Old Nov 16, 2012, 09:22 AM
The_RattleSnake is offline
Find More Posts by The_RattleSnake
The_RattleSnake's Avatar
Joined Jul 2007
Originally Posted by headlessagain View Post
I agree. I once asked why the Rare Bear with it's fat fuse and big frontal area is the fastest of the Skyangel/HK Funfighters. The answer was the lack of panel lines. I believe they have had one at around 136 mph on a different motor.
Andy
I also herd that the airfoil used was a big factor.
The_RattleSnake is offline Find More Posts by The_RattleSnake
Old Nov 18, 2012, 10:46 AM
Kurt is offline
Find More Posts by Kurt
Upstanding Member
Kurt's Avatar
United States, TX, Houston
Joined Sep 2003
The Dually is painted up and almost flight ready.
Went a little wacky on the paint scheme. Would have liked to go with a more correct silver/red/blue Red Bull scheme but none of the silver paint I had left a decently smooth finish like white. Should be good for vis anyway which is the most important thing.
Took her out to the field yesterday but it was a bit windy and I didn't have time to go through all of her systems thoroughly so the maiden will have to wait.
For the first flight at least I'll probably not worry about differential thrust (or counter rotating props), just make sure she flies and handles well before adding this extra layer of complexity.
Got the central elevator mixed in to the elevons, batteries wired in parallel so the motors spin at the same RPM, and left/right sides balanced.
Not sure if I'll launch her from the skid I glued in the center, or maybe an underhand toss grabbing the leading edge-side of the central wing.
Any other ideas?
Kurt is offline Find More Posts by Kurt
Old Nov 18, 2012, 11:44 AM
headlessagain is offline
Find More Posts by headlessagain
Reap the wild wind
headlessagain's Avatar
Bristol,UK
Joined Feb 2007
Nice paint job on the twin. Looking forward to the maiden flight report.
Andy
headlessagain is offline Find More Posts by headlessagain
Old Nov 18, 2012, 07:59 PM
setxws6 is offline
Find More Posts by setxws6
Hemi pilot
setxws6's Avatar
USA, TX, Lumberton
Joined Oct 2005
LOL that's awesome. Should be an interesting maiden!
setxws6 is offline Find More Posts by setxws6
Old Nov 19, 2012, 06:41 AM
Joined Jul 2007
Great job you are doing there.
Just wondering why you say this.
You will have double torque roll if they both spin the sameway, none of you use counter rotating props.
Counter rotating is a must with duel props!
Old Nov 19, 2012, 07:33 AM
setxws6 is offline
Hemi pilot
setxws6's Avatar
USA, TX, Lumberton
Joined Oct 2005
Agreed
Old Nov 19, 2012, 04:29 PM
Kurt is offline
Upstanding Member
Kurt's Avatar
Joined Sep 2003
Since I had flew my JPower P-38 without counter rotating props and the Radjet's 6x4s are smaller and lighter I didn't think it would be necessary but now you have me wondering... that's not a bad idea.
It wouldn't hurt anything to go this route so I'll do it.
Just ordered 2 of each of these:
http://www3.towerhobbies.com/cgi-bin...ZK90&search=Go
http://www3.towerhobbies.com/cgi-bin...PVF3&search=Go
tally ho!
Old Nov 19, 2012, 06:38 PM
dahawk47 is online now
Find More Posts by dahawk47
Augermeister
dahawk47's Avatar
United States, TX, Keller
Joined Jul 2011
Very few full scale twins actually have counter-rotating props. Few RC civilian twins have them either. My DH-88 Comet has them and they are nice but would the plane get airborne without them ? Probably
dahawk47 is online now Find More Posts by dahawk47
Old Nov 20, 2012, 05:21 AM
harlyquin76 is offline
Find More Posts by harlyquin76
harlyquin76's Avatar
Australia, TAS, Claremont
Joined Jul 2012
That came up well Kurt, good job, cant wait to see a video of it flying!!!
harlyquin76 is offline Find More Posts by harlyquin76
Old Nov 20, 2012, 05:04 PM
Reap the wild wind
Bristol,UK
Joined Feb 2007
Solentlife has a different approach to converting an HK airframe to a twin with his Parkjet twin. http://www.rcgroups.com/forums/showp...postcount=1292 but will be first to maiden? He is going for contra rotating props on his set up
Andy
Old Nov 24, 2012, 09:43 PM
Emil in Oz is offline
Find More Posts by Emil in Oz
Emil in Oz's Avatar
Joined Jul 2012
RadJet Settings
Hi all,,i will be buying a Radjet 800 pnp very soon,,my set up is Spektrum6ch,AR600Rx,,Eflight 30amp esc,,flightmax 1600mah batt.Before i learn how to launch this bird,could someone pls be able to give me some start-off settings for the Rad? I probably will start off slow just to get the feel of it,,wat % for the High@Low rates is a good starting point,,,i really want to get my head around this Jet and i dont particually want to be spending$ on fix ups so i thought it would be a good idea to get some info-i also have numerous peices of carbon fibre rods so any areas that require strength would be appreciated,,,thanks fellas hopefully i can come back with some on bourd footage ,,Emil W.A
Emil in Oz is offline Find More Posts by Emil in Oz
Old Nov 25, 2012, 12:23 AM
Joined Jul 2007
If you are using the stock motor you wont need to reinforce it with carbonfibre.
Its very sensative on the roll so %100 for pitch and %60 rates for roll
Set the COG to 400mm from the tip of the nose (measure this BEFORE it gets blunt :P ).
Old Nov 25, 2012, 09:30 PM
PeterVRC is offline
Find More Posts by PeterVRC
Australia, VIC, Melbourne
Joined Nov 2006
I would run one - or two - CF spar(s) right across into each wing. I used just the one 5mm CF tube spar, but wood skewers for and aft of that to keep thins aligned and their small 'joint support' they will give.
This is because pretty well no foam wing stays on a foamie 'properly' with just glue. Nothing glues it properly... and nothing can hold the forces a wing can have at 90deg to the joint some times. So eventually it will crack and/or break, if no spar.
PeterVRC is offline Find More Posts by PeterVRC
Old Dec 02, 2012, 07:59 AM
Joined Jul 2007
I broke the 150 MPH barrier in my RadJet today!.
Now i just need to edit it and get a doppler reading for confirmation.
Old Dec 02, 2012, 04:14 PM
setxws6 is offline
Hemi pilot
setxws6's Avatar
USA, TX, Lumberton
Joined Oct 2005
We need details on what you did to get that extra mph
Contest Habu 32 Speed Contest Tumbler Unlimited Class 165.2 keithtsr Electric Ducted Fan Jet Talk 2140 May 01, 2016 10:29 PM
Discussion RadJet from the KING! vettster Foamy EDFs 1 Jun 01, 2014 06:00 PM
Help! New ViperJet From Hobby King dviperjet Electric Ducted Fan Jet Talk 20 Sep 30, 2011 07:04 AM
For Sale orange rx from hobby king and orange satilite from hobby king ZEROSKIN76 Aircraft - General - Radio Equipment (FS/W) 8 Mar 15, 2011 01:41 PM
Sold orange rx from hobby king and orange satilite from hobby king ZEROSKIN76 Aircraft - General - Radio Equipment (FS/W) 4 Feb 21, 2011 12:06 PM
