Old Feb 16, 2012, 08:51 PM
graeme_robinson is offline
Find More Posts by graeme_robinson
Australia, New South Wales, Sydney
Joined Jan 2011
Originally Posted by graeme_robinson View Post
flew the 4S this morning - they are good though not massively faster than 3S - definitely more power on tap to pull up. Anway, experimenting with my flaperons after the second battery died I got into trouble & did a nose landing. Not pretty - however I think I can do my gyprock tape and epoxy thing to rebuild the front end, though the skids crumpled up and I had to cut it off halfway up the fuse. The rest of the body seems fine. I have some video and will post if I can swallow my pride enough to edit & post.
Radjet patched up and in the air again. Video of the crash and repair here with post repair flight footage.
graeme_robinson is offline Find More Posts by graeme_robinson
Old Feb 16, 2012, 10:07 PM
nickelbn1 is offline
Find More Posts by nickelbn1
fly and then fly some more!
nickelbn1's Avatar
Springdale, AR
Joined Dec 2006
Originally Posted by nogas View Post
Heres a few pics.
I cut a section of the turtle deck out to keep the esc up high to allow heavier packs to go back underneath it (when i run 4S). The esc will be nice and cool up there too.
With the pack in this position, the COG is right on the point recommended in the manual. However i believe it flys better 10 - 15mm further back.
You can see where i've dremelled the fuse to take the pack. You'd have to go a bit lower (and / or higher???) to fit the 4S
I'm still working on the best method to attach the esc and lipo.
Hoping to get it finished this weekend for a maiden before i go back to work.
is the battery in this picture a 3 cell or 4 cell? what c rating is it?
nickelbn1 is offline Find More Posts by nickelbn1
Old Feb 17, 2012, 12:18 AM
Airdog67 is offline
Find More Posts by Airdog67
Airdog67's Avatar
Joined Mar 2011
Well done on the rebuild, I'll have to keep that repair in mind for the future.
Airdog67 is offline Find More Posts by Airdog67
Old Feb 17, 2012, 09:00 AM
nickelbn1's Avatar
Springdale, AR
Joined Dec 2006
I ordered last night a 1800mah 40c 3 cell and a 1800mah 30c 4 cell to use in my radjet. Skylipos. According to measurements, those should fit the easiest. I like how sky lipos are very hard and flat and dont puff out.
Old Feb 18, 2012, 10:05 PM
The_RattleSnake is offline
Find More Posts by The_RattleSnake
The_RattleSnake's Avatar
Joined Jul 2007
Got to do a maiden speed run this morning!
My setup is:
Turnigy 2836 2350kv
Nanotec 4s 1000mah 45-90c
Turnigy Superbrain 60 amp
Apc 5x5
Max rpm : 29k
Max amp: 44amps
Originally Posted by vettster View Post
Thats the exact same set up im going to use.
Good luck with the maiden. and remember to get Video
Yes I did get the speed run video, from 2 cameras! I just need to edit it all.
I got 117mph (188Kph) !
The speed runs look awsome on camera.
I didnt muck around with 3s, went straight to 4s so I have no idea how fast
it is on 3s.
Now what Im going to do is try different props to see if I can break the 200kph
barrier!
The_RattleSnake is offline Find More Posts by The_RattleSnake
Old Feb 19, 2012, 12:46 AM
Joined Jan 2011
Originally Posted by The_RattleSnake View Post
My setup is:
Turnigy 2836 2350kv
thats impressive for such a small 4S battery, but then the motor is very strong - I've got one in a parkjet. Look forward to seeing the video.
I also had a couple very nice Radjet flights this morning in near perfect conditions. Finding it very steady and easy to keep level in passes. I suspect that's to do with the heavier battery I'm using which is actually counterbalanced with some lead weight at the end of the fuse. I like my jets a bit heavy rather than a bit light, though of course that impacts on top speed. If the Rad survives till it burns out the standard motor I will be upgrading the to the Turnigy you are using I think.
Old Feb 21, 2012, 03:22 PM
Joined Jul 2007
Here you go :P
HK Radjet 800, Unboxing, 4s Setup and Flights (8 min 53 sec)
Old Feb 21, 2012, 11:57 PM
Joined Jan 2011
Here you go :P
Thanks for posting that Rattlesnake - nice vid. I won't be putting that motor in my Radjet any time soon though! I was wrong about having one in my parkjet - I've got a 2432 in that - but I have the 2836 in my larger Flyjet and Skyfuns and it turns those planes into rockets so I can't imagine being able to cope with that motor in the smaller radjet.
I did some passes this morning on my 4S Ratj... , er Radjet, and dopplered the video with the Android app rcspeedo, a fun little app and at 4 bux a bit cheaper than the onboard speedo or radar gun. Its pushing out over 80mph on the 4S and standard motor which is pretty decent I think and certainly fast enough for me. The motor seems to be coping just fine with 4S too, no sign over overheating. If I kill it I plan to install a Turnigy 2432 but maybe that won't be needed. The video shows just this mornings runs but I dopplered my earlier videos too and got a highest reading of 83mph. Here it is:
Radjet morning passes.
Old Feb 22, 2012, 02:00 AM
Joined Jul 2007
Thanks for posting that Rattlesnake - I can't imagine being able to cope with that motor in the smaller radjet.
From my experiance, its alot easyer to fly a plane at those speeds than
it is to watch someone fly at those speeds, because you know where it
it going next. Someone watching has to wait for the plane to change course
and then try to follow it.
Its not as hard you think!
The hxt900 servos seemed to handle it fine and I have more faith in the Orange RX's than I do the genuine Spektrum ones. O_o
Old Feb 22, 2012, 08:59 AM
nickelbn1's Avatar
Springdale, AR
Joined Dec 2006
Has anyone had problems with their four cell battery getting too warm due to lack of airflow? Or are those bottom two air vent holes sufficient?
Old Feb 22, 2012, 12:21 PM
vettster is offline
Find More Posts by vettster
"Take Off" eh!
vettster's Avatar
Canada, ON, Beeton
Joined Aug 2008
with the stock motor its fine. Your just not drawing enough amps to worry about it. My battery came out cold each time after 5 flights
vettster is offline Find More Posts by vettster
Old Feb 22, 2012, 01:56 PM
nickelbn1's Avatar
Springdale, AR
Joined Dec 2006
I will be using the turnigy 2836 motor with a 1800mah 4 cell
Old Feb 22, 2012, 02:14 PM
vettster is offline
"Take Off" eh!
vettster's Avatar
Canada, ON, Beeton
Joined Aug 2008
Me too.. I havnt installed it yet..but in this case you will want to add cooling vents. I intend too.
Old Feb 22, 2012, 02:40 PM
nickelbn1's Avatar
Springdale, AR
Joined Dec 2006
Well the only way I could see to add cooling vents in front of the battery, would be to cut some slits in the canopy to allow air through the canopy area. Think that would work? Kind of like the stryker q canopy.
Old Feb 22, 2012, 02:53 PM
Airdog67 is offline
Airdog67's Avatar
Joined Mar 2011
If anybody has an extra 2836 they want to sell shoot me a pm, thanks.
Contest Habu 32 Speed Contest Tumbler Unlimited Class 165.2 keithtsr Electric Ducted Fan Jet Talk 2140 May 01, 2016 10:29 PM
Discussion RadJet from the KING! vettster Foamy EDFs 1 Jun 01, 2014 06:00 PM
Help! New ViperJet From Hobby King dviperjet Electric Ducted Fan Jet Talk 20 Sep 30, 2011 07:04 AM
For Sale orange rx from hobby king and orange satilite from hobby king ZEROSKIN76 Aircraft - General - Radio Equipment (FS/W) 8 Mar 15, 2011 01:41 PM
Sold orange rx from hobby king and orange satilite from hobby king ZEROSKIN76 Aircraft - General - Radio Equipment (FS/W) 4 Feb 21, 2011 12:06 PM
