Espritmodel.com Heli Air
Old Oct 30, 2011, 02:26 PM
Don Bourdon's Avatar
United States, NC, Cajah's Mountain
Joined Oct 2006
Hi Guys,
Went to the field today with my blu-WOT. Several of my instructor FBs put this plane through it paces. Did everthing but knife edges and 3D. We literally flew the wheels, well one wheel anyway, off this plane today. Unfortunately the plane is now grounded until I can get some new wheels.
What a great little plane.
Thanks again David for a great design.
Don
Don Bourdon is offline Find More Posts by Don Bourdon
Old Oct 31, 2011, 12:45 PM
how much's Avatar
United Kingdom, England, Wigan
Joined Jul 2011
Don
glad you had a good day with the wot-next.. dont go letting everyone fly it!
you will wear it out!
infact point them in the direction of this thread and tell them to make their own
re-drew the plans for a 24" span version made out of 3mm depron for indoor flying on 2 cells this morning. bigger control surfaces tho' cos this one is for me!
will post details when i get to it
David
how much is offline Find More Posts by how much
Old Oct 31, 2011, 04:31 PM
United States, CA, Folsom
Joined Jun 2011
I am thinking of re-using the wing from this plane http://www.rcgroups.com/forums/showp...&postcount=399 with WOT's fuse.....
radhav is offline Find More Posts by radhav
Old Oct 31, 2011, 04:40 PM
how much's Avatar
Joined Jul 2011
dont see why not... i would cut the dihedral tips off though and just use the 32" middle bit.
the wot next would suit a variety of wings.. flat like the one i used, wing section like Dons, or kfm... all will work.
its surprising how well it flies with the flat single 6mm depron wing i used in the design.
David
Old Nov 01, 2011, 08:15 PM
Canada, ON, Windsor
Joined Sep 2008
Would this plane fly with a blue wonder motor? I have a few sitting around. While we're at it what size would I have to go to use a 2408-21t H-K motor? I'd like to build one and fit a set of skis to it for flying in winter. Thanks for any and all responses.
sidecar53 is offline Find More Posts by sidecar53
Old Nov 02, 2011, 01:05 AM
how much's Avatar
Joined Jul 2011
Sidecar
not sure about the blue-wonder? anyone?
the prototype only weighed 10 ounce and is massively overpowered with the 1800kv that i used.. listen to the motor on the video, take off was at half power and full power was rarely used.
the limiting factor with scaling the wot-next up will be the integrity of the flat sheet wing... i would be getting nervous before i hit 40" span.
but use a "simple aerofoil" wing or a "kfm" wing (both detailed on the foam scratchbuilt thread) then you could build much bigger.
good luck with your ski plane wot-next... i like your thinking
David
Old Nov 02, 2011, 03:49 AM
Medicinal Foam User
Wilfor's Avatar
150 mile house B.C. Canada
Joined Jan 2010
At 10 oz the blue wonder should be a nice fit .depends on KV as to prop size .
Wilfor is online now Find More Posts by Wilfor
Old Nov 02, 2011, 06:19 AM
Canada, ON, Windsor
Joined Sep 2008
Thanks, guys. Onward and upward!!
Old Nov 02, 2011, 08:06 AM
Joined Oct 2006
David,
Looking forward to your 24" plans. We do not have an indoor flying site locally but perhaps on a calm day it would fly nicely out in my yard.
Cheers,
Don
Old Nov 02, 2011, 08:45 AM
VoyagerXll's Avatar
Bloomfield. Nebraska
Joined Jun 2009
I have used a 1300kv and 1750 kv blue wonder powered by a 2S 1000mah lipo turning a 9X5 prop. I have used those combinations of prop/ motor on a FFF piper that has an AUW of 12.8 oz. The motor gets only slightly warm if run full throttle for extended time when using the 1750 Kv motor So it is my opinion that the blue wonder would work well on this plane
Stan
VoyagerXll is offline Find More Posts by VoyagerXll
Old Nov 02, 2011, 12:36 PM
how much's Avatar
Joined Jul 2011
Stan
Stan
thanks.. the 10.1/2 oz weight i quoted for the prototype wot next was with the motor and "full size" 30a esc fitted in fact it was the weight ready to fly without lipo
David
Old Nov 03, 2011, 06:11 AM
Canada, ON, Windsor
Joined Sep 2008
Well, as my first aileron trainer, I've decided to go with a blue wonder motor and 6mm EPP (figure it'd bounce a bit instead of breaking).Got the wing and elevator done last night, re-inforced with carbon. Seems stiff enough. Does anyone have a link for instructions to help someone transition from RET to ailerons? I figure it'd be an advantage to read about it before I try to fly one. Thanks again.
Old Nov 03, 2011, 10:56 AM
who put that tree there
dazza44's Avatar
Joined Jun 2010
took my taube wot next out other day for test flight wow flew very well..
put an emax 2228 motor and 8x4 apc 1500 3 cell lipo .. 618g thrust plenty of power to spare,pushed most electrics in front as to fit my battery under the wing..final flying wieght was 13.75 oz..
just needing a paint job now,mmmmmmm red n yellow sounds good..
great design and thanks for sharing..
daren
edit...finished paint job opted for red n white looks better
dazza44 is offline Find More Posts by dazza44
Old Nov 03, 2011, 07:27 PM
USA, CA, San Diego
Joined Apr 2006
Hello HOW MUCH,
jellwalt is offline Find More Posts by jellwalt
Old Nov 03, 2011, 07:35 PM
USA, CA, San Diego
Joined Apr 2006
Hello HOW MUCH
Love your design of the WOT NEXT foamy and the elaborate plans you offered to us foam guys. One question that bothers me is the call out for the cutting layout of the top and bottom pieces...i.e. "26" x 2.9/16". Do you mean it should be 2,9 inches wide? What does the "/16" add-on mean?
Thank you for a truly cool design!!
Walt Jellison
jellwalt@cox.net
Wanted Wot Trainer St3v3 Aircraft - Fuel - Airplanes (FS/W) 0 Sep 29, 2011 08:06 AM
Discussion Trainer with aileron depron plan please... luconedj Beginner Training Area (Aircraft-Electric) 1 Apr 27, 2010 02:47 PM
Discussion Next model after aileron trainer? norite Beginner Training Area (Aircraft-Electric) 10 Jun 28, 2006 02:53 PM
Help! Next plane?....Need aileron trainer--- TurkeyTx Parkflyers 8 Feb 15, 2006 10:40 PM
Dandy Sport - aileron Trainer CoClimber Parkflyers 143 Apr 16, 2003 07:34 PM
