Old Nov 17, 2011, 01:45 PM
dazza44 is offline
Find More Posts by dazza44
who put that tree there
dazza44's Avatar
Joined Jun 2010
this is one of the easiest explained builds with great pics to help..
no need for any thing else..
and flies as good as well..
dazza44 is offline Find More Posts by dazza44
Old Nov 17, 2011, 06:23 PM
VoyagerXll is offline
Find More Posts by VoyagerXll
VoyagerXll's Avatar
Bloomfield. Nebraska
Joined Jun 2009
I agree with what others have said about the ease of building this plane with the plans given. It very easy to draw straight lines of the given dimensions then cut them out and glue everthing together. Once that is all done and the electronics are in one will have one of the nicest flying planes to park in your hangar
Thanks again for the plans.
VoyagerXll is offline Find More Posts by VoyagerXll
Old Nov 17, 2011, 10:28 PM
mrexcel is offline
Find More Posts by mrexcel
mrexcel's Avatar
Joined Jul 2009
I asked whether has anyone created tiled plans, not because I cannot build this model by looking at the build log. I was trying to create some tiled plans if none has done it so far. Having tiled plans, gives you the flexibility of rescaling the model for various power setups with ease. I personally believe having tiled plans are always better than not having them at all.
mrexcel is offline Find More Posts by mrexcel
Old Nov 18, 2011, 12:07 AM
how much is online now
Find More Posts by how much
how much's Avatar
United Kingdom, England, Wigan
Joined Jul 2011
mrexcel
a valid point regarding having a CAD file for the "wot-next" it would allow scaling the model size up/down to suit a particular power set-up. though it will fly with quite a wide range of motors as it is.
if anyone wants to draw it up please feel free to do so!
David
how much is online now Find More Posts by how much
Old Nov 18, 2011, 02:21 AM
domll is offline
Find More Posts by domll
domll's Avatar
Norwich.uk.
Joined Oct 2007
Originally Posted by how much View Post
mrexcel
David
Okay, here are some Sketchup drawings i've done, should be self explanatory.
If someone could 'Pdf' them that would be grand.
domll is offline Find More Posts by domll
Old Nov 18, 2011, 08:23 AM
potshot is offline
Find More Posts by potshot
Vertical approach specialist
potshot's Avatar
Northeastern Illinois
Joined Mar 2009
If you'll export those to DXF, I'll make AutoCAD and PDF versions.
potshot is offline Find More Posts by potshot
Old Nov 18, 2011, 02:07 PM
domll is offline
domll's Avatar
Norwich.uk.
Joined Oct 2007
Here's the DXF zipped file.
Old Nov 18, 2011, 04:11 PM
potshot is offline
potshot's Avatar
Joined Mar 2009
Thanks, domll. The AutoCAD .dwg is in the Zip file.
Edit: Files updated 26 Nov. 2012
Old Nov 19, 2011, 01:51 AM
how much's Avatar
Joined Jul 2011
Dom, Potshot
many many thanks for sorting the plan to CAD.. nice job!
i will move them up to the begining of the thread
David
Old Nov 19, 2011, 02:17 AM
mrexcel is offline
mrexcel's Avatar
Joined Jul 2009
Wonderful stuff!
Old Nov 19, 2011, 02:18 AM
mrexcel is offline
mrexcel's Avatar
Joined Jul 2009
I am going to build a version using a CD-ROM motor.
Old Nov 19, 2011, 10:41 AM
mrexcel is offline
mrexcel's Avatar
Joined Jul 2009
I just completed a 24.8" inch model. Power system is HK 10 gram motor (1811-2000). I am planning to test fly this tomorrow morning with our regular flying session. Will post some videos and photos tomorrow.
Old Nov 19, 2011, 11:10 PM
potshot is offline
potshot's Avatar
Joined Mar 2009
Sounds good. I've had that in mind for a while. What thickness of foam, and how much does it weigh all up? Looking forward to the video and fight report.
Old Nov 20, 2011, 12:40 AM
mrexcel is offline
mrexcel's Avatar
Joined Jul 2009
I test flew it in the morning. It flew from the first launch itself. I will post a video of it here soon.
The AUW came to 115 grams with a 450mah 2S Lipo. Plenty of power. Great model.
Old Nov 20, 2011, 12:41 AM
mrexcel is offline
mrexcel's Avatar
Joined Jul 2009
I did a small mod though. I used a mono block for the motor.
Wanted Wot Trainer St3v3 Aircraft - Fuel - Airplanes (FS/W) 0 Sep 29, 2011 08:06 AM
Discussion Trainer with aileron depron plan please... luconedj Beginner Training Area (Aircraft-Electric) 1 Apr 27, 2010 02:47 PM
Discussion Next model after aileron trainer? norite Beginner Training Area (Aircraft-Electric) 10 Jun 28, 2006 02:53 PM
Help! Next plane?....Need aileron trainer--- TurkeyTx Parkflyers 8 Feb 15, 2006 10:40 PM
Dandy Sport - aileron Trainer CoClimber Parkflyers 143 Apr 16, 2003 07:34 PM
