Old Jan 16, 2012, 01:51 PM
dahawk47 is online now
Find More Posts by dahawk47
Augermeister
dahawk47's Avatar
United States, TX, Keller
Joined Jul 2011
Looking to maiden the Radjet this weekend, Would have done it Saturday but the black wire on my XT60 to EC3 adaptor came apart. Impressed on the quality you get for ~USD $35.00. Have the stock version. Anything I need to know ? Will start with a 3 cell 1300mah. More concerned about stability than speed at this point.
dahawk47 is online now Find More Posts by dahawk47
Old Jan 16, 2012, 02:32 PM
Oyvind M. is offline
Find More Posts by Oyvind M.
Joined Jan 2012
just remember to get the battery far enough in front. i used 1300 3s on stock, and i had the battery just peeking out into the cockpit. a little front heavy rather than opposite. deathspins are suppose to be a hassle. though it glides very well, and i think its capable of a nice big engine to power it
Oyvind M. is offline Find More Posts by Oyvind M.
Old Jan 16, 2012, 02:49 PM
vettster is offline
Find More Posts by vettster
"Take Off" eh!
vettster's Avatar
Canada, ON, Beeton
Joined Aug 2008
Originally Posted by Oyvind M. View Post
ive flown some flights on my radjet. it weighs 394 grams w/o battery. ive used a 6x56 carbon rod through the wings.
setup is:
turnigy 2836-2350 (2800kv)
4s 1600mah 30c batteries.
turnigy plush 60amp
dont have a watt meter so havent emasured watts.
but i used the rc speedo on my phone, and it was from 170-175 km/h using a APC 6x4E pusher prop
I have the exact same setup coming in the mail
Remember to set the CG at least 15mm rearward of the stock location. Do this and it will fly very good. Others have gone as far as 20mm. Ill be doing that too on my next flight.
vettster is offline Find More Posts by vettster
Old Jan 16, 2012, 04:03 PM
Airdog67 is offline
Find More Posts by Airdog67
Airdog67's Avatar
Joined Mar 2011
Mine is on its way. I too will start off stock. Has anybody done radar or doppler on the stock set up.
Airdog67 is offline Find More Posts by Airdog67
Old Jan 16, 2012, 04:12 PM
vettster is offline
"Take Off" eh!
vettster's Avatar
Canada, ON, Beeton
Joined Aug 2008
I didnt doppler it on 3s but your only going to get about 70-80kph out it. 4s is much better. Check out my vid on page 3
Old Jan 16, 2012, 05:17 PM
Airdog67 is offline
Airdog67's Avatar
Joined Mar 2011
thanks vettster: so how is the stock motor holding up, or did it burn up
Old Jan 16, 2012, 05:24 PM
vettster is offline
"Take Off" eh!
vettster's Avatar
Canada, ON, Beeton
Joined Aug 2008
only had about 5 flights before winter hit. But with only a 17amp draw.. I dont think its going to die anytime soon
Old Jan 16, 2012, 05:48 PM
Airdog67 is offline
Airdog67's Avatar
Joined Mar 2011
vettster: I forgot to ask what prop r u running.
Old Jan 16, 2012, 05:50 PM
rcFoamFighters is offline
Find More Posts by rcFoamFighters
Joined Jan 2009
RadJet power upgrade and other mods
HobbyKing RadJet Peformance Mods and test flight (10 min 59 sec)
This is a video of my HobbyKing RadJet 800 with a performance power system upgrade and some other mods done to make servicing the plane easier. The power system and mods are all covered at the end of the video.
2826-6 2200kv brushless outrunner
H-King 50A brushless esc
Rhino 1350mAh 30c 3s1p liPo
APC 6x4 sport prop
E-Flite removable stick mount / motor mount
With this setup the plane weighs in at about 16.4oz and is about 15-20mph faster than stock 3s setup. This is for those looking for good all around flight performance fast and slow.
rcFoamFighters is offline Find More Posts by rcFoamFighters
Old Jan 16, 2012, 06:37 PM
nogas is offline
Find More Posts by nogas
Because gas is for BBQ's
nogas's Avatar
Australia, QLD, Brisbane
Joined Feb 2011
Good to see this plane (and thread) is getting some more followers.
For those flying this for the first time, make sure you have dialled back your rates and or are set up for minimal throws, this thing is crazy twitchy at full rates / throws. Dont ask me how i know.
Originally Posted by kiwi_idiot View Post
cheers nogas good to know. Pretty sure I'll run your setup as it seems pretty popular
on the crazier side anyone got near 300k/hr out of these? Any suggestions to get one there?
thanks guys
300kph??? WOW, you really are trying to live up to your name
I've heard of over 200kph with the 2836 but nothing like 300. Good luck, hope you've got good eye sight.
Originally Posted by nickelbn1 View Post
I did read the thread. I saw about a 1000mah 4 cell but I didnt see anything about a 1300mah 4 cell. that is why I asked. I would like to know what a good battery would be that wouldnt require a lot of foam removal. some is ok, but I dont want to remove a lot.
The 1300 wont require alot of foam removal. In any case you can counter balance on the rear end if you want to just mount it in the cockpit. I also believe a 1000 3S will balance OK without removing any foam.
nogas is offline Find More Posts by nogas
Old Jan 16, 2012, 07:04 PM
vettster is offline
"Take Off" eh!
vettster's Avatar
Canada, ON, Beeton
Joined Aug 2008
That was a great video Frank! Though at the 2;05 mark..You said you scooted the CG forward a bit, when I think you meant to say..you moved it Rearward. We've found that 15-20mm rearward of the stock location is best.
Thanks for doing such a great review.
Trevor
Old Jan 16, 2012, 08:19 PM
choopi is offline
Find More Posts by choopi
choopi's Avatar
New Brunswick
Joined Feb 2006
That is what I'm running on mine with 4s 1000mah pack but small prop!
choopi is offline Find More Posts by choopi
Old Jan 16, 2012, 09:18 PM
vettster is offline
"Take Off" eh!
vettster's Avatar
Canada, ON, Beeton
Joined Aug 2008
Im telling you choopster.. 6x4 is were the fun is
Old Jan 16, 2012, 09:35 PM
choopi is offline
choopi's Avatar
New Brunswick
Joined Feb 2006
THatis my next move! 6x4 On 4s, that should move.
Old Jan 17, 2012, 07:57 AM
nogas is offline
nogas's Avatar
Joined Feb 2011
Cant wait to see this. Video or it didn't happen.
Contest Habu 32 Speed Contest Tumbler Unlimited Class 165.2 keithtsr Electric Ducted Fan Jet Talk 2140 May 01, 2016 10:29 PM
Discussion RadJet from the KING! vettster Foamy EDFs 1 Jun 01, 2014 06:00 PM
Help! New ViperJet From Hobby King dviperjet Electric Ducted Fan Jet Talk 20 Sep 30, 2011 07:04 AM
For Sale orange rx from hobby king and orange satilite from hobby king ZEROSKIN76 Aircraft - General - Radio Equipment (FS/W) 8 Mar 15, 2011 01:41 PM
Sold orange rx from hobby king and orange satilite from hobby king ZEROSKIN76 Aircraft - General - Radio Equipment (FS/W) 4 Feb 21, 2011 12:06 PM
