Old Oct 21, 2011, 03:46 PM
Taurean75 is offline
Find More Posts by Taurean75
Joined Oct 2011
1800mAh AAA NiMH Rechargeable Batteries
Do 1800mAh AAA NiMH Rechargeable Batteries Exist?
I bought some on eBay, but they are being detected as defective by 2 separate chargers.
Thanks.
Taurean75 is offline Find More Posts by Taurean75
Old Oct 21, 2011, 04:03 PM
everydayflyer is offline
Southern Pride
everydayflyer's Avatar
Haralson County GA. USA
800 mAh is a lot for AAAs perhaps the 1 was a mistake.
Old Oct 21, 2011, 06:14 PM
mrforsyth is offline
Find More Posts by mrforsyth
So. Cal.
Unfortunately, there are a multitude of sellers peddling "1800mAh" AAA NiMH cells on eBay. Nearly all are garbage and none are likely anywhere near 1800mAh in capacity.
http://www.ebay.com/sch/i.html?_nkw=...hargeable+1800
Rechargeable AAA's are a bit more finicky than rechargeable AA's so it's best to restrict purchases to those with known good performance. AAA Eneloops are the best that I have ever personally tested and use them in many devices and have yet to have one fail. The AAA Eneloops have a reported capacity of 800mAh and all that I have tested had usable capacity between 750 and 825mAh.
Mark
mrforsyth is offline Find More Posts by mrforsyth
Old Oct 21, 2011, 07:40 PM
flydiver is offline
Find More Posts by flydiver
flydiver's Avatar
United States, WA, Seattle
Joined Jan 2007
1800 AAA? Complete scam. Likely complete garbage.
Anything over 800 is a lie.
flydiver is offline Find More Posts by flydiver
Old Oct 21, 2011, 07:45 PM
Joined Oct 2011
Thanks, guys!
Old Oct 21, 2011, 07:52 PM
Wrend is offline
Find More Posts by Wrend
どうもありがとうミスターロボット
Wrend's Avatar
United States, IL
Joined Jul 2009
You might be able to get close to 1800mAh with some chemistries of primary AAA cells at very low drain rates, but definitely not any NiMH rechargeable cells that I'm aware of.
Wrend is offline Find More Posts by Wrend
Old Oct 22, 2011, 09:32 AM
Capt. Gary is offline
Find More Posts by Capt. Gary
Joined Nov 2010
Max AAA NiMHs I've been able to find are 1000 mAH.
Sanyo, Lenmar, DuraCell all have them.
Capt. Gary is offline Find More Posts by Capt. Gary
Old Oct 22, 2011, 08:34 PM
Joined Oct 2011
eBay sided with me and issued a full refund.
I'd have done a research beforehand. Live and learn, I guess.
Thanks!
Old Oct 27, 2011, 01:47 PM
chainring is offline
Find More Posts by chainring
Joined Apr 2007
Just stick with 800 mAh AAA Sanyo Eneloop's and you'll have no problem.
Capacities over 2500 on AA's are generally fake.
Capacities over 1000 on AAA's are generally fake.
chainring is offline Find More Posts by chainring
Old Oct 27, 2011, 02:05 PM
merlin703 is offline
Find More Posts by merlin703
Love anything RC
merlin703's Avatar
Alexandria, Virginia
Joined Mar 2008
Can't you set up the batteries in parallel to make it an 1800mAh, just like you would do with lipos? or is that can only be accomplished with lipos? I've always been curious.
merlin703 is offline Find More Posts by merlin703
Old Oct 27, 2011, 04:04 PM
So. Cal.
For discharge, yes. For charging, no.
Cell counts must obviously be the same.
Mark
Old Oct 27, 2011, 07:28 PM
Wrend is offline
どうもありがとうミスターロボット
Wrend's Avatar
United States, IL
Joined Jul 2009
That, and usually you get AAAs because of size or weight limitations. AAs would be more effective if those weren't issues.
Old Oct 28, 2011, 05:34 PM
Love anything RC
merlin703's Avatar
Joined Mar 2008
Mark
Yes, that's what I mean, discharging. So for charging I assume lipos make it possible due to the balancing tabs. Good to know, thanks guys!
Old Oct 28, 2011, 05:47 PM
So. Cal.
Not related to balance taps. It's possible with lipolys (and Pb) due to charge algorithm. Lipolys charge to a specific voltage (4.2V) via CC/CV (constant current / constant voltage) charge algorithm whereas NiXX employ dV/dT (peak sense) algorithm.
Multiple lipolys can be charged in parallel independent of whether one chooses to use the balance taps. It's generally wiser to use the balance taps, but certainly not necessary.
Mark
Old Oct 28, 2011, 10:09 PM
Wrend is offline
どうもありがとうミスターロボット
Wrend's Avatar
United States, IL
Joined Jul 2009
NiMH cells can be parallel charged, but it isn't recommended due to their variations and their drop in voltage as they warm up near the end of their charge.
Eneloop C and D "cells" sold in other countries are actually paralleled AAA and AA cells. This isn't as much of an issue for them because they're very similar and because they'll have the same usage history.
You could reasonably safely parallel charge similarly performing NiMH cells, but it would be at such a low rate (so as to not inadvertently dangerously overcharge individual cells) that it isn't practical. (About 30 hours for 2 cell, 45 hours for 3, and so on.)
For Sale POWEREX C9000 Wizard One Charger/ Analyzer for AA & AAA Batteries - REDUCED GoRgOyL Aircraft - Electric - Batteries & Chargers (FS/W) 2 Mar 01, 2015 02:14 PM
Question Rechargeable Rx/Tx batteries VS regular headshrink Sailboats 9 Oct 18, 2011 11:43 AM
Discussion Centura Low Self-Discharge (LSD) NiMH Rechargeable Batteries ptglass Batteries and Chargers 3 Mar 17, 2011 08:00 AM
Yippee! 8 Duracell AA NiMH rechargeable Tx batteries - $11!! grymg Motorcycles 10 Feb 10, 2006 12:44 PM
FS: Battery packs - 9.6V 350 2/3AA NiCd, 8.4V 650 AAA NiMH, 8.4V 650 AAA NiMH Cycletherapy Aircraft - Electric - Airplanes (FS/W) 0 Apr 01, 2005 05:36 PM
