Old Aug 01, 2012, 04:14 PM
Gohmer is offline
Find More Posts by Gohmer
Owatonna MN 55060
Joined Sep 2005
One of these on a 10mm stick glued to the inside bottom of the fuse should work http://www.horizonhobby.com/products...mount-EFLM1915
That might be too low KV and too much weight to work well in the RadJet. Try it with the stock motor on 4s first.
Gohmer is offline Find More Posts by Gohmer
Old Aug 03, 2012, 12:09 PM
3dRCrazy is offline
Find More Posts by 3dRCrazy
Gravity hates me.
3dRCrazy's Avatar
Joined Aug 2011
Is the correct CG in the middle of the two circles on the underside of the wing?
3dRCrazy is offline Find More Posts by 3dRCrazy
Old Aug 03, 2012, 01:00 PM
Gohmer is offline
Owatonna MN 55060
Joined Sep 2005
That might be too far back, depending on who put the decals on it.
Mine balance just behind the front edge of the finger hold notch.
Old Aug 04, 2012, 09:43 AM
Cid156 is online now
Find More Posts by Cid156
Switzerland
Joined Sep 2008
Hi,
I received my radjet yesterday.
How do you fix the omega profil? (see picture)
I don't want to glue it as I want to remove the upper part of the fuselage.
I was thinking of using magnets.
What are the sticker of the opposite side of the fuselage? It is for removeing the omega profil with a rod
For the first fly, how much elevons mouvement should I put?
Cid156 is online now Find More Posts by Cid156
Old Aug 04, 2012, 12:39 PM
boiko is offline
Find More Posts by boiko
Home of A-10 - Farmingdale NY
boiko's Avatar
United States, NH, Londonderry
Joined Dec 2006
I have to ask after reading through this thread....what kind of speed increase do you get when you upgrade to a say 4S 1300...from a 3S....and can that be significantly increased by the removal of the wing tanks?
-mike
boiko is offline Find More Posts by boiko
Old Aug 04, 2012, 05:59 PM
setxws6 is offline
Find More Posts by setxws6
Hemi pilot
setxws6's Avatar
USA, TX, Lumberton
Joined Oct 2005
I noticed a small increase in overall speed when I cut my wing tip tanks off. I really noticed extra performance on verticals and decel, it doesn't slow down as fast when cutting the thottle back. Best part about cutting the tanks off is when landing, they don't catch the grass and cause a ground loop.
setxws6 is offline Find More Posts by setxws6
Old Aug 04, 2012, 06:02 PM
setxws6 is offline
Hemi pilot
setxws6's Avatar
USA, TX, Lumberton
Joined Oct 2005
Not sure what you mean by your first questions, but as far as rates go...watch out with how much roll rate you put in. It rolls very fast and aggresive, so start out small and increase as you go with rates. Pitch isn't as sensitive.
Old Aug 04, 2012, 08:47 PM
tracknoob is offline
Find More Posts by tracknoob
Diverted by planks
tracknoob's Avatar
South Florida
Joined Dec 2010
That's why mine had to go in the end -- they just got broken in half too many times by getting caught on landing to get glued back on straight. One second with an Exacto blade, and I was flying lighter and cleaner.
tracknoob is offline Find More Posts by tracknoob
Old Aug 05, 2012, 12:32 PM
johnnyrocco123 is offline
Find More Posts by johnnyrocco123
You down with EPP?
johnnyrocco123's Avatar
Houston, Tx
Joined May 2009
You flown your Funjet Ultra yet?
johnnyrocco123 is offline Find More Posts by johnnyrocco123
Old Aug 05, 2012, 01:51 PM
nickelbn1 is offline
Find More Posts by nickelbn1
fly and then fly some more!
nickelbn1's Avatar
Springdale, AR
Joined Dec 2006
I think I am about to give up on this bird. I have had nothing by problems with this thing since i got it. had crash #5 today. just a mild one of takeoff, but now my motor is making a bad sound and not sure why. I have spent more time working on this thing then flying it. really annoying plane.
nickelbn1 is offline Find More Posts by nickelbn1
Old Aug 05, 2012, 06:45 PM
Revilo88 is offline
Find More Posts by Revilo88
Joined May 2012
Description:
Death Spiral for me today. Wasnt even vertical, just shallow climb and that was that....
Revilo88 is offline Find More Posts by Revilo88
Old Aug 05, 2012, 09:23 PM
nickelbn1's Avatar
Springdale, AR
Joined Dec 2006
ok just found out my turnigy 2836 motor lost the bearing inside of it on the crash I had today. I highly doubt I can find it. any way of getting a new bearing for this motor????
Old Aug 06, 2012, 12:20 AM
setxws6 is offline
Hemi pilot
setxws6's Avatar
USA, TX, Lumberton
Joined Oct 2005
No! Unfortunately. Ive been procrastinating on getting it finished. All i have to do is glue the vert stabs on, hook up the pushrods to the horns and throw some stickers on, and thats about it! I really need to finish it. Im off work the rest of the week, time to get r done...
Old Aug 06, 2012, 12:26 AM
setxws6 is offline
Hemi pilot
setxws6's Avatar
USA, TX, Lumberton
Joined Oct 2005
Thats crazy because ive had nothing but a blast with mine. The stock motor is junk because the shaft bends so easy. Im flying with a dons wicked 3000kv and 40A esc with 3s 1300 and its just right. Cruise around 80mph and dives around 100mph and still weighs close to stock weight, so lands easy. Cheap stock servos, pushrods and horns are still rockin too! Its been the best bang for the buck ive had in a long time!
Old Aug 06, 2012, 09:54 AM
Gohmer is offline
Owatonna MN 55060
Joined Sep 2005
http://www.headsuprc.com/servlet/the...NGS/Categories
Not listed by model. They might know if you email them, or just measure your old ones. Not worth the bother for a cheap motor, just replace it.
Sorry about your troubles with this airplane. Some up trim (on the flap switch) and some aileron on the left stick helps me with launches.
Contest Habu 32 Speed Contest Tumbler Unlimited Class 165.2 keithtsr Electric Ducted Fan Jet Talk 2136 Oct 11, 2015 10:42 PM
Discussion RadJet from the KING! vettster Foamy EDFs 1 Jun 01, 2014 07:00 PM
Help! New ViperJet From Hobby King dviperjet Electric Ducted Fan Jet Talk 20 Sep 30, 2011 08:04 AM
For Sale orange rx from hobby king and orange satilite from hobby king ZEROSKIN76 Aircraft - General - Radio Equipment (FS/W) 8 Mar 15, 2011 02:41 PM
Sold orange rx from hobby king and orange satilite from hobby king ZEROSKIN76 Aircraft - General - Radio Equipment (FS/W) 4 Feb 21, 2011 01:06 PM
