Old Nov 04, 2011, 02:33 AM
how much is offline
Find More Posts by how much
how much's Avatar
United Kingdom, England, Wigan
Joined Jul 2011
Originally Posted by jellwalt View Post
Hello HOW MUCH
Love your design of the WOT NEXT foamy and the elaborate plans you offered to us foam guys. One question that bothers me is the call out for the cutting layout of the top and bottom pieces...i.e. "26" x 2.9/16". Do you mean it should be 2,9 inches wide? What does the "/16" add-on mean?
Thank you for a truly cool design!!
Walt Jellison
jellwalt@cox.net
jellwalt
good spot... the 2 and 9/16" width of the top and bottom panels is a deliberate "oversize"
the nominal width of the fuselage is 2 and 1/2" but with variances in material thickness and the accuracy with which the 2" wide fuselage formers and servo tray have been cut will all effect the final width of the fus.
so i deliberately designed the panels slightly oversize so you can....
"trim to fit on final assembly"
saves wasting that 2.1/2" wide strip you just cut that is slightly undersize
David
how much is offline Find More Posts by how much
Old Nov 04, 2011, 02:38 AM
how much is offline
how much's Avatar
Joined Jul 2011
Originally Posted by dazza44 View Post
took my taube wot next out other day for test flight wow flew very well..
put an emax 2228 motor and 8x4 apc 1500 3 cell lipo .. 618g thrust plenty of power to spare,pushed most electrics in front as to fit my battery under the wing..final flying wieght was 13.75 oz..
just needing a paint job now,mmmmmmm red n yellow sounds good..
great design and thanks for sharing..
daren
edit...finished paint job opted for red n white looks better
Daren
the "Wot-Taube" is just brilliant.... I love it!
David
Old Nov 04, 2011, 08:28 AM
Don Bourdon is offline
Find More Posts by Don Bourdon
Don Bourdon's Avatar
United States, NC, Cajah's Mountain
Joined Oct 2006
Daren,
+1 -- Nice job
Don
Don Bourdon is offline Find More Posts by Don Bourdon
Old Nov 05, 2011, 03:55 AM
how much is offline
how much's Avatar
Joined Jul 2011
Originally Posted by sidecar53 View Post
Does anyone have a link for instructions to help someone transition from RET to ailerons? I figure it'd be an advantage to read about it before I try to fly one. Thanks again.
Sidecar
sorry i didn't respond to your question sooner.... busy day! anyway, i had a trawl through the beginers section and couldnt find what i was looking for, only plenty of "differences of opinion" about how it all works, so had a look elsewhere.
this link tells you how the individual control surfaces effect your direction of flight, the animated controls at the bottom are neat!
http://www.allstar.fiu.edu/aero/fltmidcont.htm
now you know how it works... what does it mean going from RET?
well a lot more fun for a start your RET trainer would have a dihedral wing and be "self righting" in so much that after a gentle turn and the controls returned to neutral it would try to get itself back the right way up.
now you will be rolling the aircraft into a turn with the ailerons (and pulling it through the turn with the elevator) when it is banked over it will stay banked over... you basically put the roll on then take the roll off to re-level the wings
dont be intimidated by this, you will have already been doing this with your RET. as you will have had your rudder servo plugged into your aileron channel (tx stick) anyway, so your thumb should already be tuned in to doing this. just try not to "over-control" it and you will be ok
the "wot next" has very nicely balanced controls and will be ideal for the job, it might help if you could get an experienced flyer to "trim" the model on its test flight so it flys straight and true... hands off
good luck, lets see some photos and let us know how you get on
David
Old Nov 05, 2011, 05:38 AM
domll is offline
Find More Posts by domll
domll's Avatar
Norwich.uk.
Joined Oct 2007
Hi how much, How's sunny Wigan, lived there till i was 14yrs, many fond memories. Do they still have the under cover indoor market?
I've had problems getting the Solartrim to stick in areas and it bubbles up, usually on the non shinny side, any ideas.
domll is offline Find More Posts by domll
Old Nov 05, 2011, 06:07 AM
how much is offline
how much's Avatar
Joined Jul 2011
hi Domll
Wigan is fine thankyou, dont know how long since you left but the town centre just looks the same as every other town centre (except hilly) same shops in the same non-descript precincts!
dont know why you are having trouble with your solartrim? it sticks like sh** to a blanket on depron! sounds like you may have some contamination on your foam, try washing it off and drying it before applying your trim
these two depron sea-bbs i built only gets flown off water and have had no trouble with the solartrim..
David
Old Nov 05, 2011, 06:25 AM
domll is offline
domll's Avatar
Norwich.uk.
Joined Oct 2007
1982, guess it has changed now.
Thanks for that, will clean a piece of depron and try.
One last question, how far forward of the CG did you place the wheels?
Old Nov 05, 2011, 07:32 AM
Aero Andy is offline
Find More Posts by Aero Andy
ExPat
Aero Andy's Avatar
Spain, Murcia, Mazarrón
Joined Apr 2010
David
Oooooooooooooooohhhhhh, they are so beautiful....
Andy
Aero Andy is offline Find More Posts by Aero Andy
Old Nov 05, 2011, 08:50 AM
how much is offline
how much's Avatar
Joined Jul 2011
Domll
i sewed the piano wire onto a scrap of 1/16" ply and stuck the ply plate onto the underside of the fuselage with double sided servo tape
the wheel axles are about 1 and 1/4" in front of the leading edge of the wing
dont forget to fit a tail skid to protect the rudder
have been out flying the prototype again this morning, it was a grey, miserable, windy and cold, November morning...
flew every lipo pack i own through it.. my fingers were yellow with the cold
but i was having so much fun! big loops into rolls,into reversals, race down wind then straight up into a stall turn... then more of the same
David
Old Nov 05, 2011, 09:05 AM
dazza44 is offline
Find More Posts by dazza44
who put that tree there
dazza44's Avatar
Joined Jun 2010
i put my wheel axels sandwiched in two pieces of foam and insert into fuze glued against one of the formers..
works a treat and is quite sturdy.
was out today in the cold too frozen fingers.
also went out about 11pm last nite had first night flight was easy as flying in the day..
dazza44 is offline Find More Posts by dazza44
Old Nov 05, 2011, 10:47 PM
VoyagerXll is offline
Find More Posts by VoyagerXll
VoyagerXll's Avatar
Bloomfield. Nebraska
Joined Jun 2009
I have almost completed my Wot-n-Fokker. I down sized the plans to a 30 inch Wing span. AUW is 12.2 oz I have installed an Emax 1600kv 2805 motor with a 9X5 orange prop. I am quite confident that this set up will be adequate. All that is left is to get the ailerons connected to the servo. I am going to run my control arms above the wing. Not as neat looking but my receiver is where the wires should go, so rather than mess with that will go on top. I am not going to add a landing gear,since I fly in front of my house and do not have a smooth enough area for a landing strip. Too big of stones in the gravel on the drive way to take off on. I liked the "original" Wot-n-Fokker so much that I copied it the best I could. Even if I had the plane done I could not fly as the wind has been blowing really strong the last two days. Hoping tomorrow will be better
Stan
VoyagerXll is offline Find More Posts by VoyagerXll
Old Nov 06, 2011, 02:15 AM
how much is offline
how much's Avatar
Joined Jul 2011
Stan
your wot-a-fokker looks excellent! i am sure it will fly as good as it looks..
you have done a great job, let us know how the flying goes? i am sure you will be rushing back into the house to recharge the batteries so you can have another fly
i flew the wings off both mine yesterday despite the poor weather! i think the original one without wheels flies better than Baron von Wingovers... not sure if its the undercart or the really horrible cheapo servos in the barons that are the cause.
lets us know all about it
David
Old Nov 06, 2011, 02:37 AM
domll is offline
domll's Avatar
Norwich.uk.
Joined Oct 2007
I have all the parts cut but need to get some dowel tomorrow. Your hinges look very clean lined, are you using the solar trim for the hinge as i don't see tape on the underside?
Old Nov 06, 2011, 03:09 AM
how much is offline
how much's Avatar
Joined Jul 2011
dom
do not put tape or trim accross the hinge.. its just the line of uhu por glue as shown in the build instructions that hinges the ailerons,elevator, & rudder
trust me it works just fine!
6mm dowel is £2 for an 8ft length at B&Q.. enough for 2 wots!
David
Old Nov 06, 2011, 03:31 AM
domll is offline
domll's Avatar
Norwich.uk.
Joined Oct 2007
Thanks, must have missed that, getting ahead of my self. B&Q here we come...
Wanted Wot Trainer St3v3 Aircraft - Fuel - Airplanes (FS/W) 0 Sep 29, 2011 09:06 AM
Discussion Trainer with aileron depron plan please... luconedj Beginner Training Area (Aircraft-Electric) 1 Apr 27, 2010 03:47 PM
Discussion Next model after aileron trainer? norite Beginner Training Area (Aircraft-Electric) 10 Jun 28, 2006 03:53 PM
Help! Next plane?....Need aileron trainer--- TurkeyTx Parkflyers 8 Feb 15, 2006 11:40 PM
Dandy Sport - aileron Trainer CoClimber Parkflyers 143 Apr 16, 2003 08:34 PM
