Old Aug 29, 2012, 05:31 PM
viperman3 is offline
Find More Posts by viperman3
Joined Feb 2012
Originally Posted by ggcrandall1 View Post
Monitor mode will only check pack and cell volts. It will not show IR.
Glen
So the PL6 does not show IR. Does the PL8 show IR? I am asking because I'm in the process of making a purchase ... either the PL6 or the PL8. Just need to know what the differences between chargers are.
viperman3 is offline Find More Posts by viperman3
Old Aug 29, 2012, 05:55 PM
Turner2 is offline
Find More Posts by Turner2
Tallahassee, FL
Joined Sep 2009
PL6 calculates IR during charging.
Turner2 is offline Find More Posts by Turner2
Old Aug 29, 2012, 06:39 PM
Gregor99 is offline
Find More Posts by Gregor99
Revolectrix Ambassador
Seattle
Joined Sep 2007
As Turner correctly says, IR is calculated during charging. There is no need to use a special mode to get the pack IR. Just read during a charge. You can also do a short charge to get the IR on pack that you just want to take a reading on. Both the Powerlab6 and the Powerlab8 operate the same way with regard to IR.
Gregor99 is offline Find More Posts by Gregor99
Old Sep 14, 2012, 08:05 AM
cirrus_uk is offline
Find More Posts by cirrus_uk
cirrus_uk's Avatar
United Kingdom, London
Joined Mar 2012
would appreciate some advice. I've decided to get the CellPro 6 but can't get my head round the connectors/adapters. My current set up is as follows.
All my lipos have a JST-XH balance connector.
I have a Parallel balance board which has a 200mm 6S JST-XH connector.
My charger is a cheap GT power charger. I can plug the parallel board connector directly into the charger.
If I buy the CellPro 6, am I right in thinking I can't plug the parallel board directly into the Cellpro 6 port? I need to either chop the 200mmm JST connector off and replace with a Cellpro one (don't want to do this as won't work in my other charger) or use a cellpro adapter? What adapter do I need here?
I'd also need to run the charger in XH mode? Do I lose any features doing this?
cirrus_uk is offline Find More Posts by cirrus_uk
Old Sep 15, 2012, 03:05 PM
cirrus_uk's Avatar
Joined Mar 2012
bump
Old Sep 15, 2012, 05:39 PM
Gregor99 is offline
Seattle
Joined Sep 2007
Its possible the parallel board you are describing can be adapted to work with the Powerlab. Dave and Progressive sells interconnect cables with the FMA style end and the JST-XH connector on the other end. However there are a couple different wiring schemes being used making it hard to know which interconnect cable to use. You could get an FMA pigtail and solder it in parallel to the existing connector so the board could be used with both chargers. Not all 9 wires are needed. Only the first 7. Remove the uneeded wires.
However I suspect your board is not fused which is a concern. The Revolectrix MPA is a direct connect to the Powerlab and you can get an seperate interconnect so it can also work with your other chargers.
Old Sep 15, 2012, 06:07 PM
cirrus_uk's Avatar
Joined Mar 2012
cheers for reply. Yes I am planning to upgrade to the fused para board ASAP.
Do I lose any features running the charger in XH wiring mode? vs. FMA
Also am I right in thinking If I get one of the standard FMA adaptors I can just plug the 6 pin cable from my current para board into the 6s port on the FMA adapter board?
Old Sep 15, 2012, 09:14 PM
Gregor99 is offline
Seattle
Joined Sep 2007
With XH mode you lose node only or charge lead only charging on the Powerlab8. Both features aren't on the Powerlab6 except for the small unbalanced preset.
Nope. The FMA boards use FMA wiring which are not going to work with the para board.
Old Dec 24, 2012, 02:21 PM
JimHSoars is online now
Find More Posts by JimHSoars
United States, OK, Tulsa
Joined Jun 2003
LiPolys w/ Cellpro JST PA Balance (Node) Plug
Hello:
I have a few Cellpro LiPolys with the original Cellpro balance plug, JST PA. What adapter do I need for such batteries which have less than 6 cells? (Mine are 3S.) Which PL6 combos come with this adapter?
- Jim
JimHSoars is online now Find More Posts by JimHSoars
Old Dec 24, 2012, 05:40 PM
Gregor99 is offline
Seattle
Joined Sep 2007
Jim,
I believe this is the right combo. But the pictures of the adapters don't match the specs listed in the combo. This will give you the USB cable (important) and two FMA safe adapters which allows you to parallel charge with fused balanced connectors.
http://www.usastore.revolectrix.com/...-PA-Adapters_2
If you also have a lot of JST-XH packs, it may be better to get a combo with the JST-XH adapters then add a JST-PA adapter.
Old Jan 09, 2013, 02:06 PM
Joined Jun 2003
Thanks Gregor99. I asked when I ordered my PL6 and Jamie added a single battery JST-PA adapter to the order.
Old Jan 10, 2013, 12:52 PM
Joined Jun 2003
Multi4 Fuel Tables in PL6
Hi:
Will the PL6 use fuel tables generated with a Multi4?
- Jim
Old Jan 10, 2013, 01:51 PM
Tim Marks is offline
Find More Posts by Tim Marks
President, FMA, Inc.
Tim Marks's Avatar
Joined Mar 2008
Originally Posted by JimHSoars View Post
Hi:
- Jim
Hi:
The answer is NO. Every model uses different Fuel Tables.
Tim Marks is offline Find More Posts by Tim Marks
Old Jan 15, 2013, 04:57 PM
apper001 is offline
Find More Posts by apper001
Switzerland, ZH, Zürich
Joined Nov 2012
cycle charge/discharge
during the cooldown period the fan stays on and only stops after 60 seconds in the next charge cycle? does not matter if the cool down period is 2 or 5 minutes?
apper001 is offline Find More Posts by apper001
Old Jan 15, 2013, 11:24 PM
Tim Marks's Avatar
Joined Mar 2008
Hi:
If I understand your question, this is not an issue. The fans are controlled by a thermistor on the PCB that monitors critical temperature. The fans come on only when they are required to keep the PL running cool. Does this answer your question?
Tim Marks
New Product Sneak Peek at the NEW Cellpro PowerLab 8 (v2) Tim Marks FMA Direct 6415 Today 05:50 AM
New Product Introducing the ALL NEW Cellpro 10XP Charger Howard Matos FMA Direct 442 Apr 14, 2016 10:29 AM
New Product Introducing the Scirocco--All Molded, All Carbon Pitcheron Ward Hagaman Slope 180 Oct 04, 2014 09:43 AM
Sold Revolectrix/FMA direct Cellpro PowerLab 8 unused new thwang99 Aircraft - Electric - Batteries & Chargers (FS/W) 2 Aug 26, 2010 03:24 PM
Wanted Cellpro 4S 4amp Charger-New Version ( Found One--Thanks! ) helinut4ever Aircraft - Electric - Batteries & Chargers (FS/W) 1 Jan 27, 2009 04:24 PM
