Melbourne, Australia
Joined Oct 2005
I appreciate the vote of confidence, thank you.
If you haven't seen it there is a considerable amount of info in this link: http://www.rcuniverse.com/forum/m_55...tm.htm#5531029 |
Kelowna , BC
Joined Nov 2008
ARF vs KIT
Yes I went the kit version also as mine took 10 plus years in the making so know what you mean. The nice thing with the kit version you can make any and all modes that the ARF version does not have. My battery compartment is oversized so I have no problem with a single 6S battery to fit and I made the wing struts functional as at the time I had mine; the wing joiner was a weak link according to the kit report in a past magazine. I also built in float mounts for future expansion to float flying if I decide to do so .
Yes.There is plenty of room for the batteries in deed!
![]() I want to try with one 6S 4000 that I've installed into the cowling for saving weights. CG looks good so far. (100 mm from leading edge) But nevertheless she feels a little bit heavy , so I wish I have had reinforced the wingstruts, too ![]() Yep, floating must be a dream with her, but I have no chance to try were I live- so I have to hit the runway..
Kelowna , BC
Joined Nov 2008
posting report #56 shows how I added the least amount of weight for balance by bolting the lead bar as far foreward as I could. The weight amount changed from 14oz inside the firewall area to the foreward inside cowl area I think it was to about 4 oz or close to it. Saving was about 8 to 10 oz in any case. Mounting can be easily changed for fine tuning.
After balancing was set I clipped off the excess bolts. I think I also used 100mm for CofG and seemed to be right on and am happy with landing performance. |
Kelowna , BC
Joined Nov 2008
Cessna landing gear
Just received my ARF landing gear and looks not too bad. The mains are definitely made of fibreglass and much thicker .... arround 7.5 to 8 mm thick depending were you measure. Also looks like I may be able to get at least another 1/2 inch overall more ground clearance for my 16x8 prop . Like it !
![]() Also went with the ARF wheel pants as the extra cost was not worth making new pants. |
pics, pics, pics..
The 16 x 8 Prop sounds very nice, I will give it a try..![]() I have the origin wheelpants made of ABS - plastic , I'm not sure that they will lasting very long on a grass-strip ! The ARF mains are made of fibre-glass?? That could mean an improvement, never get tired |
Kelowna , BC
Joined Nov 2008
The brushless motor is a Scorpion 4025-12 on 6S and draws 53 amps full out at 8300 rpm. on that APC 16x8. Takeoff is at about 75% power and usually half flap.
Scale airplane is more fun when flown scale like. Whatched a video "warbirds over deleware" were a 4 engine bomber was doing vertical climbs, rolls and patern type flying and th announcer thought that was just so great. Myself on a scale of 1 to 10.... I would give a zero. |
![]() That doesnt't look very scale ..
| Thread Tools | |
| Sold REDUCED!!Hobbico FlyZone Cessna 182 Skylane EP PNP 47.5" Trade ? | kramer | Aircraft - Electric - Airplanes (FS/W) | 6 | Nov 22, 2011 03:15 PM |
| For Sale REDUCED!!Hobbico FlyZone Cessna 182 Skylane EP PNP 47.5" with SPARE PARTS!! Trade ? | kramer | Aircraft - Electric - Airplanes (FS/W) | 9 | Oct 09, 2011 09:02 PM |
| For Sale Topflite Cessna 182 Skylane Gold Ed Kit .61-.91,81" | Vagabond324 | Aircraft - Fuel - Airplanes (FS/W) | 2 | May 28, 2011 10:49 PM |
| For Sale Great Planes Cessna 182 Skylane .40 ARF 110.00 NIB LPU San Diego | boatdoc | Aircraft - Fuel - Airplanes (FS/W) | 1 | Mar 14, 2011 12:15 AM |
| Motor for TopFlite Cessna 182 Skylane | SiPet | Power Systems | 5 | Jan 06, 2009 08:17 AM |
