Old Aug 06, 2012, 09:15 AM
Gohmer is offline
Find More Posts by Gohmer
Owatonna MN 55060
Joined Sep 2005
Originally Posted by Cid156 View Post
Hi,
I received my radjet yesterday.
How do you fix the omega profil? (see picture)
I don't want to glue it as I want to remove the upper part of the fuselage.
I was thinking of using magnets.
What are the sticker of the opposite side of the fuselage? It is for removeing the omega profil with a rod
For the first fly, how much elevons mouvement should I put?
I didn't do anything with "omega profil", not sure what it is.
I use clear packing tape to secure the upper fuse pieces.
I use 1/4" up and down (60% expo) - 5/16" left and right (70% epo) for elevon movement. Probably too much elevator expo.
10% left and right rudder to aileron mix.
Gohmer is offline Find More Posts by Gohmer
Old Aug 06, 2012, 09:25 AM
nickelbn1 is offline
Find More Posts by nickelbn1
fly and then fly some more!
nickelbn1's Avatar
Springdale, AR
Joined Dec 2006
I have never had an issue with launches up till that one. I had just made some adjustments and i dont think i gave it enough power before i threw it. Dont know if i want to spend another $20 on this plane since i continue having issues flying it.
nickelbn1 is offline Find More Posts by nickelbn1
Old Aug 06, 2012, 11:23 AM
3dRCrazy is offline
Find More Posts by 3dRCrazy
Gravity hates me.
3dRCrazy's Avatar
Joined Aug 2011
Just took the pnp version for maiden flight and I love this plane. The only problem I had was that the ESC and Motor got quite hot even with ventilation holes. Should I add a scoop to get more air in it? Also do I need a separate ventilation hole directly above the motor?
3dRCrazy is offline Find More Posts by 3dRCrazy
Old Aug 06, 2012, 02:27 PM
nickelbn1's Avatar
Springdale, AR
Joined Dec 2006
I cut a vent hole in the top just before the esc and cut off the foam the sticks out from the main body around the motor. Helped a lot.
Old Aug 08, 2012, 10:54 AM
boiko is offline
Find More Posts by boiko
Home of A-10 - Farmingdale NY
boiko's Avatar
United States, NH, Londonderry
Joined Dec 2006
Originally Posted by The_RattleSnake View Post
Run a Turnigy 2836 2350kv on 4s and he wont call it a sadjet
What kind of speed/MPH are you getting out of a 2836/2350kv....and with what prop?
-mike-
boiko is offline Find More Posts by boiko
Old Aug 08, 2012, 11:46 AM
boiko is offline
boiko's Avatar
Joined Dec 2006
2836/2350kv on 4S looks like a great combo for the Radjet 800...
-mike-
Old Aug 08, 2012, 02:45 PM
tracknoob is offline
Find More Posts by tracknoob
Diverted by planks
tracknoob's Avatar
South Florida
Joined Dec 2010
Well, guys -- think I'll be checking out of this thread -- have so many different threads I try to follow, and my poor little RadJet finally bit the dust once too many times: earlier this week I had it out, trimmed great, running fine, flying inverted right in front of me at about 20 feet out, doing a R-to-L pass.... and it just.... exploded! It was the coolest thing ever! I think what happened is that the right wing was still sporting the original adhesive, and I must have used superglue instead of UHUpor, Welders, or epoxy, and it just cracked under the final stress - I am sure it was weakened from prior impacts.
Was not pulling a lot of Gs or anything at the time, worst force was maybe a bit of a cross wind gust got under it, but somehow it just lost that wing, then spun, slinging the ESC, battery, canopy and anything else loose, then it all fluttered to the ground. It was pretty cool to see!
So, while I could probably rebuild it, I figured the poor thing deserves to rest in peace at this point, so I gratefully thanked it for helping me learn to fly a 'wing', and on my way home, stopped by the LHS and promptly picked up a Stryker F27Q!
Thanks to all who contributed with info on this thread that helped me out -- in the end, the RadJet is a great little bang-for-the-buck airplane!
If you ever want to hit me up for comments, info or anything, just PM me or track me down on one of the other threads.
tracknoob is offline Find More Posts by tracknoob
Old Aug 08, 2012, 04:22 PM
setxws6 is online now
Find More Posts by setxws6
Hemi pilot
setxws6's Avatar
USA, TX, Lumberton
Joined Oct 2005
Sorry about the loss but I guess it was it's time to go, it sounds like it committed suicide lol...
setxws6 is online now Find More Posts by setxws6
Old Aug 09, 2012, 06:35 PM
PeterVRC is online now
Find More Posts by PeterVRC
Australia, VIC, Melbourne
Joined Nov 2006
I picked one of mine up one day, after a flight, and noted one wing was 'loose'. I use epoxy and wooden skewers (2 per side here) for extra strength, but the epoxy join had cracked. It was just wobbly, but another flight or two and it would not have been a good result!!
I pulled it apart, re-epoxied it, and it has been fine since.
I guess model planes should need reasonably detailed checks done often enough - when you get home each flying day(??), or even between flights really. That is if you want to be sure the next flight will be successful.
But some of these smaller planes are too much fun to 'waste' (LOL) time between the next flight! So I just change the battery, do a quick controls check and off it goes again!
PeterVRC is online now Find More Posts by PeterVRC
Old Aug 09, 2012, 11:04 PM
dahawk47 is offline
Find More Posts by dahawk47
Augermeister
dahawk47's Avatar
United States, TX, Keller
Joined Jul 2011
Track,
I know what you mean. Mine has had more facelifts than Joan Rivers. Only so much packing tape can do to hold her together. Looking pretty ratty. I got mine at the intro price of $39.00 No downside there. A lot of fun on the cheap. It was my first real entry into anything resembling speed. Haven't flown it in months. Too many other new challenges. The JPowers funfighter series is a hoot. The little Rare Bear will do 100.
Thanks for helping and supporting the rest of us here. !
Salutations,
Hawk
dahawk47 is offline Find More Posts by dahawk47
Old Aug 10, 2012, 07:19 AM
SixDeuces is offline
Find More Posts by SixDeuces
Lawn Dart Specialist
SixDeuces's Avatar
United States, PA, Williamsport
Joined Jun 2006
Mine just arrived in the mail yesterday. Gotta start assembly asap. I love the Engrish instructions... especially the radio instructions that show you how to move the "joystike" and how the helicopter will respond. And this while showing images of the wrong airplane.
SixDeuces is offline Find More Posts by SixDeuces
Old Aug 10, 2012, 09:42 AM
nickelbn1's Avatar
Springdale, AR
Joined Dec 2006
My wings kept coming loose too until i realized the foam is super slick and the glue just couldnt bond well enough. Had to sandpaper it to roughen it up but was fine after that.
Old Aug 10, 2012, 11:26 AM
Cid156 is online now
Find More Posts by Cid156
Switzerland
Joined Sep 2008
I am really surprised with the size of the motor. It is really tiny, I did not test it yet but I am wondering if I can go fast with that. The shaft is only 2.3mm?!?
Cid156 is online now Find More Posts by Cid156
Old Aug 10, 2012, 01:00 PM
Hemi pilot
setxws6's Avatar
USA, TX, Lumberton
Joined Oct 2005
The stock motor is tiny and the shaft can bend easy if the prop hits just right when landing. I was getting around 140-160 watts with the stock motor/esc setup. It was enough to zip around, but not super fast and the vertical was not unlimited. If you can double the watts with another motor/esc combo, the radjet becomes really fun.
Old Aug 10, 2012, 01:04 PM
Hemi pilot
setxws6's Avatar
USA, TX, Lumberton
Joined Oct 2005
My wings were coming loose sometime in the first dozen flights I made on it. Mine was built by a previous owner but he never flew it, so I'm not sure what glue he used. So I sandpapered them and used white gorilla glue, haven't had a problem since.
Contest Habu 32 Speed Contest Tumbler Unlimited Class 165.2 keithtsr Electric Ducted Fan Jet Talk 2136 Oct 11, 2015 09:42 PM
Discussion RadJet from the KING! vettster Foamy EDFs 1 Jun 01, 2014 06:00 PM
Help! New ViperJet From Hobby King dviperjet Electric Ducted Fan Jet Talk 20 Sep 30, 2011 07:04 AM
For Sale orange rx from hobby king and orange satilite from hobby king ZEROSKIN76 Aircraft - General - Radio Equipment (FS/W) 8 Mar 15, 2011 01:41 PM
Sold orange rx from hobby king and orange satilite from hobby king ZEROSKIN76 Aircraft - General - Radio Equipment (FS/W) 4 Feb 21, 2011 12:06 PM
