Joined Jun 2003
PL6 Auto Current Mode Insufficient Current Levels
Hello fellow PowerLab 6 users.
Glen Crandall, points out in the PL6 thread: Quote:
Here is specific information about my problem with auto charge rates I referred to in the first quote above. teeforb may have been having a similar problem. Gregor99 suggested in Gregor99 suggested, see quote below, that the problem may be that the charger went into safety charge or low voltage restore. I would have received an error code or statement if this had happened. However, if the PL6 does not beep when an error comes up I would have not turned my head to see it. If so the message may have timed out, if the software does that. Quote:
In a PM Gregor99 said "That's not uncommon, especially in new packs that have not been broken in yet." As to this being uncommon see these posts by everydayflyer in the PowerLab 8 thread showing the expcted behavior of the PL6: 1.) Does Auto C really work? 2.) Showing A3C Refered to by Charles in this PL6 Post. If anyone is interested in checking the maximum charge current your PowerLab 6 reaches you can:
- Jim |
Joined Nov 2012
Buuhh CCS stopped working with windows 7, icon comes up but program window does not open
runs fine on my laptop with windows 8.. will try updating W7... Edit: updating did not help, seems to be running .NET Framework 4 Client Profile anybody any clues? |
Seattle
Joined Sep 2007
By the way were able to test in set current mode? Did the actual current reach the set current? |
Joined Jun 2003
Re: PL6 Auto Current Mode Insufficient Current Levels
Tim Marks please comment on my previous post and this post. - Jim ![]()
How do the individual cell voltage track if you check the cell voltage graph? Auto mode will base it's calculations on the actual capacity of the battery pack, not what it says on the label. As packs age, of if there are QA issues with the pack or pack brand, it may not always track the way you expect. Do you see this issue with one pack, one brand, or across multiple packs/brand? If the packs are out of balance, this could be an indication that you have one or more weak cells in the pack. In this case, balance issues can result in the PL seeing the pack as having much lower capacity than what the label reads. If you have a pack that does not come close to what you feel the nominal C rate charge should be, the individual cell voltage graph could provide some clues as to why this is happening. FYI, I would like to add the caveat that Auto mode generally works pretty well, but it's not an exact science. I have had customers with similar complaints. But even after working with them for some time, helping them generate custom fuel tables, etc, they don't always get the results they wish to attain on certain battery packs. In the end, this situation tends to end up in an unsolved mystery to me. Usually, if it goes this way, in the end, the customer elects to go one of two ways for those particular batteries: 1) set charge rate for manual charge rate 2) use a higher Auto rate. For examle, if your hope was to achieve a 1C rate using Auto, instead set the PL for Auto 2C or 3C and see what you get. You might find that it consistently results in the 1C rate you were attempting to achieve. Auto rate is a convenience feature we added to our products, mostly for customers who are not well versed about how to choose charge current properly or who do not wish to take advantage of the vast capabilities of the products by establishing optimal presets for multiple charging scenarios. It's a difficult feature to implement because the charge/discharge curve of Li technology batteries is extremely flat. As LiPo manufacturers have packed more and more capacity into the cells, altered the chemistries to allow for higher charge/discharge rates, the challenges continue to mount. Also, you may have mentioned it, but I didn't read any information concerning your power supply setup. What are you using to power the PL? Where do you have the input current limit and low voltage setttings set? (smart power manatement features) It could be useful information to make sure there is not the potential for that to be contributing to the situation you describe. Tim Marks |
Seattle
Joined Sep 2007
Joined Jun 2003
Does the above happen with the PowerLab 8 as well? I am working on doing the charging again. I'll provide graphs and other information when I post them. As far as the power supply is concerned:
| Thread Tools | |
| New Product Introducing the ALL NEW Cellpro 10XP Charger | Howard Matos | FMA Direct | 309 | May 16, 2013 07:02 PM |
| New Product Sneak Peek at the NEW Cellpro PowerLab 8 (v2) | Tim Marks | FMA Direct | 5311 | May 11, 2013 12:57 PM |
| New Product Introducing the Scirocco--All Molded, All Carbon Pitcheron | Ward Hagaman | Slope | 174 | Nov 16, 2012 08:40 AM |
| Sold Revolectrix/FMA direct Cellpro PowerLab 8 unused new | thwang99 | Aircraft - Electric - Batteries & Chargers (FS/W) | 2 | Aug 26, 2010 03:24 PM |
| Wanted Cellpro 4S 4amp Charger-New Version ( Found One--Thanks! ) | helinut4ever | Aircraft - Electric - Batteries & Chargers (FS/W) | 1 | Jan 27, 2009 04:24 PM |
