Joined Jul 2011
Im about to post a youtube video to show you what it does.
Old Oct 23, 2011, 01:07 AM
Jake1050 is offline
Joined Jul 2011
thunder ac6 not working properly (1 min 10 sec)
Old Oct 23, 2011, 01:32 AM
BGR is offline
BGR
BGR
Foam Junkie
Joined Dec 2003
Yea its the power supply, its either not working or a internal connection is bad.
Old Oct 29, 2011, 11:43 PM
Joined Aug 2007
did you find the problem ?
Old Oct 30, 2011, 10:41 AM
seair is offline
Find More Posts by seair
Joined May 2009
Curiously, can you plug the adapter the other way into the charger?
seair is offline Find More Posts by seair
Old Oct 30, 2011, 01:44 PM
TheWoodCrafter is offline
Find More Posts by TheWoodCrafter
RC Helicopter Pilot
TheWoodCrafter's Avatar
United States, CA, Westminster
Joined Mar 2010
Looks like a bad unit.
Send it back.
TheWoodCrafter is offline Find More Posts by TheWoodCrafter
Old Nov 02, 2011, 07:31 AM
telance1011 is offline
Find More Posts by telance1011
Lance
United States, CO, Littleton
Joined Apr 2011
I had this same charger and had the same thing happen to it. They replaced it with a Thunder AC680, because the AC6 was not available and the internal power supply on that one went bad after about 4 months, just popped and quit working. I've just been running it off of my power supply as I don't want to hassle with returning it. This is just a backup charger now as I have others. If you can return it, I would probably try to get something else. The price on those is right but quality seems to be lacking.
telance1011 is offline Find More Posts by telance1011
Old Dec 29, 2011, 12:43 PM
Jake1050 is offline
Joined Jul 2011
Thanks for the help guys I have an update.
I went to amazon dot com and typed in 12v power supply and bought one made for an LCD monitor. It is rated for 6 amps so I guess Ill probably never need to set the unit for more than 3 amps. Addmitedly I know very little about electronics and had my doubts it would work. As luck would have it the connecter is just the right size to fit in the dc port on the side of the unit so I just replaced the power supply that came with my AC6 and ran the cord out the right side and over to the left side. It looks ghetto but it actually works (for now). Fingers crossed that this will be a long term fix. I'm looking forward to not having to bother with the motorcycle battery and plug in charger.
Old Dec 29, 2011, 09:24 PM
aero550 is offline
Find More Posts by aero550
United States, OH, Tipp City
Joined Oct 2011
Just curious...why didn't you just have HobbyPartz replace it if this happened upon the first use after receiving it?
aero550 is offline Find More Posts by aero550
Old Dec 31, 2011, 12:18 AM
Jake1050 is offline
Joined Jul 2011
That is what I should have done. I honestly do not have an answer for that. I guess I thought maybe I did something wrong and it was my fault it broke. Or at the very least maybe there was nothing wrong with it and I wasn't doing something right. At any rate its working now.
Sold Brand new Thunder AC6 charger - only used a few times BayAreaCrasher Aircraft - Electric - Batteries & Chargers (FS/W) 11 Oct 21, 2011 12:48 PM
Help! Thunder AC6 charger for Nicads dwatherton Batteries and Chargers 3 Oct 08, 2011 11:48 AM
Discussion Radio charging via LiPo charger (Thunder AC6) big_poppa4904 Radios 2 Sep 30, 2011 12:13 AM
Mini-Review Thunder AC6 & HobbyPartz.com Snowdog Batteries and Chargers 4 Sep 22, 2011 07:07 AM
Sold Thunder AC6 Charger blueapplepaste Aircraft - Electric - Batteries & Chargers (FS/W) 7 Sep 10, 2011 11:43 AM
