Old Oct 30, 2011, 03:41 PM
mrforsyth is offline
Find More Posts by mrforsyth
So. Cal.
Originally Posted by Tim Marks View Post
Using question 4 of the ss, inputting your PSU and battery info, the max output current will be 19.4A (worst case).
Presuming that the calc program assumes 90% DC-DC conversion efficiency to get this number?
4.2 X 5 X 10 / 12 / .9 = ~19.4A
Quick question - Do the PL8 and PL6 have charge lead voltage drop compensation? e.g. - When charging lipolys, does the charger switch from CC to CV mode when the main output reaches 4.2 x cell count or when the first cell reaches 4.2 volts as sensed by the balance lead?
Mark
mrforsyth is offline Find More Posts by mrforsyth
Old Oct 30, 2011, 05:35 PM
Tim Marks is offline
Find More Posts by Tim Marks
President, FMA, Inc.
Tim Marks's Avatar
Joined Mar 2008
Mark
Hi:
It's actually 85% efficiency (worst case).
40A input current limit
12V * 40A = 480W
480W * .85 = 408W available at output
408W / (4.2 * 5) = 19.4A
Tim Marks
Tim Marks is offline Find More Posts by Tim Marks
Old Oct 30, 2011, 06:42 PM
So. Cal.
Ok, I see that the calculation is based upon max input power limitation. Thanks Tim.
Have searched and still cannot find an answer to my above question:
"Do the PL8 and PL6 have charge lead voltage drop compensation? e.g. - When charging lipolys, does the charger switch from CC to CV mode when the main output reaches 4.2 x cell count or when the first cell reaches 4.2 volts as sensed by the balance lead?"
Mark
Old Oct 30, 2011, 08:21 PM
Gregor99 is offline
Find More Posts by Gregor99
Revolectrix Ambassador
Seattle
Joined Sep 2007
Voltage readings are taken without current flowing. There is no voltage drop when there is no current.
http://www.rcgroups.com/forums/showp...4&postcount=32
Gregor99 is offline Find More Posts by Gregor99
Old Oct 30, 2011, 08:31 PM
So. Cal.
Of course there is no voltage drop at zero current. This is not my question.
My question is: "When charging lipolys, does the charger switch from CC to CV mode when the main output reaches 4.2 x cell count or when the first cell reaches 4.2 volts as sensed by the balance lead?"
Mark
Old Oct 30, 2011, 08:33 PM
Gregor99 is offline
Seattle
Joined Sep 2007
If you have one FUIM2/FUIM3, you can use it with any number of Revolectrix products. Some like the idea, and I guess some don't.
Count my vote in the "like it" column. Also with the PL6 or 8, a single FUIM can be used to drive multiple chargers in expansion mode, or by adding a switch can be used to control and update either charger seperately when not in expansion mode. Switching between chargers does not require disconnecting and reconnecting the USB cable. Very handy when you need to perform a firmware update on both chargers.
Old Oct 31, 2011, 11:15 AM
Howard Matos is offline
Find More Posts by Howard Matos
AR-15 BRD!
Howard Matos's Avatar
Frederick, MD
Joined May 2002
PL8/PL6 Expansion Channel Video
PL8/PL6 Expansion Channel Video (10 min 34 sec)
Howard Matos is offline Find More Posts by Howard Matos
Old Oct 31, 2011, 11:31 AM
Tim Marks's Avatar
Joined Mar 2008
Mark
Hi:
To answer your question:
Before the first cell reaches 4.200V, the balancer is turned on. We use 1 amp balancers, which are the industry’s largest. This allows the other cells to catch up. Mostly the pack is balanced before CV occurs. But once the highest cell reaches the set charge voltage, the current starts reducing and CV begins.
Tim Marks
Old Nov 11, 2011, 09:04 PM
Tim Marks's Avatar
Joined Mar 2008
Whoop There It Is!
The first production unit, PL6...
Old Nov 12, 2011, 03:16 PM
teookie is offline
Find More Posts by teookie
Perfect 3pt inverted landing!
teookie's Avatar
USA, AL, Huntsville
Joined Oct 2008
Cool! Really excited to get mine.
teookie is offline Find More Posts by teookie
Old Nov 18, 2011, 02:08 AM
teeforb is offline
Find More Posts by teeforb
Joined Nov 2011
My Two PL6 shipped out today.
What's the expansion feature?
teeforb is offline Find More Posts by teeforb
Old Nov 18, 2011, 04:45 AM
ggcrandall1 is online now
Find More Posts by ggcrandall1
ggcrandall1's Avatar
USA, GA, Marietta
Joined Aug 2005
Your second PL6.
ggcrandall1 is online now Find More Posts by ggcrandall1
Old Nov 18, 2011, 08:53 AM
teeforb is offline
Joined Nov 2011
Originally Posted by ggcrandall1 View Post
Your second PL6.
I know it's for two, but I dont understand the point. What's wrong with just using them seperate?
Old Nov 18, 2011, 09:22 AM
teookie is offline
teookie's Avatar
USA, AL, Huntsville
Joined Oct 2008
My understanding is that expansion mode just makes it so you don't have to push so many buttons since the second charger "mirrors" the preset of the primary charger.
teeforb is offline
Joined Nov 2011
I spent a little more time to read the bullets. I'm not sure if I can capitalize off of this feature. I'll be running packs at different times
New Product Sneak Peek at the NEW Cellpro PowerLab 8 (v2) Tim Marks FMA Direct 6472 Yesterday 10:58 PM
New Product Introducing the ALL NEW Cellpro 10XP Charger Howard Matos FMA Direct 442 Apr 14, 2016 10:29 AM
New Product Introducing the Scirocco--All Molded, All Carbon Pitcheron Ward Hagaman Slope 180 Oct 04, 2014 09:43 AM
Sold Revolectrix/FMA direct Cellpro PowerLab 8 unused new thwang99 Aircraft - Electric - Batteries & Chargers (FS/W) 2 Aug 26, 2010 03:24 PM
Wanted Cellpro 4S 4amp Charger-New Version ( Found One--Thanks! ) helinut4ever Aircraft - Electric - Batteries & Chargers (FS/W) 1 Jan 27, 2009 04:24 PM
