Old Oct 21, 2011, 05:24 PM
TSXChef is offline
Find More Posts by TSXChef
Joined Oct 2011
Art Tech Miniwolf SE Bottom Rotor Not Spinning, Help Appreciated.
Hello,
I have Art-Tech Miniwolf SE, purchased from XHeli few weeks ago... Unfortunately I had a bad spill and ran the helicopter to a wall.
ISSUE: the bottom blade rotor assembly is somehow not attached to the outside center shaft (when center outer shaft is spinning, the bottom rotor does not spin together as if it is not tied together anymore). Because of this, bottom rotor spins somewhat, but not enough to lift the helicopter. Top blade-rotor spins just fine.
I am not sure how the bottom rotor assembly was attached to the outer-center shaft when it was new, does anyone know?? I thought about gluing little piece that is above bottom swash-plate to the outer-center shaft, but wasn't sure of its consequences.
I am wondering if I need a spare part to fix my issue, and if so, can you tell me which spare part(s) I would need? Thanks.
Any help would be greatly appreciated. Thanks in advance!
Cheers.
-TSXChef
TSXChef is offline Find More Posts by TSXChef
Help! Top Rotor Not Spinning Properly Dusty88 Coaxial Helicopters 9 Aug 21, 2013 08:10 PM
Discussion Art tech Miniwolf JET747 Coaxial Helicopters 39 Aug 01, 2012 02:31 PM
Discussion Brownstone Silver Bullet RC Heli bottom blades not spinning ? cc114144 Beginner Training Area (Heli-Electric) 1 Sep 28, 2011 06:01 AM
Discussion HELP! bottom rotor of blackstorm heli not spinning anymore bowlerman13 BladeRunner Heli 0 Jan 06, 2010 07:10 PM
