Old Oct 21, 2011, 08:58 PM
RedRanger is offline
Find More Posts by RedRanger
Did you say up or down?
RedRanger's Avatar
Canada, ON, Brampton
Joined Mar 2011
Question
Battery Wire Gauge?
Hello,
I have just purchased some 3S and 4S Lipo's. Stupid me forgot to look at the wire gauge on the battery ends. They arrived with 12ga wire.
My question is all my ESC's have 14ga and 16 gauge wire, can I still hook up these Lipo's to my ESC's? I should be going from small to larger diameter wire if I read correctly. In this case I am stuck with these Lipo's with 12 ga wire. Can this be done?
E.
RedRanger is offline Find More Posts by RedRanger
Old Oct 21, 2011, 09:21 PM
whitecrest is offline
Find More Posts by whitecrest
Frequent Flyer
whitecrest's Avatar
Orleans, MA
Joined Feb 2007
You'll have no problem doing that. Wires of this size can conduct very large currents. If there are any losses in the narrower gauge ones, they will be negligible, especially in the short lengths required for RC hookups.
You can make a smooth physical transition from the narrower to wider gauges by stripping off about 1/4" of insulation from each wire end and then intermingling the strands before soldering and covering with shrink wrap.
whitecrest is offline Find More Posts by whitecrest
Old Oct 21, 2011, 09:31 PM
RedRanger's Avatar
Joined Mar 2011
So I am safe going from a large 12ga battery wire to a smaller 16ga ESC wire done through EC3 connectors?
Thanks for the reply and help whitecrest.
Regards,
E.
Old Oct 21, 2011, 10:04 PM
TheWoodCrafter is offline
Find More Posts by TheWoodCrafter
RC Helicopter Pilot
TheWoodCrafter's Avatar
United States, CA, Westminster
Joined Mar 2010
This is one of thoughs cases where bigger is better.
Big wire out of a battery is always a good thing.
TheWoodCrafter is offline Find More Posts by TheWoodCrafter
Old Oct 21, 2011, 10:54 PM
RedRanger's Avatar
Joined Mar 2011
Phew! Thought I had screwed myself. Gratefull for the information TheWoodCrafter.. Glad to know I did not waste my money on Lipo's I could not use
Another lesson learned for me
Regards,
E.
Question Is there a formula for going from more turns of a smaller gauge wire to a larger #? roberted5 Electric Motor Design and Construction 2 Oct 03, 2011 10:24 AM
Help! Rewiring a standard DC motor with smaller gauge wire. Tommygunn Electric Motor Design and Construction 17 Sep 07, 2011 01:22 PM
Battery pack wire size (gauge) Mike Palko Power Systems 1 Jun 23, 2003 12:40 AM
Battery pack wire gauge: rule of thumb zippogeek Batteries and Chargers 3 Jun 11, 2003 12:39 PM
Battery Pack Wire Gauge? LJH Power Systems 8 Apr 23, 2001 12:55 AM
