Old Oct 21, 2011, 05:30 PM
Msioni is offline
Find More Posts by Msioni
Joined Oct 2010
Hobbywing/Turnigy 180A ESC Issue
Hey guys, I have a new Hobbywing 180A ESC and there seems to be an issue. I am using a Leopard 5692 and, for testing purposes, a 4S lipo. Everything is new in the system. The issue is that when I plug in the battery, the esc either goes through it start up tunes, or quickly turns on, either way, it immediately goes to high throttle and does not respond to the transmitter. I have used a different transmitter to no avail. I have both the basic Boat Hobbywing ESC programmer as well as the advanced usb programmer, and have reset the settings, but I cant figure it out. Any ideas?
Thanks.
Msioni is offline Find More Posts by Msioni
Old Oct 22, 2011, 12:25 AM
CornelP is offline
Find More Posts by CornelP
CornelP's Avatar
Bucharest, RO
Joined May 2009
I think it's just throttle adjustment... Before connecting the battery on the ESC, put the Tx to full throttle. Connect power and, after the first beeps, get the throttle to neutral (if you use reverse or have a pistol Tx) or fully down on a stick type with no reverse. This should cure it.
CornelP is offline Find More Posts by CornelP
Mini-HowTo RCTimer/Turnigy/Hobbywing ESC DIY Firmware Flashing Nek Multirotor Electronics 10724 Aug 22, 2016 03:41 PM
Help! Turnigy K force. Hobbywing platinum pro ESC barnstorm100 Mini Helis 5 Sep 07, 2011 04:37 PM
Help! Using hobbywing pentium esc and turnigy plush esc on one quad tahi_88 Multirotor Talk 1 Jul 12, 2011 01:43 PM
Discussion New Turnigy ESC 12S 120A / 180A burst Franz2002_01 Power Systems 14 Jul 17, 2009 01:40 AM
For Sale Hobbywing 100A ESC, same as Turnigy ESC jetfan20 Aircraft - Electric - Jets (FS/W) 5 Nov 29, 2008 08:15 AM
