Old Feb 10, 2013, 08:46 AM
skydvejam is offline
Find More Posts by skydvejam
Once you taste flight...
skydvejam's Avatar
United States, ME, Garland
Joined Dec 2011
Originally Posted by PeterVRC View Post
I guess the Relex Switch idea is to use between flights? Shift weight a LOT more forward and use Reflex then?
But I am not sure why, as the Radjet must already have an appropriate wing design seeing it flies great just as it comes.....? I would assume it uses washout - I have never looked so I don't know what base idea they used.
I have the reflex set for up ele for launch, after reading enough threads I understand that it should help some with the launch.
skydvejam is offline Find More Posts by skydvejam
Old Feb 10, 2013, 10:27 AM
headlessagain is offline
Find More Posts by headlessagain
Reap the wild wind
headlessagain's Avatar
Bristol,UK
Joined Feb 2007
Originally Posted by AnTLeNFer View Post
Thanks for the info and the video Andy, I love that model, you have a plan?
Greetings.
Here you go http://www.rcgroups.com/forums/showthread.php?t=1209113
It was originally designed as a profile fuse model but I just cut an extra side to make it a full fuse. My build starts here http://www.rcgroups.com/forums/showp...3&postcount=46 She was a sweet flyer once a I 'd added some nose weight.
Andy
headlessagain is offline Find More Posts by headlessagain
Old Feb 10, 2013, 07:58 PM
PeterVRC is offline
Find More Posts by PeterVRC
Australia, VIC, Melbourne
Joined Nov 2006
But wouldn't 'temporary reflex' just be called UP Elevator!?? LOL
Really that is all it is.... Up Elevator to make a similar effect to having real reflex built into a wing.
And to have it really be "Reflex" it would be permanent (even if done via permanent up elevator trim), and that means needing a lot more rearwards CofG (more weight forwards) for it to fly without climbing all the time.
PeterVRC is offline Find More Posts by PeterVRC
Old Feb 13, 2013, 02:31 PM
xxxcellarator is offline
Find More Posts by xxxcellarator
xxxcellarator's Avatar
Toronto, Canada
Joined Nov 2009
... and that means needing a lot more rearwards CofG (more weight forwards) ...
Under no circumstances does that make sense
Rearward/aft CofG implies more weight at the back, or balance point closer to the back, not "forwards".
xxxcellarator is offline Find More Posts by xxxcellarator
Old Feb 15, 2013, 12:40 AM
hate2crash is offline
Find More Posts by hate2crash
Joined May 2010
Anyone ever flown this fiberglass/balsa electryfly evader? I love my radjet and feel i have gotten pretty good at flying it...But this evader is now pretty cheap price since its been out a couple of years and looks very nice...Just not sure i have the skill to fly it and keep it in one piece ...heres a video of if
Great Planes Evader EDF Sport Jet ARF.mpg (3 min 58 sec)
thx
hate2crash is offline Find More Posts by hate2crash
Old Feb 15, 2013, 01:47 AM
PeterVRC is offline
Joined Nov 2006
LOL, oops... maybe it was reverse....sorry!
More forwards CofG
This will also make the CofG 'weird' relative to the CoL.... so it is just not the right way to fix things by 'warping' something else, which creates other aerodynamic balance issues.
Though it could fluke being BETTER.... or worse... than normal. Especially if the 'normal' state was not overly aerodynamically correct anyway.
But to me it seems a great acting little plane, so I suspect they did get everything quite right about it.
Old Feb 15, 2013, 01:45 PM
sneci1977 is offline
Find More Posts by sneci1977
sneci1977's Avatar
Hungary, Somogy County, Siofok
Joined Feb 2013
Motor timing
Hi,
i have this plane in ARF version. I use a Turnigy Plush 40A ESC whit stock motor (the brown-black one).
What motor timing is recommended to set?
sneci1977 is offline Find More Posts by sneci1977
Old Feb 15, 2013, 01:56 PM
skyhawk newbie is offline
Find More Posts by skyhawk newbie
Not a newbie anymore..
skyhawk newbie's Avatar
Ireland, Cork
Joined Oct 2010
Originally Posted by sneci1977 View Post
Hi,
I'd like to know this aswell, ,as I've just started putting my RadJet together today.
All so , using the stock motor with above ESC running a 1300mAh 3cell Nano
what watts readings are you guys getting with 5x5 / 6x4 props..
This will be my first jet style plane,but once used to the way it flys
I'll be up-grading the motor.
Sean
skyhawk newbie is offline Find More Posts by skyhawk newbie
Old Feb 15, 2013, 03:07 PM
sneci1977's Avatar
Joined Feb 2013
Tomorrow i will try the maiden, depends on weather.
I will measure the 5x5 with wattmeter for U mate.
Old Feb 15, 2013, 03:28 PM
Ireland, Cork
Joined Oct 2010
Thanks..
Sean
Old Feb 16, 2013, 11:46 AM
sneci1977's Avatar
Joined Feb 2013
Sorry, today the maiden went wrong. the nose ripped out at crash.
After glueing together tomorrow next try.
Old Feb 16, 2013, 08:57 PM
setxws6 is offline
Find More Posts by setxws6
Hemi pilot
setxws6's Avatar
USA, TX, Lumberton
Joined Oct 2005
The Evader fly's heavier than the Radjet, so everyday maneuvers you'd always get away with with the Radjet would make a lawn dart out of the Evader. The Evader has to be flown with speed and large sweeping maneuvers. And it lands much hotter than the Radjet with more landing room required. Also, fiberglass and balsa don't do well with really rough landings like a foam plane, and is much harder to piece back together after an oops.... Just some things to keep in mind. I've owned/flown both by the way....
setxws6 is offline Find More Posts by setxws6
Old Feb 16, 2013, 09:08 PM
DJO is offline
DJO
Find More Posts by DJO
DJO
DJO's Avatar
Joined Oct 2011
RadJet. Stock motor, 30A ESC + 6x5.5 APC prop.
I'd say about 80 MPH, maybe 85? What do you guys think?
RadJet - 6x5.5 and 30A ESC First Flight (1 min 31 sec)
Dan
DJO is offline Find More Posts by DJO
Old Feb 18, 2013, 11:26 AM
sneci1977's Avatar
Joined Feb 2013
Originally Posted by skyhawk newbie View Post
Thanks..
Sean
Hi Sean,
my first take off ended with crash, was my fault. The second start was succsess.
I measured the TGS 5x5E with 3S: 14Amps and 150Watts.
Stock prop (don't know the size) it was better: 15A - 170W
Stock prop with 4S: 20A - 285W
Here is a vid from the 3. flight:
Radjet 800 (13 min 4 sec)
Andy
Old Feb 18, 2013, 08:02 PM
Joined May 2010
https://www.youtube.com/watch?v=Uq16hKglrL4
Dan
Dan, what motor and batteries u using?.... mine looks about same speed,but hard to tell from video
Contest Habu 32 Speed Contest Tumbler Unlimited Class 165.2 keithtsr Electric Ducted Fan Jet Talk 2140 May 01, 2016 10:29 PM
Discussion RadJet from the KING! vettster Foamy EDFs 1 Jun 01, 2014 06:00 PM
Help! New ViperJet From Hobby King dviperjet Electric Ducted Fan Jet Talk 20 Sep 30, 2011 07:04 AM
For Sale orange rx from hobby king and orange satilite from hobby king ZEROSKIN76 Aircraft - General - Radio Equipment (FS/W) 8 Mar 15, 2011 01:41 PM
Sold orange rx from hobby king and orange satilite from hobby king ZEROSKIN76 Aircraft - General - Radio Equipment (FS/W) 4 Feb 21, 2011 12:06 PM
