Old Oct 21, 2011, 04:49 PM
JMF11 is offline
Find More Posts by JMF11
Joined Jul 2011
problem with electric glider flight after a crash
Dear all,
I'm looking for some help. I come back to RC models afte 20 years of non practice and my analysis skills are now very smooth. I Crashed my Kinetic 800 some weeks ago (lost one wing during the flight). I repaired it. It flies again, but it seems much more difficult to fly than before:
- it needs a lot of trim (seems more thqn before) on the elevator to suppress stall,
- when you push the throttle, then the plane immediately goes up, almost starting a loop when with full throttle.
But the CG is OK, and the front of the plane does not seems damaged.
What to look for ? What could cause this ?
Regards,
JMF
JMF11 is offline Find More Posts by JMF11
Old Oct 21, 2011, 08:05 PM
AC5FF is offline
Find More Posts by AC5FF
Where'd The Wise Men Go?!?
AC5FF's Avatar
United States, NE, Bellevue
Joined Sep 2007
just a couple ideas...
Incidence problem? The third photo looks like the stab is a little off from the main wing, but almost opposite of what you are describing...
You said the front of the plane wasn't damaged - but again the photos seem to show the nose pointed upwards which would explain this...
I'm not familiar with the model here - but just a few ideas I had..
AC5FF is offline Find More Posts by AC5FF
Old Oct 22, 2011, 01:57 AM
Flyextreme is offline
Find More Posts by Flyextreme
Sure it'll work
Flyextreme's Avatar
United States, CA, Redondo Beach
Joined Nov 2005
I was thinking the same. The leading edge of the horz stab looks to be high which would cause you to need up trim for level flight.
The top of the fuse just behind the motor mount looks a little scrunched changing the thrust line (up) which would cause the plane to climb when you apply throttle.
It's a little hard to tell from just pictures, but these might be a few things to consider taking a closer look at.
Bill
Flyextreme is offline Find More Posts by Flyextreme
Old Oct 22, 2011, 12:22 PM
JMF11 is offline
Joined Jul 2011
Thanks for your advices. I see that both of you see the nose of the plane pointing too high. I have to investigate this further. I may have to remove the red plastic piece, to see how is the foam behind it.
I'll post the result.
Thanks again,
JMF
Old Oct 22, 2011, 12:31 PM
UlteriorModem is offline
Find More Posts by UlteriorModem
UlteriorModem's Avatar
Joined Aug 2011
Second photo, is that just wrinkles in the decal or has the nose been 'crumpeled' at some point?
Yea double check the firewall, I had one crack but it kind of set in place throwing the thrust angle all wonky. You couldent tell by glancing at it. The next flight was exciting.
UlteriorModem is offline Find More Posts by UlteriorModem
Help! please help with my "problem after problem" problem chopperdudes Micro Helis 3 Apr 29, 2014 09:44 AM
Discussion AV- After some time.. with my Easy Glider guyg Aerial Photography 3 Oct 04, 2011 08:42 PM
Discussion Problem with aon motor after slight crash... TommyB Cermark 2 Jun 03, 2006 11:21 AM
