Old Sep 10, 2012, 05:58 PM
Kurt is offline
Find More Posts by Kurt
Upstanding Member
Kurt's Avatar
United States, TX, Houston
Joined Sep 2003
frog - I see you've trimmed off the wing-tip "tanks".
Both mine have snapped off and been re-glued, but I'm thinking about doing like you. No difference in flight I assume?
After 20+ flights and landings my stock prop finally broke (bent 90degrees about 1/3 way from the tip actually) when she skidded around on a landing, backwards into a rock.
Great, get to try out the APC 5.5x5.5 pusher!
Flight went well, then on the 1st landing (not even a harsh one) one of the blades breaks off. Brittle little suckers!
Kurt is offline Find More Posts by Kurt
Old Sep 11, 2012, 03:42 AM
frogforce is offline
Find More Posts by frogforce
Australia, QLD, Rubyanna
Joined Aug 2012
Tip tanks
Both tanks wing tip were reglued several times, so this is following earlier advise from this forum, I forget who but they recon speed improved and no ill effects stability. Still repairing and hot roding, will post results of flights when its finished.
My dissovleable stitches came out today, 5 weeks after op on shoulder, I'll be out in the feild flying this week.
frogforce is offline Find More Posts by frogforce
Old Sep 11, 2012, 03:02 PM
Cid156 is online now
Find More Posts by Cid156
Cid156's Avatar
Switzerland
Joined Sep 2008
Put the motor of my radjet on my 28" F22 depron... I am very happy that I did not put it on my radjet... it is slow.....
What will be the best motor in 3S?
I have already a 2826 2200kv, the speed is good but I need more
Cid156 is online now Find More Posts by Cid156
Old Sep 11, 2012, 03:05 PM
medroller is offline
Find More Posts by medroller
Australia, QLD, Townsville
Joined Jul 2011
Went out for a couple of flights yesterday. on the second flight I put my nanotech 1300 4s in . Coming past in a high speed run , a trail of smoke was leaving the tail . Another motor burnt up. Although ,the smoke did look good.
medroller is offline Find More Posts by medroller
Old Sep 11, 2012, 07:37 PM
Joined Aug 2012
cid156, I run a turnigy 2836 3200kv on my ultra funjet on 3s with a 4.7x4.7 prop. It draws 55-58 amps and 550watts, it is rated to 5s in a edf 70mm. Surprised me in speed for 3s. Also ran a himax b2825 3600kv might be 10kph faster same prop. I ran this 2815 2000kv in a trainer an kept folding wings at high speed, should be great on 4s.
Old Sep 12, 2012, 08:23 AM
Simon1013 is offline
Find More Posts by Simon1013
Joined Aug 2012
Has anybody carried out any airframe mods to increase speed?
I was thinking along the lines of thining the wings, reducing the span, reducing fin area, improving surface finish, 'extreme' streamlining? I know tip tanks were an obvious improvement...but what else could be done?
Although you may probably end up with something that looks more like a sidewinder missile than an aircraft, I just wonder how fast one of these could be made to go. Right now, with aircraft out there pushing 1.5KW, there is probably little more that can be done in terms of power?
Simon1013 is offline Find More Posts by Simon1013
Old Sep 12, 2012, 08:31 AM
Kurt is offline
Upstanding Member
Kurt's Avatar
Joined Sep 2003
2826-2200kv motors back in stock at HK
http://www.hobbyking.com/hobbyking/s...dProduct=12919
Old Sep 12, 2012, 09:02 AM
Joined Aug 2012
auw 606g
Ready for action again, 4s1800ma65c nano fits easy and still air flow to motor is good. About time I found a home for this himax motor, first time on 4s, 5x5apc. Up it goes, either flys or not, my guess is heaps faster then stock.
Old Sep 12, 2012, 09:59 AM
Kurt is offline
Upstanding Member
Kurt's Avatar
Joined Sep 2003
she looks ready to rock!
did you enlarge the ailerons? Wanted more roll or more elevator?
Old Sep 13, 2012, 12:49 AM
harlyquin76 is offline
Find More Posts by harlyquin76
harlyquin76's Avatar
Australia, TAS, Claremont
Joined Jul 2012
Just ordered one of these motors, can anyone please let me know of a good way to remove the standard motor.
harlyquin76 is offline Find More Posts by harlyquin76
Old Sep 13, 2012, 07:57 AM
Kurt is offline
Upstanding Member
Kurt's Avatar
Joined Sep 2003
Harly - after removing the the foam cap on top of the motor (took some careful working with an exacto and longer razor blade) it took more careful cutting and prying to get the stock motor& motor mount out. Even then the lower foam piece rear of the the mount tore away from the rest of the fuse (the mount channel is deep and there isn't much foam underneath it).
After swapping the 2826 motor I used hot glue to fix the mount back into the foam, reattached the lower foam "shroud" and put a few strips of CF on the belly to strengthen the structure, and glued the top cap back on. So mine is a pretty permanent installation - don't want to think of having to take the motor out again... luckily she barely gets warm after 5 minutes flying with a 1.3A 3S Nano-tech 45-90C. I don't push my luck with a 4S after the one time....
Maybe you can undo the motor bolts with the mount still sitting in the lower "frame", with a long phillips screwdriver? Anyone?
Would save some hacking/repairing to leave the mount in place.
Old Sep 13, 2012, 11:05 AM
nofreee is offline
Find More Posts by nofreee
nofreee's Avatar
United States, CO, Colorado Springs
Joined Jan 2012
Got my Radjet in the air last night after converting to a Turnigy 2836-2350kv motor. On 3s 2200 35c and an APC 6x5.5 it was doppler'd around 90mph flat and level. I only have a 35amp Castle ESC in there right now, so I cant run 4s (watt meter was showing about 380watts@36amps), but I was very happy with the performance on 3s.
Motor came down fairly warm, but within reasonable limits. Flew around for about 5 minutes doing 6-8 second WoT bursts and the batts had 3.8v per cell when I came down. Very pleased with the setup.
nofreee is offline Find More Posts by nofreee
Old Sep 13, 2012, 11:17 AM
nofreee is offline
nofreee's Avatar
Joined Jan 2012
I was able to install my 2836 without removing the motor mount. I used a very skinny phillips head screwdriver out of a eyeglass repair kit. Bottom screws were a little tricky, but nothing major.
Old Sep 13, 2012, 03:26 PM
Joined Jul 2012
cool thanks guys, ill give it a go when the new motor tuns up.
Old Sep 15, 2012, 06:36 AM
Joined Jul 2012
Wing wing and Radjet 800 (3 min 27 sec)
small video with my Radjet 800 and a hobbyking Wing wing.
Contest Habu 32 Speed Contest Tumbler Unlimited Class 165.2 keithtsr Electric Ducted Fan Jet Talk 2140 May 01, 2016 10:29 PM
Discussion RadJet from the KING! vettster Foamy EDFs 1 Jun 01, 2014 06:00 PM
Help! New ViperJet From Hobby King dviperjet Electric Ducted Fan Jet Talk 20 Sep 30, 2011 07:04 AM
For Sale orange rx from hobby king and orange satilite from hobby king ZEROSKIN76 Aircraft - General - Radio Equipment (FS/W) 8 Mar 15, 2011 01:41 PM
Sold orange rx from hobby king and orange satilite from hobby king ZEROSKIN76 Aircraft - General - Radio Equipment (FS/W) 4 Feb 21, 2011 12:06 PM
