Old Sep 19, 2012, 11:12 AM
nofreee is offline
Find More Posts by nofreee
nofreee's Avatar
United States, CO, Colorado Springs
Joined Jan 2012
Originally Posted by Paramanic View Post
thanks guys yeah the shaft is broken and its hard to get the shaft of :@ lol but if i give it that motor will i need a better esc?
Yes you will.
With a 2836/6 motor, 3s and 6x4 prop you will need at least a 40amp ESC. If you want to run 4s, you will need closer to 60amp.
nofreee is offline Find More Posts by nofreee
Old Sep 19, 2012, 11:20 AM
Paramanic is offline
Find More Posts by Paramanic
Paramanic's Avatar
United Kingdom, Scotland, Motherwell
Joined Dec 2011
http://www.hobbyking.com/hobbyking/s...arehouse_.html
would this be good enough? they said it takes upto 40A and burst upto 50A
or this one
i only got choices from uk warehouse ? if u see anyn better than these two in uk warehouse please tell lol
Paramanic is offline Find More Posts by Paramanic
Old Sep 19, 2012, 12:06 PM
nofreee is offline
nofreee's Avatar
Joined Jan 2012
or this one
Are you going to run 3s or 4s?
Old Sep 19, 2012, 12:08 PM
Paramanic's Avatar
Joined Dec 2011
3s mate
Old Sep 19, 2012, 12:12 PM
nofreee is offline
nofreee's Avatar
Joined Jan 2012
Go with the 45amp ESC, the other wont have enough capacity. I use the 45a on another plane of mine and have no complaints with it.
Old Sep 19, 2012, 12:20 PM
Cid156 is offline
Find More Posts by Cid156
Cid156's Avatar
Switzerland
Joined Sep 2008
I remplaced the shaft of the motor. IT is very easy.
If fact the shaft has two diameters 3 and 2.4. So I was able to use a standard 3mm shaft from a burned emax motor
The shaft is only knock it in the bell, there is no screws.
It is a bit strange that they reduced the diameter ???
Anyway this motor is working very good on my 28" f22 depron. A bit slow but it is ok
Cid156 is offline Find More Posts by Cid156
Old Sep 19, 2012, 12:22 PM
Paramanic's Avatar
Joined Dec 2011
thanks mate and i cant get the brocken shaft out of the motor :O
Old Sep 19, 2012, 12:28 PM
Cid156 is offline
Cid156's Avatar
Switzerland
Joined Sep 2008
I put teh bell on a flat surface with a hole on the middle and with a pin remover and a hammer I hit the opposite side
Old Sep 19, 2012, 12:33 PM
Paramanic's Avatar
Joined Dec 2011
ive tried that not budging lol
Old Sep 19, 2012, 12:43 PM
Paramanic's Avatar
Joined Dec 2011
i got the shaft out WOO!!
Old Sep 19, 2012, 01:19 PM
Paramanic's Avatar
Joined Dec 2011
http://www.ebay.co.uk/itm/Scorpion-H...06%26rk%3D1%26 would this replace the shaft?
Old Sep 19, 2012, 02:07 PM
headlessagain is online now
Find More Posts by headlessagain
Reap the wild wind
headlessagain's Avatar
Bristol,UK
Joined Feb 2007
Have you tried Giant Shark for motor spares, motors and esc's?
http://www.giantshark.co.uk/spare-sh...-p-404875.html
http://www.giantshark.co.uk/shaft-xyh2822-p-404737.html
You are really looking for a 3mm (double check with some of these Vernier Calipers http://www.giantshark.co.uk/digital-...-p-403716.html) shaft with the correct "C" clip groove and grub screw cut outs. It won't matter if it's too long as you can cut off any excess and you can always use a 3mm wheel collet to retain the shaft if you can't find one with a suitable "C" clip groove http://www.giantshark.co.uk/collets-...-p-406788.html
Here is a selection of 40 amp esc's http://www.giantshark.co.uk/40-amp-esc-c-21_91.html
I'm running one of their 2600kv 36 gram motors on 3s in my Parkjet. Have swapped out the esc from this video but not had chance to run her yet.http://www.giantshark.co.uk/a22088-2...-p-405607.html
HobbyKing Parkjet maiden flight (2 min 57 sec)
And here is an earlier video of the same spec motor in my Flycat
Haoye Flycat pusher jet (3 min 40 sec)
Andy
headlessagain is online now Find More Posts by headlessagain
Old Sep 19, 2012, 02:24 PM
Paramanic's Avatar
Joined Dec 2011
thanks and did u fly with or against the wind there?
Old Sep 19, 2012, 02:28 PM
Reap the wild wind
Bristol,UK
Joined Feb 2007
Launched against the wind as usual but passes were a combination of with, against, cross wind etc.
Andy
Old Sep 19, 2012, 03:58 PM
Cid156 is offline
Cid156's Avatar
Switzerland
Joined Sep 2008
BTW do you know a good place for buying exotic prop like a 5.5x5.5 ? Something worldwine?
Contest Habu 32 Speed Contest Tumbler Unlimited Class 165.2 keithtsr Electric Ducted Fan Jet Talk 2140 May 01, 2016 10:29 PM
Discussion RadJet from the KING! vettster Foamy EDFs 1 Jun 01, 2014 06:00 PM
Help! New ViperJet From Hobby King dviperjet Electric Ducted Fan Jet Talk 20 Sep 30, 2011 07:04 AM
For Sale orange rx from hobby king and orange satilite from hobby king ZEROSKIN76 Aircraft - General - Radio Equipment (FS/W) 8 Mar 15, 2011 01:41 PM
Sold orange rx from hobby king and orange satilite from hobby king ZEROSKIN76 Aircraft - General - Radio Equipment (FS/W) 4 Feb 21, 2011 12:06 PM
