at 3 minutes 25 seconds into this video my Radjet goes into a death spiral, Half throttle fixed the problem. |
I still dont understand why people get suprised at this, I have said many times this is how you get out of it. Some people are just stubborn /dont like to bo told they are wrong I guess.
Cool vid Harly, and good story Peter even though it has a sad ending
![]() Where did you find a $28 GPS logger by the way? Got a link? Thanks! I've got Radjet fever... not even done with the Dually and yesterday ordered another kit from HK's US warehouse. Figured I have an extra 2826 motor and ESC, plenty of servos, extra set of wings and want to try an X-wing design, and do want to have one with left/right thrust vectoring engine mount and a Harlyquin-styel canard so why not. Putting the finishing touches on the dually and noticed the pieces of white tape on the underside covering up 4 holes per fuse. Any idea what these are for? I'm just spackling over them, and have CA'd 1/16 basswood blanks over the finger detents to have a smoother underside. Will probably put a large Dubro tail skid in the middle for throwing. Also cut and reinforced the center elevator and properly hinged the ailerons. Weight of the bare airframe will be ~450g, with all electronics and batteries ~900g. The biggest decision now is paint scheme. As cool as a military grey or black would look, for vis I'm leaning towards a red/white/blue combo something like this: http://www.rcgroups.com/forums/showp...postcount=2004 |
Australia, VIC, Melbourne
Joined Nov 2006
I need some maths/formulas on projectile trajectories and ranges.... so I can work out where to start looking for the battery and GPS.
I figure (guess) that I could throw that battery type about 20m to 30m, so coming out of a ???? (160kph by then?) aircraft, at anything from 30deg to 70deg angle (seeing it must be at some reasonable angle to get the high stress to break), and starting from about 20m up, means it could maybe go 100m to 200m ahead of that?? I have given up on it (battery/GPS) and am not too fussed on getting them back.... but I would like to know where it really went! |
i hate when that happens Peter, i lost a micro sd card out of a wing cam from my 1st onbored flight, only cost $6 but really wanted to see the footage of my friends planes filmed from my radjet for the 1st time.
We spent ages combing the fooball ground for it but something that tiny would be near to impossible to find. i now put tape around the back of the wing cam holding the card in. Hope you have better luck. |
the Dually is sufficiently reinforced and smoothed out, servos and control horns mounted and has a coat of primer. Now just need to finalize the wiring, decide how I'm going to lock down the turtle decks (the canopy is fixed to the deck so it comes off in one piece, already removed the canopy magnets) and give her final coats of paint and she'll be done.
All-in weight with two 1300mAh 3S batteries will be ~900g and from a prelim cg check it's within 5-10mm of the stock (single) RJ location. If I had a bit more skill and forethought would have liked to hide the central elevator control horn (or could have mounted on top to protect the servo but wouldn't like the look up there). Think I'll set up a switch to fully extend the central surface on landing, should act a bit like a flap and also better protect the lower control horn from snagging. Should have also made the central elevator an inch or two wider. Wouldn't have been difficult, and would have given me extra margin for pitch authority which I hope won't be a weak point. Twin foam cooling scoops were made from unused P-38 pieces. Not thrilled with how they look but not too bad, and they do make nice handles to remove the turtle decks. Might just get her in the air before things get REALLY cold up here! |
When I had my 2836 setup, I left the motor as far back as I could, for CG reasons and also for better cooling. |
| Thread Tools | |
| Discussion Habu 32 speed contest * Tam Jets Top Gun 173.3* Stock leader Skylineflyer 126.6 | keithtsr | Electric Ducted Fan Jet Talk | 1755 | Mar 08, 2013 04:05 PM |
| Discussion RadJet from the KING! | vettster | Foamy EDFs | 0 | Oct 21, 2011 11:33 PM |
| Help! New ViperJet From Hobby King | dviperjet | Electric Ducted Fan Jet Talk | 20 | Sep 30, 2011 07:04 AM |
| For Sale orange rx from hobby king and orange satilite from hobby king | ZEROSKIN76 | Aircraft - General - Radio Equipment (FS/W) | 8 | Mar 15, 2011 01:41 PM |
| Sold orange rx from hobby king and orange satilite from hobby king | ZEROSKIN76 | Aircraft - General - Radio Equipment (FS/W) | 4 | Feb 21, 2011 12:06 PM |
