Old Jan 07, 2012, 08:23 PM
vettster is offline
Find More Posts by vettster
"Take Off" eh!
vettster's Avatar
Canada, ON, Beeton
Joined Aug 2008
I dunn know.....i think you get more speed out of the 6x4 since your motor sounds as though its hitting it max rpm. Im going to try the larger prop if I ever get around to flying in the winter.
vettster is offline Find More Posts by vettster
Old Jan 07, 2012, 10:29 PM
choopi is offline
Find More Posts by choopi
choopi's Avatar
New Brunswick
Joined Feb 2006
I know! I did try once a bigger prop, but for some reason, it almost sound like it was loading the motor to much like it was bugging, I will have to plug my Eagletree to see.
An other quick clip of the Radjet:
Hobyking RADJET Jan 2012 (2 min 46 sec)
choopi is offline Find More Posts by choopi
Old Jan 07, 2012, 11:11 PM
vettster is offline
"Take Off" eh!
vettster's Avatar
Canada, ON, Beeton
Joined Aug 2008
Maybe 6x3
Old Jan 08, 2012, 01:09 AM
The_RattleSnake is offline
Find More Posts by The_RattleSnake
The_RattleSnake's Avatar
Joined Jul 2007
copied from my video,...
I run the Turnigy 2836 3700kv on my Model Engines FOX that I converted to RC.
Using a 1000mah 3s and an apc 4.5x4.1 it pulls 41 amps @ a bit over 30k rpm.
Ive had the maiden flight but not a speed run yet, Im hoping pass 150 kph.
143kph is my best so far with the old version of the fox.
That was my comment on your video :P
I have been looking on getting something that is fast and reliable.
( The fox is being pushed to 15 times or so its origional speed and I don't expect it to last long)
Was looking at This thing or a parkjet (Mini Skyfun) or the blue fiberglass pylon racer from HK.
do you guys think this one would be the best way to go ? I have a Turnigy 2836 2350kv that I was planning on running on 4s in it with a apc 5x5 prop
or I could put the 2836 3700 kv in it on 3s.
The_RattleSnake is offline Find More Posts by The_RattleSnake
Old Jan 08, 2012, 04:35 AM
unisev is offline
Find More Posts by unisev
unisev's Avatar
Joined Sep 2011
I think its 4.5x4.5 but the guys here are useing 6x4
Thank you guy !
I think I'll buy a 5x5
unisev is offline Find More Posts by unisev
Old Jan 08, 2012, 08:48 AM
choopi is offline
choopi's Avatar
New Brunswick
Joined Feb 2006
I don't know but the shaft will have to be move on the 2836. If you use this one it's 2200kv and it work on 4s and the shaft is the right way: http://www.hobbyking.com/hobbyking/s...dproduct=12919
Old Jan 09, 2012, 05:52 AM
Joined Jul 2007
I already have the 2836 2350kv and 3700kv versions.
But that is a nice ( and very cheap ) Motor.
Its not hard to swap the shaft on the 2836 motors.
I did a step by step vid here:
Brushless Motor, Shaft / Pusher Conversion (5 min 47 sec)
Old Jan 09, 2012, 06:02 AM
choopi is offline
choopi's Avatar
New Brunswick
Joined Feb 2006
Nice!
Old Jan 10, 2012, 09:25 AM
planex is offline
Find More Posts by planex
Rookie
planex's Avatar
Australia, VIC
Joined Jun 2011
Are you sure this motor can take 4s?
It only says 2-3s in the specs?
planex is offline Find More Posts by planex
Old Jan 10, 2012, 03:55 PM
vettster is offline
"Take Off" eh!
vettster's Avatar
Canada, ON, Beeton
Joined Aug 2008
LOL who cares if it cant. Its only a $4 motor. If it blows up...upgrade to a $13 motor
Ive already had several flights with the stock motor on 4s 2200 and no problems
Old Jan 10, 2012, 09:30 PM
nickelbn1 is offline
Find More Posts by nickelbn1
fly and then fly some more!
nickelbn1's Avatar
Springdale, AR
Joined Dec 2006
subscribed
nickelbn1 is offline Find More Posts by nickelbn1
Old Jan 11, 2012, 08:11 PM
PeteFliesBy is offline
Find More Posts by PeteFliesBy
but sometimes crashes
Joined Jan 2012
Vettster, are you sure the rcspeedo app is accurate? I'm curious about the radjet so that's how I came across this thread, but I clocked 269 km/h (167miles/h) on a skyfun this morning and just wanted to know if it's accurate. Have the turnigy 2350 powered by a 4S 2200 running a graupner 6.5x4 speed prop. Pulled 963 watts during ground testing. Graupner props rock! Very smooth props. Wouldn't the radjet be a bit of a flying brick on a 2350 with very little glide?
PeteFliesBy is offline Find More Posts by PeteFliesBy
Old Jan 11, 2012, 10:06 PM
choopi is offline
choopi's Avatar
New Brunswick
Joined Feb 2006
For my experience with RC Speedo, you do sometime get a bad pass, but most the time it's super accurate as I have a GPS(Eagletree) and most the time it is within 1mph accurate. What was the average passes on that particular flight?
Old Jan 11, 2012, 10:08 PM
vettster is offline
"Take Off" eh!
vettster's Avatar
Canada, ON, Beeton
Joined Aug 2008
Like Choppi said. But you need to make sure you have the correct temperature inputted.
Other wise....HOLY COW!!
Old Jan 11, 2012, 10:27 PM
choopi is offline
choopi's Avatar
New Brunswick
Joined Feb 2006
Ya temp is the key, also, how windy was it when you did that pass
Contest Habu 32 Speed Contest Tumbler Unlimited Class 165.2 keithtsr Electric Ducted Fan Jet Talk 2140 May 01, 2016 10:29 PM
Discussion RadJet from the KING! vettster Foamy EDFs 1 Jun 01, 2014 06:00 PM
Help! New ViperJet From Hobby King dviperjet Electric Ducted Fan Jet Talk 20 Sep 30, 2011 07:04 AM
For Sale orange rx from hobby king and orange satilite from hobby king ZEROSKIN76 Aircraft - General - Radio Equipment (FS/W) 8 Mar 15, 2011 01:41 PM
Sold orange rx from hobby king and orange satilite from hobby king ZEROSKIN76 Aircraft - General - Radio Equipment (FS/W) 4 Feb 21, 2011 12:06 PM
