View Poll Results: Which programmers are you using
AVRisp mkII 14 23.73%
usbasp 34 57.63%
mySmartUSB light 4 6.78%
USBtiny 8 13.56%
other 2 3.39%
Multiple Choice Poll. Voters: 59. You may not vote on this poll
Old Jul 21, 2012, 08:48 AM
LittleG's Avatar
Raleigh, NC
Joined Jan 2007
Error message appears when flashing HK multicopter board
Need help flashing the multicopter board.
Below is what is displayed when I attempted to flash the HobbyKing Multi-Rotor Control Board V2.1 (Atmega168PA) with Tricopter V2.5XXcontrol KR by Minsoo Kim:
Flash the firmware from repository.
C:\Users\iM\Desktop\kkflashtool\lib\avrdude\window s\avrdude.exe -C C:\Users\iM\Desktop\kkflashtool\lib\avrdude\window s\avrdude.conf -p m168p -P usb -c usbasp -B 8 -e -U lfuse:w:0xe2:m -U hfuse:w:0xdd:m
avrdude.exe: set SCK frequency to 93750 Hz
avrdude.exe: warning: cannot set sck period. please check for usbasp firmware update.
avrdude.exe: AVR device initialized and ready to accept instructions
Reading | ################################################## | 100% 0.00s
avrdude.exe: Device signature = 0x1e940b
avrdude.exe: erasing chip
avrdude.exe: reading input file "0xe2"
avrdude.exe: writing lfuse (1 bytes):
Writing | ################################################## | 100% -0.00s
avrdude.exe: 1 bytes of lfuse written
avrdude.exe: verifying lfuse memory against 0xe2:
avrdude.exe: load data lfuse data from input file 0xe2:
avrdude.exe: input file 0xe2 contains 1 bytes
avrdude.exe: reading on-chip lfuse data:
Reading | ################################################## | 100% -0.00s
avrdude.exe: verifying ...
avrdude.exe: 1 bytes of lfuse verified
avrdude.exe: reading input file "0xdd"
avrdude.exe: writing hfuse (1 bytes):
avrdude.exe: 1 bytes of hfuse written
avrdude.exe: verifying hfuse memory against 0xdd:
avrdude.exe: load data hfuse data from input file 0xdd:
avrdude.exe: input file 0xdd contains 1 bytes
avrdude.exe: reading on-chip hfuse data:
avrdude.exe: 1 bytes of hfuse verified
avrdude.exe done. Thank you.
Flashing firmware from file.: C:\Users\iM\Desktop\kkflashtool\tmp\XXcontrol_KR_T riCopter_v2_9.hex
C:\Users\iM\Desktop\kkflashtool\lib\avrdude\window s\avrdude.exe -C C:\Users\iM\Desktop\kkflashtool\lib\avrdude\window s\avrdude.conf -p m168p -P usb -c usbasp -B 8 -e -U flash:w:C:\Users\iM\Desktop\kkflashtool\tmp\XXcont rol_KR_TriCopter_v2_9.hex:i
avrdude.exe: error: could not find USB device with vid=0x16c0 pid=0x5dc vendor='www.fischl.de' product='USBasp'
Error during writing flash.
LittleG is offline Find More Posts by LittleG
Old Jul 21, 2012, 10:04 AM
quad pilot
LazyZero's Avatar
Alsdorf/Eifel, Germany
Joined Jun 2005
Just retry seem that the USBasp shut down after writing fuses. Haven't seen this before.
Christian
LazyZero is offline Find More Posts by LazyZero
Old Jul 21, 2012, 11:48 AM
LittleG's Avatar
Raleigh, NC
Joined Jan 2007
Christian
I did it again, and got this with error message (Error during writing flash.) at the end. See below.
Flash the firmware file.
Reading | ################################################## | 100% 0.01s
Writing | ################################################## | 100% 0.00s
Old Jul 21, 2012, 11:54 AM
LittleG's Avatar
Raleigh, NC
Joined Jan 2007
Do you think I have a bad USBasp device? I have installed the required drivers for it.
Old Jul 21, 2012, 11:59 AM
LittleG's Avatar
Raleigh, NC
Joined Jan 2007
I tried it again and got this:
avrdude.exe: error: usbasp_transmit: usb_control_msg: sending control message failed, win error: A device attached to the system is not functioning.
avrdude.exe: error: programm enable: target doesn't answer. 0
avrdude.exe: initialization failed, rc=-1
Double check connections and try again, or use -F to override
this check.
Error during setting the fuses.
Flashing of firmware aborted.
Old Jul 22, 2012, 03:59 AM
quad pilot
LazyZero's Avatar
Joined Jun 2005
Look like your usbasp is not working properly. You only have attached the board or a there any other components connected to the board?
Best Christian
Old Jul 22, 2012, 04:59 AM
Quad lover.
chaosdestro0's Avatar
Joined Dec 2011
I have a usbasp but it's at 3.3V, will it work when flashing?
I guess I could change it to 5v but I am not sure how to do that.
chaosdestro0 is offline Find More Posts by chaosdestro0
Old Jul 22, 2012, 05:28 AM
quad pilot
LazyZero's Avatar
Joined Jun 2005
That could work, but I am not sure. Can you switch off the 3.3v totally? Then you could attach a bec with 5v during flashing
Christian
Old Jul 22, 2012, 05:45 AM
Quad lover.
Joined Dec 2011
Christian
Ahh I just made a little thing up on a perfboard as my isp programmer came with a 10 pin cable, I just won't attach vcc and then power it from a BEC.
Old Jul 22, 2012, 05:55 AM
quad pilot
LazyZero's Avatar
Joined Jun 2005
That's the alternative.
Old Jul 25, 2012, 05:38 PM
LittleG's Avatar
Raleigh, NC
Joined Jan 2007
Best Christian
No other components were connected to the board...
Old Jul 26, 2012, 12:23 AM
quad pilot
LazyZero's Avatar
Joined Jun 2005
Then you should try a new USBasp, had similar issues with mine USBasp the last days after I switched to a new one everything was like expected.
Old Jul 28, 2012, 10:57 PM
Movie Guy's Avatar
Delta, BC, Canada
Joined Apr 2004
I am trying to flash some Turnigy Plush 25 escs. Using a USBTiny which seems to be working alright but when it gets to the point where it starts to write, the program hangs and nothing happens until I lose contact with the esc and get an error message. Using version .62 on Mac OS 10.6.8. I noticed that there was a patch for windows on your webpage but nothing for Mac. A copy and paste of the message where it freezes or stops doing anything:
Flashing firmware from file.: /Users/xxxx/Library/Preferences/kkMulticopterFlashTool/tgy.hex
/Applications/kkMulticopter Flash Tool.app/Contents/Resources/Java/lib/avrdude/mac/avrdude -C /Applications/kkMulticopter Flash Tool.app/Contents/Resources/Java/lib/avrdude/mac/avrdude.conf -p m8 -P usb -c usbtiny -B 8 -e -U flash:w:/Users/xxxxx/Library/Preferences/kkMulticopterFlashTool/tgy.hex:i
avrdude: AVR device initialized and ready to accept instructions
avrdude: Device signature = 0x1e9307
avrdude: erasing chip
avrdude: reading input file "/Users/xxxxx/Library/Preferences/kkMulticopterFlashTool/tgy.hex"
avrdude: writing flash (8192 bytes):
Writing |
You have any thoughts here?
Edit: I have tried .33, .53.2, .62 and .63 beta 8.
.33 works to flash an Atmel 328P chip that I have but all the other versions freeze at the "Writing" point. Sadly .33 does not seem to allow ESC flashing so I am currently stuck.
Edit #2 Also tried it on another Mac using 10.7.4 and issue is the same. Is there a patch or file I need to get the USBTIny to work with the later versions?
Movie Guy is offline Find More Posts by Movie Guy
Old Jul 30, 2012, 03:22 AM
Doha, Qatar, Middle East
Joined Jan 2005
Hi Lazy
I'm having some issues running your flashtool
When i try to run the serial command to launch the program i get this message.
"java is not recognized as an internal or external command, operable program or batch file"
Even though i have Java installed?
What am i doing wrong?
Many thanks
Ben
wazzer is offline Find More Posts by wazzer
Old Jul 30, 2012, 03:16 PM
Mmmmmmm!
WiseDuck's Avatar
Kingdom of Sweden, Dalarna County, Sater
Joined Oct 2011
So I'm trying to flash my ESCs using my 'USBtiny/Sparkfun programmer. But as you know it does not work with version 0.62, only 0.33.
Unfortunately, 0.33 has no option for flashing ESCs so I am stuck. What can I do?
WiseDuck is offline Find More Posts by WiseDuck
