Couple frame grabs from the servo cam. I took her up pretty much to the edge of my eyestight for the first one - the shore of Lake MI is 6.5 miles away accd to Google Maps.
The left/right panning works very well! Once the weather gets too cold to do much outside I'll put together a compilation video. |
I used this one, but the white version should work as well:
http://www.amazon.com/Gorilla-Glue-A...s=gorilla+glue Use it sparingly, it will expand with moisture, you can put a piece of clear tape over the joint to help keep excess from coming out of the joints. I have about 6 different glues for various RC plane joints: hot glue gun (<$10 from Walmart) that sticks very well to foam, but cools quickly! 15 minute 2 part epoxy for wood and plastic, CA, Gorilla super glue, white and brown Gorilla glue.... it's always a bit of a guess whether it will work, so if possible do a test glue first and be patient, let whatever glue you use dry completely if possible before flying! |
^ Every thing Kurt just said. I wouldn't use Epoxy on foam, it's too heavy. CA burns most foams and I've never had good luck with foam safe CA. So that leaves Gorilla glue or hot glue gun. And glue gun is a heavy glue too and doesn't allow for a super tight bond, it's more of a quick fix. Gorilla glue bonds very well to the Radjet foam. It also fills in all the imperfections. Like Kurt said, apply the glue, join the pieces together, then use a masking tape over the entire seem. This will help keep the pieces together while it dries and as the gorilla glue expands it will keep it tight with the seem or joint.
Australia, VIC, Melbourne
Joined Nov 2006
My two Radjets have been dormant for quite a while now... awaiting the motor system upgrades....
The first one is ready to test fly now. I cut a much longer hatch, and joined it to the stock hatch. That way I have full access to the battery area - seeing large batteries need to go well rearwards and are quite long batteries too. (4S 1800mAH 35C Nano) I put on a slide-catch mechanism, to lock down the hatch and assure it can never come off. The front end has a tongue that feeds into the nose area foam. The Turnigy Deluxe 40A ESC sits in the rear end lower fuselage half, and gets clamped down snugly by a plwood strip that runs forwards from the motor mount, to where the fuselage top remains. I will make up a 'plastic upper half', like the fuselage shape, to cover the ESC area - but it will also airflow thorugh that area, over the ESC. But for test flights it will remain open as it is now. I will probably test 3S first.... I haven't done any Amp/Power tests yet. So I will do that before the weekend, to make sure it all 'adds up' to be workable. This Radjet uses the Turnigy 2826/6-2200kv motor. The other one has the Turnigy 2836-2350kv motor. ...
I made the rear deck removable so I can change motors et al.
Used the original motormount, but instead of glueing it to the fuselage it is clamped in position by the original foam pieces, and kept in place by 2 screws and some pieces of wood. (pieces cutoff from big paint stir sticks) The wood is rounded (curved) on the edges, so as to follow the concave fuselage form. ![]() ![]() And in honor of the topic title, I changed the decals a bit... ![]() ![]() ![]() tata! |
Joined Nov 2006
Gee, you could test things all day... all week.... the many combinations!!
I did my first tests..... Turnigy 2826/6-2200kv APC 5 x 5 (reverse) Prop (just because that was all they had in stock then) Interesting results: 4S 1300mAH 45c Nano 25 Amps 350W AUW 495g Thrust 600g 1.21 : 1 Motor Temp 50degC areas 4S 1800mAH 35c Nano 24 Amps 320W AUW 545g Thrust 670g 1.23 : 1 - Huh? Less Watts but more thrust? I rechecked them twice. I don't know why this occured..... 3S 2200mAH 40C Turnigy 20 Amps 225W AUW 545g Thrust 510g 0.94 : 1 3S 1300mAH 25C Nano 18 Amps 195W AUW 460g Thrust 495g 1.08 : 1 All were pretty good results, versus the stock Radjet (I think?). The 4S have more thrust of course, but the motor gets a lot hotter too! That will be OK if you use it at 80% mainly, and then have fun at WOT for short periods. It really need more props to test. Probably 5 x 4.5 (diam/pitch) for a start. If you really wanted to work out optimals. I liked the 3S 1300mAH 25c Nano results, as a good 'sport' power result. Above that, either 4S battery was much the same - just more flight time, but heavier, for the 1800mAH of course. I will test fly them all soon....... I am not sure what props I have (a lot of various types), so I will see what I have, and when to test those..... |
good stuff!
Peter - how are you testing for A/W/thrust? Any change of trying out a 6x4? I'll be doing some tests as well with a wattmeter on the twin,but last time I checked my 2826-6 2200kV (before killing my RJ #1 ) I seem to remember 4S being somewhere around 35A. I only flew it once on 4S, motor made popping noises occasionally and came down VERY hot, but man did she scream!Nice job Martin! What kind of tape is that on your RJ? Some kind of rip-stop tape? |
Cant remember who suggested it ( i think Kurt ) but about 3 mins into this video is my Radjet 800 with the 2200kv http://www.hobbyking.com/hobbyking/s...dProduct=12919 Best idea ever, Thank you.... |
Cool video, sure was moving fast! Was that 3 or 4 cells, what size prop,esc,and battery? |
I was thinking about picking up the Radjet, and wanted to upgrade the motor. I have read good things about 2826 and the 2836. Just didn't know which one to go with. I think I might just go with the 2836 since it's rated up to 4cells and knowing after a few flights I will probably want to go even faster. Just wish Hobby King shipping was cheaper. Is there some here in the US you can get an equivalent motor as the 2836?
Switzerland
Joined Sep 2008
Just need to crash the plane equipped with the 2826
| Thread Tools | |
| Discussion Habu 32 speed contest * Tam Jets Top Gun 173.3* Stock leader Skylineflyer 126.6 | keithtsr | Electric Ducted Fan Jet Talk | 1755 | Mar 08, 2013 04:05 PM |
| Discussion RadJet from the KING! | vettster | Foamy EDFs | 0 | Oct 21, 2011 11:33 PM |
| Help! New ViperJet From Hobby King | dviperjet | Electric Ducted Fan Jet Talk | 20 | Sep 30, 2011 07:04 AM |
| For Sale orange rx from hobby king and orange satilite from hobby king | ZEROSKIN76 | Aircraft - General - Radio Equipment (FS/W) | 8 | Mar 15, 2011 01:41 PM |
| Sold orange rx from hobby king and orange satilite from hobby king | ZEROSKIN76 | Aircraft - General - Radio Equipment (FS/W) | 4 | Feb 21, 2011 12:06 PM |
