Seattle
Joined Sep 2007
Take a look at the PL8 and PL6 in these pictures. My comments were about the PL8 which has two feet in the rear. For the front area of the charger I was going to only add one small square of dual lock, right in the center on the bottom. But now I think about it, the charger would probaly rock side when using the buttons. So after rethinking it, I'd either use two in the front (one on each corner), or nothing at all since the rear ones may be strong enough. I need to get the case together first then I'll start testing to see what works.
Joined Nov 2011
this will work, correct?
http://www.radioshack.com/product/in...ductId=2103345 i believe it's the same as 3m dual lock. |
Seattle
Joined Sep 2007
To be honest, it will probably be fine. If were me, I'd solder. I like overhead when its comes easy and inexpensively. Now that you've gone to all that trouble, with the crimps and nice coverings, I'd test at 15 amps and take a measurement with your IR gun. If you get some heating consider soldering. Otherwise you are good to go. Are you running both supplies through that one plug? Or do you have two plugs?
Joined Nov 2011
Yes, both supply on one AC cord. I talked to a rep at meanwell. He says my power supply runs on AC at 10.1A each at full throttle (1000w). Since the power supply is 27v, the max I can occupy with the pl6 is around 816w. Which is around 80% of 1000w. So Im thinking around 16A (8A each) with the chargers full power, using those 816w each. Also, I'm sure (I hope) I won't be maxing both chargers at the same time. |
Seattle
Joined Sep 2007
Those IEC connectors are only rated for 15 amps. But that is not where the problem is. PC power cords are typically rated at less than 15. Some as little as 8 amps. I did notice some warming on my smaller cords. Which is why I going with this thing and a heavy duty extention cable on my next case.
Joined Nov 2011
Hey guys,
I believe i am finished my setup. I haven't even charged a battery yet and i'm in shock in awe. You guys are right, this charger is very VERSATILE when connected to the computer! Can't wait til my first charge. Hope all goes well. I have been SLOWLY working on this system Nov 10th, when i first inquired about it. Since then, 92 posts full of questions. You guys are extremely helpful and I really appreciate it! |
Joined Nov 2011
Hi Tim,
i finally was able to start some charging. However, i am finding a few issues. as you know, i have two power supplies (RSP-1000-27) and two PL6 (each on their own power supplies). One charger charges just fine. But the other charger, i seem to have problems with. It keeps on resetting, saying SVS reset or something like that. I tried turning off the charger and turning it back on, same thing. another issues i am having, i can not series charge. I got the series charge system from EPbuddy.com. I checked the voltages, and everything seems fine and connected. WHen it check for cell count, it errors out and says something about FMA wire and i believe it says voltage HI/LO... please help! edit: I tried swapping power supplies, and the issue still exist for the same charger.. thanks |
I don't think your EPBUDDY adapter is series. It's parallel. Have you wired it to the FMA balance connector correctly? Have you set the PL6 Node wiring to XH/EH mode? See the Options tab in the CCS. Glen |
| Thread Tools | |
| New Product Sneak Peek at the NEW Cellpro PowerLab 8 (v2) | Tim Marks | FMA Direct | 5328 | Today 09:56 AM |
| New Product Introducing the ALL NEW Cellpro 10XP Charger | Howard Matos | FMA Direct | 309 | May 16, 2013 07:02 PM |
| New Product Introducing the Scirocco--All Molded, All Carbon Pitcheron | Ward Hagaman | Slope | 174 | Nov 16, 2012 08:40 AM |
| Sold Revolectrix/FMA direct Cellpro PowerLab 8 unused new | thwang99 | Aircraft - Electric - Batteries & Chargers (FS/W) | 2 | Aug 26, 2010 03:24 PM |
| Wanted Cellpro 4S 4amp Charger-New Version ( Found One--Thanks! ) | helinut4ever | Aircraft - Electric - Batteries & Chargers (FS/W) | 1 | Jan 27, 2009 04:24 PM |
