Old Sep 20, 2003, 08:35 PM
vw63 is offline
Find More Posts by vw63
Stockton CA
Joined Mar 2003
Li-poly for Hacker B20 4.1 HELP
Hey evrey one. I need some help. I have a Hacker B20 4.1 wiht a C.C. 35 speed control.
I want to no if there are any Li-poly's that I can use with this setup any and all help would be gerat Thanks Jeremy
vw63 is offline Find More Posts by vw63
Old Sep 20, 2003, 08:44 PM
birdofprey is offline
Find More Posts by birdofprey
The Magician.
birdofprey's Avatar
Lucas, Kansas
Joined Nov 2002
Welcome to RCGroups.
What kind of airframe and which B20 do you have? There are a number of different B20 motors that use different numbers of windings as well as Long and Short cans.
Justin
birdofprey is offline Find More Posts by birdofprey
Old Sep 20, 2003, 09:32 PM
Donald Duck is offline
Find More Posts by Donald Duck
Donald Duck's Avatar
Fort Collins, Colorado
Joined Mar 2002
Li-Polymers with Hacker B20 4:1
Sure you can use Li-poly batteries with the Hacker B20-4:1. Two LiPo batteries in series will be about the same as 7 NiMH cells. Three in series will be about the same as 10 NiMH cells. However, you have to worry more about the current draw. Assuming you use 1200 mAH LiPo cells, depending on the propeller and the current draw by the motor needed for the speed of your plane, you may have to go to 2 or even 3 LiPo parallel sets of 2 or 3 LiPo cells in series --- that is, 2S2P or 2S3P or 3S3P. I run a Hacker B20-18L/4:1 on 10x1100 mAH NiMH cells, drawing about 13 amps at full power for a 9x6 APC-e prop. To match that with LiPo cells, I would probably try 2S2P to start, then if I needed more power, go up in series. Increase the number of parallel cells if the LiPo cells get too hot with the required current draw.
Donald Duck is offline Find More Posts by Donald Duck
Old Sep 21, 2003, 11:41 PM
vw63 is offline
Stockton CA
Joined Mar 2003
Thanks For the reply's
I have this setup in a Airwave Design Sukhoi 3D the motor is a B20 22L 4:1 and the prop is a 11 X 4.7
Thanks Guy's
Jeremy
Old Sep 22, 2003, 03:06 AM
Jason M is offline
Find More Posts by Jason M
20 years on RCG!
United States, IL, Champaign
Joined Dec 1996
I use 2 Hacker B20-15L motors with the 4:1 gearing in some of my 3D models.
With this motor and a 9x6 prop on one plane with an 11x3.8 prop on the other, static current draw is 20 amps on 3s LiPos (Same power as 10 cells). This is far too much for the 1200 mah LiPos...2p does help, but I prefer to use a 3s 2100 mah Thunder Power pack. This pack easily handles 20-25 amp burst for short verticals and is capable of 12.6 amps continuous.
But, both airplanes only weigh around 16 ounces so most of the flight is spent around 1/4-2/3 throttle which makes flight times 15-20 minute easy per charge. With 30 ounces of thrust, both models have AWESOME vertical - the 9x6 is good for speed, the 11x3.8 is great for slow flying but great pull and acceleration.
With any Hacker B20 motor, the Thunder Power 2100s are your best bet when pulling 15-20 amps static. Use 3s for the power of 10 cells, and 2s for the power of 7 cells.
You can get these Thunder Power packs at your local hobby shop (they can order them from Horizon for you), or at these sites:
http://www.espritmodel.com/accesorie...ies.html#LiPol
http://www.lightflightrc.com
http://www.b-p-p.com
http://www.edogfight.com
And many others too!
Jason
Jason M is offline Find More Posts by Jason M
Old Sep 22, 2003, 03:09 AM
Jason M is offline
20 years on RCG!
Joined Dec 1996
I think the Thunder Power 3s 2100s will be perfect for your 22L motor - only weighs 4.5 ounces with 2100 mah and the power of 10 cells
Jason
Old Sep 22, 2003, 07:16 PM
Joined Mar 2002
Li-polymers in parallel
If you use three 1200s in series, and two of those packs in parallel, you will do fine on a Hacker B20 15L. I am flying a SR Batteries X250 model on 10 1100 mAH NiMH cells, with a 8x6 APC-e propeller. It draws between 11 and 12 amps at full throttle. I plan to replace the NiMH batteries with LiPo, in a 3s2p configuration of 1200 mAH Etec cells. The use of two parallel LiPo packs will reduce the current draw from each pack by 50%, while maintaining the voltage. That means each pack will be putting out about 5 to 6 amps at full throttle, or roughly 5C, which should work o.k. Most of my flying is at about 3/4 throttle. Replacing the NiMH battery with the LiPo packs will reduce the weight by 2.5 ounces, which is pretty significant for a 24 ounce plane. However, I cannot disagree with the use of 3s Thunder Power 2100 mAH cells, but I already own the Etec 1200s.
Old Sep 22, 2003, 08:14 PM
Clayshobbies is offline
Find More Posts by Clayshobbies
Clayshobbies's Avatar
Ohio
Joined May 2003
The Thunder Powers would be great. I use the 3s 2100 with my BP20-15L and my new Himax.
Plus I sell them for $5-$10 less then the 4 venders above
http://www.clayshobbies.com/Field%20...tterypacks.htm
Clayshobbies is offline Find More Posts by Clayshobbies
Old Sep 22, 2003, 11:22 PM
vw63 is offline
Stockton CA
Joined Mar 2003
Wow
Wow!!! Thanks to all. This helps me out so much. Jeremy
Old Sep 24, 2003, 10:10 AM
texan is offline
Find More Posts by texan
PROBRO 194
texan's Avatar
Georgetown, TX
Joined Apr 2003
vw63,
I'm running a Hacker B20 15L 4:1 with a 10x4.7 prop in a Wattage Crazy 8 on KOKAM 3s3p 1020 LiPo pack. Performance is excellent ... saved about 9oz from the previous 10cell cp1300 setup. Controller is Hacker 30 amp.
TX
texan is offline Find More Posts by texan
Old Sep 24, 2003, 12:27 PM
Tim H. is offline
Find More Posts by Tim H.
FoamyFactory.com
Tim H.'s Avatar
USA, TX, Fort Worth
Joined Nov 2001
Wow Clay! Great prices on the TP lipos. I just added a link to your site on mine. www.foamyfactory.com/links.htm You'll be getting an order from me soon!
Tim H.
vw63 - I would go with the TP 3s 2100 pack. That's what I'll be running on my 40" Ultimate Bipe with a Hacker B20-15L, 10x4.7 or 11x3.8
Tim H. is offline Find More Posts by Tim H.
Old Sep 24, 2003, 05:34 PM
Neil Morse is offline
Find More Posts by Neil Morse
Registered Snoozer
Neil Morse's Avatar
San Francisco, CA, USA
Joined Jul 1999
I've been flying my Switchback 3D with a B20-15L on 9 KAN950's with an APC 12X6 E prop with great success. I just bought my first Thunder Power 3S1P 2100 pack. I'm assuming I will have to prop down to avoid overheating the pack. What prop do people recommend? Thanks.
Neil
Neil Morse is offline Find More Posts by Neil Morse
Old Sep 24, 2003, 06:18 PM
Tim H. is offline
FoamyFactory.com
Tim H.'s Avatar
USA, TX, Fort Worth
Joined Nov 2001
Static Analysis - 40" UB
Sea Level, 70°F
Motor: Hacker B20 15L; 3704rpm/V; 0.064 Ohms; 0.7A idle.
Battery: TP 2100; 3 cells; 2100mAh @ 3.7V; 0.0033 Ohms/cell.
Speed Control: Castle Creations Phoenix 35; 0.0045 Ohms; High rate.
Drive System: APC 11-Inch Propellers; 10x3.8 to 11x4.7 (Pconst=1.11; Tconst=0.95) geared 4:1.
Airframe: 40" UB; 344sq.in; 17.5oz; 7.3oz/sq.ft; Cd=0.057; Cl=0.46; Clopt=0.65; Clmax=1.24.
NC Gear Diam Pitch Batt Motor Motor Input Output Loss Temp Motor Motor Elect Prop Thrust
..... Ratio (in) (in) Amps Amps Volts (W) (W) (W) (°F) Ef(%) RPM Ef(%) RPM (oz)
3 4.00 10.0 3.8 13.1 13.1 10.9 142.9 122.7 20.2 155.5 85.9 36668 84.4 9167 27.0
3 4.00 10.0 4.7 15.2 15.2 10.9 165.9 140.3 25.6 178.6 84.6 35720 82.9 8930 28.9
3 4.00 11.0 3.8 17.1 17.1 10.9 185.1 153.7 31.4 203.2 83.0 34809 81.2 8702 34.9
3 4.00 11.0 4.7 19.3 19.3 10.8 209.3 168.2 41.1 244.3 80.3 33414 78.3 8354 36.6
I would try a 10x4.7 and an 11x4.7
Tim
Old Sep 24, 2003, 06:42 PM
Registered Snoozer
Neil Morse's Avatar
Joined Jul 1999
Thanks, Tim. I will give those two choices a try and monitor my pack and motor temperatures carefully.
Neil
Old Sep 24, 2003, 08:11 PM
Ohio
Joined May 2003
I use the APC 10x6 Slow Flyer with my TP 3s 2100, Hacker BP20-15L and the Himax 4.3:1.
Thanks Tim. Is everything on your site free?
CM
FS: Hacker B20 + 4:1 vw63 Aircraft - Electric - Airplanes (FS/W) 7 Oct 14, 2003 09:14 PM
Does the hACKER b20 4:1 driveset need any running in? kajakmannen Scratchbuilt Indoor and Micro Models 4 Jul 23, 2003 05:01 PM
What Lithium poly for Hacker b20?? Steve H. Batteries and Chargers 7 Jan 22, 2003 07:32 PM
adapter for hacker B20 15L w/4:1 GB? wessman Sport Planes 6 Apr 26, 2002 10:03 PM
Need batt reco's for Hacker B20-12L 4:1 Kregg Electric Plane Talk 2 Jan 16, 2002 11:29 AM
