Old Dec 03, 2011, 03:55 PM
DerkJohn is offline
Find More Posts by DerkJohn
London
Joined Feb 2011
2836 and 4s
I did a couple of fights on the stock setup, and I must say it flies pretty well, especially with an apc 6*5E prop. One thing I cant get sorted is that darn death spin! Happened 4 times in total.
I put in a turnigy 2836 today with a 4s 1800mah 65C Nanotech and a 5.5*4.5E apcprop. With this setup the plane is ballistic! There is no where near enough cooling with the stock motor location though, and I managed to leave a trail of smoke during a vertical climb. Managed to land it ok, but the motor is fried. I have removed all the foam around the motor now, and put a scoop on the top. I will test it tomorrow and upload some pics.
DerkJohn is offline Find More Posts by DerkJohn
Old Dec 03, 2011, 05:50 PM
vettster is online now
Find More Posts by vettster
"Take Off" eh!
vettster's Avatar
Canada, ON, Beeton
Joined Aug 2008
Looking forward to it DJ. Get some vid if you can.
vettster is online now Find More Posts by vettster
Old Dec 04, 2011, 01:55 PM
DerkJohn is offline
London
Joined Feb 2011
Crazy fast with a 2836 2350Kv (2800Kv)
I managed to get a new motor on today and put an air scoop on the top right above the plush 60A esc. All the foam was cut away around the motor for better airflow and the motor was bolted right onto the stock mount.
I removed some foam inside the fuz to make space for my 4s 1800 nano tech. I have it balanced at the front edge of the launch grips. It's still a bit nose heavy as it needs +- 2mm of up elevator, but I dont want to move it too far back because the death spin problem.
I have reinforced the wings with one strip of packing tape top and bottom.
Let me tell you, this thing is nuts! Its much faster than the skyfun on the same set-up. My guess is that it is around 130mph. The only downside is that it has to land a lot faster too, but that's easy enough to get used too.
This is my set-up:
Motor: Turnigy 2836 2350KV (actually 2800KV)
ESC: Plush 60A
Battery: 4cell 1800mah 65c-130c (This battery is the nuts! stays completely cool!)
On a side note, I managed to rewind the motor I burnt out with field windings from an old beetle generator. I spooled it up this evening and it seems great! I'll test it on a plane to see if it performs better than stock as the single strand windings I used are considerably thicker than the multi-strand windings in the stock motor.
Old Dec 04, 2011, 04:33 PM
"Take Off" eh!
vettster's Avatar
Canada, ON, Beeton
Joined Aug 2008
now I REALLY want to see video!!
Do some low fast passes. Start waaay out and go waaay beyond yourself straight and level so we can doppler it. Post the temp,altitude and wind speed and direction in the video.
Trev
Old Dec 05, 2011, 03:15 AM
DerkJohn is offline
London
Joined Feb 2011
Flight vid coming soon
I'll get my little sister to take a video later today. I cant promise that the plane will be in the frame, but at least you will be able to hear it for doppler
Old Dec 05, 2011, 12:20 PM
DerkJohn is offline
London
Joined Feb 2011
Here are some clips from earlier today. I had to edit it to make it shorter as my internet connection leaves a lot to be desired and it would not upload. I also could not zoom as it cuts the sound on the digital camera I was using.
Altitude: 1800m
Temp: 27*C
Wind: 5 km/h in the same direction as the first pass
Radjet on 4s and Turnigy 2836 2350kv (1 min 44 sec)
Old Dec 05, 2011, 12:30 PM
"Take Off" eh!
vettster's Avatar
Canada, ON, Beeton
Joined Aug 2008
very impressive!!! your first pass was 132MPH. Your average after that was 130mPH range.
SWEET!!
Old Dec 05, 2011, 01:24 PM
DerkJohn is offline
London
Joined Feb 2011
Cool! Thanks for dopplering it! What program are you using if I might ask?
Old Dec 05, 2011, 03:50 PM
"Take Off" eh!
vettster's Avatar
Canada, ON, Beeton
Joined Aug 2008
just the RC-Speedo app for my iphone. dont worry. Its very accurate. Ive compared it many times to actual radar guns and Onboard GPS.
Old Dec 06, 2011, 01:04 AM
nogas is offline
Find More Posts by nogas
Because gas is for BBQ's
nogas's Avatar
Australia, QLD, Brisbane
Joined Feb 2011
132 mph for under $80, nice work.
I just ordered one of these with some 3S 1800's, but realised afterwards i might struggle to get the COG right with the stock motor and heavier battery. Will i be able to get it balanced right or should i order some 1300's?
How are you guys fitting 4S packs?
What prop is a good upgrade for the stock motor?
nogas is offline Find More Posts by nogas
Old Dec 06, 2011, 02:04 AM
DerkJohn is offline
London
Joined Feb 2011
A 3s 1800 will work fine.You will have to remove the turtle deck (easy enough with a blade) and widen the fuse further back. The downside is that the airflow through the fuse will be blocked, so an additional vent hole is needed.
For the stock motor, I found an apc6*5e prop and 3s 1300 work great! You still have to remove some foam do get the battery far enough back though.
Have fun!
Old Dec 06, 2011, 09:26 AM
DerkJohn is offline
London
Joined Feb 2011
AAAAAaagh! I have crazy thaoughts running through my mind that involve a Radjet, a turnigy 3648 1400kv motor and 6s 2200 lopo's!
Old Dec 06, 2011, 03:01 PM
nogas is offline
nogas's Avatar
Joined Feb 2011
Have fun!
Thanks, i've got a plastic spoon in the mod parts pile for a vent.
I'll grab me a few spare 6x5E's, whats the stock prop?
haha, 6S is where its at, the HV / low kv combo should run cooler and be more efficient. Let us know how it goes.
Old Dec 13, 2011, 04:38 PM
nogas is offline
nogas's Avatar
Joined Feb 2011
Hey DJ,
To change the motor are you removing the hatch (just behind the turtle deck)???
I have removed the turtle deck (to make room for the 1800 3S) and it was only glued down the sides so quite easy to cut out but i've cut around the edges of the hatch and its still not budging, so i'm thinking it may be glued on the bottom which i cant cut out so not sure how to remove it.
Old Dec 14, 2011, 01:18 AM
WitnessOnly is offline
Find More Posts by WitnessOnly
Cleared for take off...
WitnessOnly's Avatar
Australia, VIC, Melbourne
Joined Jan 2010
Stock + a little
Hi all,
I maidened my Radjet a couple of days ago, and I think it's a really worthwhile little plane. Even in it's stock config.
I must say, it looks good in the sky
I broke my first prop during bench testing and with only 1 spare original I thought I'd better do some watt tests and see where I'm at, stock was then put up against some of the props I had handy...
Stock : 13A @ 146W
TGS 6x4E : 13.1A @ 145W
Generic5x5 : 10.6A @ 120W
JM6x4 : 13.4A @ 150W (also the quietest) Now my std prop.
Dumped the original prop adapter for a prop saver a quick look after 2 landings suggests it did its job well.
I'm looking forward to more flying on this little guy, I'm running the recommended 3S 1300 and its a pleasure to fly at that weight, I'm not in any great hurry to heat this one up, I think it's quite a pleasure to fly just as it it is.
Noted: With the minor JM prop addition.
WO
Oh, and what control horn hole are we using? Cheers.
WitnessOnly is offline Find More Posts by WitnessOnly
Contest Habu 32 Speed Contest Tumbler Unlimited Class 165.2 keithtsr Electric Ducted Fan Jet Talk 2140 May 01, 2016 10:29 PM
Discussion RadJet from the KING! vettster Foamy EDFs 1 Jun 01, 2014 06:00 PM
Help! New ViperJet From Hobby King dviperjet Electric Ducted Fan Jet Talk 20 Sep 30, 2011 07:04 AM
For Sale orange rx from hobby king and orange satilite from hobby king ZEROSKIN76 Aircraft - General - Radio Equipment (FS/W) 8 Mar 15, 2011 01:41 PM
Sold orange rx from hobby king and orange satilite from hobby king ZEROSKIN76 Aircraft - General - Radio Equipment (FS/W) 4 Feb 21, 2011 12:06 PM
