Old Nov 14, 2011, 12:08 PM
how much is offline
Find More Posts by how much
how much's Avatar
United Kingdom, England, Wigan
Joined Jul 2011
Originally Posted by mrexcel View Post
Great model.
Original design is without any aerofoil?
yes... its a 6mm depron "plank" to keep things simple!
dont be put off by that... honest it flies way better than you would expect..
with a very wide and forgiving flight envelope, has a really soft stall with no tendancy to tip stall
David
how much is offline Find More Posts by how much
Old Nov 14, 2011, 12:39 PM
domll is offline
Find More Posts by domll
domll's Avatar
Norwich.uk.
Joined Oct 2007
Originally Posted by how much View Post
Dom
that looks a really neat job, not a lot left to do at that stage. if you are going to do the carbon pushrods like mine then drop another former in the fuselage halfway between the tailplane and the back of the servo tray, it will help support the pushrods in the middle,
extra former can be seen in this photo..
took my two to the club field for the first time today, it was really windy and nobody wanted to fly... till i let them all have a go with the wot nexts... they were all impressed how well they flew on such a windy afternoon
now they all want one!
David
Did notice the extra former in earlier pictures, thought it was to aid keeping fuselage in shape whilst marking out top/bottom skins, now i know why
Also going with the Emax 2812 on 9x5 but with two cells, still should deliver 19oz of thrust, few options available;
http://www.headsuprc.com/servlet/the...ushless/Detail
domll is offline Find More Posts by domll
Old Nov 14, 2011, 12:45 PM
dazza44 is offline
Find More Posts by dazza44
who put that tree there
dazza44's Avatar
Joined Jun 2010
[QUOTE=VoyagerXll;19872057]Thanks Dazza
I went back to see your rendition of the "Wot Now"...... Cool wings on yours. How does it turn with the wing you used?
I have enough problems flying when it gets towards dusk, I tend to loose orientation, so do not think flying with lights in the dark would work for me.
The emax 2822 w/ 9x5 prop gives me all the power I need. I went out this morning to fly mine but before I got coffee finished and plane ready the wind was starting to blow I flew it for about 4 minutes. It was pretty gusty and the plane was getting buffeted quite a bit so decided to land and wait for a calmer day................sure did not want to crash it so early in its life.
My nephew saw mine flying yesterday and said that he is going to build one too.
it turns surprising well put ailerons 2 thirds wing length from fuze outward best way could get enough control..
im new to the night flying had 3 flights finding it pretty easy using red n blue strip on top and green underneath orientation a lot easier..shall get a vid if i can find another looney to stand n film it in the cold..brrrrrrrr
dazza44 is offline Find More Posts by dazza44
Old Nov 14, 2011, 12:55 PM
how much is offline
how much's Avatar
Joined Jul 2011
am running 1800kv motor, 8 x 3.8sf prop on 1000ma 3cell lipo
it goes vertical like a rocket
but spends most of its time chuffing round on 1/3rd throttle
D
Old Nov 15, 2011, 08:55 PM
mrexcel is offline
Find More Posts by mrexcel
mrexcel's Avatar
Joined Jul 2009
Has anyone managed to put up some tiled plans yet?
mrexcel is offline Find More Posts by mrexcel
Old Nov 15, 2011, 09:51 PM
Wilfor is offline
Find More Posts by Wilfor
RC Adddict
Wilfor's Avatar
Canada, BC, Williams Lake
Joined Jan 2010
Not really needed if you download Adobe Reader X , you can resize and tile to anysize you like
Wilfor is offline Find More Posts by Wilfor
Old Nov 15, 2011, 11:05 PM
mrexcel is offline
mrexcel's Avatar
Joined Jul 2009
I could only see hand drawn plans. Did I miss something?
Old Nov 16, 2011, 12:14 AM
domll is offline
domll's Avatar
Norwich.uk.
Joined Oct 2007
Plans are very easily draw straight onto the depron, save's paper and time.just follow the instructions at the beginning of the thread.
Old Nov 16, 2011, 12:31 AM
mrexcel is offline
mrexcel's Avatar
Joined Jul 2009
What mods should I make to match this model for the following power setup?
http://www.hobbyking.com/hobbyking/s...idProduct=4854
Old Nov 16, 2011, 09:55 PM
Wilfor is offline
RC Adddict
Wilfor's Avatar
Joined Jan 2010
nope my bad . You were asking for tiled plans so i assumed some full size had been added , i never actually looked
Old Nov 17, 2011, 11:08 AM
how much is offline
how much's Avatar
Joined Jul 2011
CAD files are not necessary for this plane... go back to the start of the build log and you will see that all you have to do is cut out 7 or 8 rectangles to the dimensions given.. then trim each rectangle as instructed to make each piece.
it really is that simple.
[quote=mrexcel What mods should I make to match this model for the following power setup?
[url]http://www.hobbyking.com/hobbyking/s...idProduct=4854[/url] ]
simple answer... i dont know! why not choose something that resembles what other builders have chosen? you have all the information at your fingertips, model weight, power/esc/props etc. that have been used
David
Old Nov 17, 2011, 11:17 AM
mrexcel is offline
mrexcel's Avatar
Joined Jul 2009
If this to be a good build log like BB 33, having access to proper set of plans in PDF format is a must. Otherwise this thread will die somewhere couple of more posts down. BB 33 the immense success in that thread is that, they have all the information for anyone.
Why I want to modify this model for my motor is very simple. I have about 10 motors from that model just lying at our model flying club. There is no reason for us to bring down another set of motors as a result.
Old Nov 17, 2011, 12:12 PM
potshot is offline
Find More Posts by potshot
Vertical approach specialist
potshot's Avatar
Northeastern Illinois
Joined Mar 2009
IMHO, how much has done a fine job with this build log. He's been very generous with his time answering questions and providing information. In the absence of any hard and fast rules for build logs, I'd say he's given us an exemplary effort. I'd call it more than a "good" build log, to say the least.
potshot is offline Find More Posts by potshot
Old Nov 17, 2011, 12:55 PM
Don Bourdon is offline
Find More Posts by Don Bourdon
Don Bourdon's Avatar
United States, NC, Cajah's Mountain
Joined Oct 2006
Ditto what potshot said.
No problem building this plane from the info in the first posts of this thread.
Don Bourdon is offline Find More Posts by Don Bourdon
Old Nov 17, 2011, 01:23 PM
how much is offline
how much's Avatar
Joined Jul 2011
Potshot, Don
thankyou for the kind words...
mrexcel you have a very important personal message
thanks
David
Wanted Wot Trainer St3v3 Aircraft - Fuel - Airplanes (FS/W) 0 Sep 29, 2011 08:06 AM
Discussion Trainer with aileron depron plan please... luconedj Beginner Training Area (Aircraft-Electric) 1 Apr 27, 2010 02:47 PM
Discussion Next model after aileron trainer? norite Beginner Training Area (Aircraft-Electric) 10 Jun 28, 2006 02:53 PM
Help! Next plane?....Need aileron trainer--- TurkeyTx Parkflyers 8 Feb 15, 2006 10:40 PM
Dandy Sport - aileron Trainer CoClimber Parkflyers 143 Apr 16, 2003 07:34 PM
