Old Nov 15, 2012, 10:08 AM
Mashworth is offline
Find More Posts by Mashworth
Masher
United Kingdom, England, Herefordshire
Joined Oct 2012
I second that - got 4 sheets of 6mm waiting!
I think the other good thing about 48" for training is that it gets you used to the increased adrenaline - that was my experience anyway - the bigger they are the more scared I am!
Got through 3 more batteries worth this afternoon , freezing cold though
Martin
Mashworth is offline Find More Posts by Mashworth
Old Nov 15, 2012, 10:32 AM
headlessagain is offline
Find More Posts by headlessagain
Reap the wild wind
headlessagain's Avatar
Bristol,UK
Joined Feb 2007
My experience is that bigger models are easier to fly as they are not as twitchy, have a lower wing loading and are easier to see. You can still use your smaller packs by using a lead to connect two lipo's in parallel. Make your own up or buy from here http://www.giantshark.co.uk/parallel...-p-406366.html
My order includes some of the grey 6mm sheets that are longer at 1250mm which is 49.2125984 inches so it's game on for a 48" model.
Andy
headlessagain is offline Find More Posts by headlessagain
Old Nov 15, 2012, 11:30 AM
Masher
Joined Oct 2012
Yes I'm sure you are right, it's just that physiological thing I think. Perhaps it's just that I link size with !!!!
Old Nov 15, 2012, 01:37 PM
how much is offline
Find More Posts by how much
how much's Avatar
United Kingdom, England, Wigan
Joined Jul 2011
Martin
you have a point!
at least when you fly your "wot next" you think...
5 for a sheet of depron..... no big deal
David
how much is offline Find More Posts by how much
Old Nov 15, 2012, 01:50 PM
Reap the wild wind
Bristol,UK
Joined Feb 2007
There is a downside with larger model. They are heavier so don't tend to survive unexpected and sudden contact with terra firma (or should that be terror firma?) as well as smaller stuff.
Old Nov 15, 2012, 02:20 PM
how much is offline
how much's Avatar
Joined Jul 2011
big ones fly way better
my biggest "own design scratch built" to date.... 21 feet (6.5 metre) span scale twin with 2 x Zenoah 62's
oh! and never forget.....
gravity is a cruel master
David
Old Nov 15, 2012, 02:51 PM
Reap the wild wind
Bristol,UK
Joined Feb 2007
If gravity doesn't get you, the magnetic trees will
Old Nov 15, 2012, 03:00 PM
dazza44 is offline
Find More Posts by dazza44
who put that tree there
dazza44's Avatar
Joined Jun 2010
hahaha magnetic trees
dazza44 is offline Find More Posts by dazza44
Old Nov 19, 2012, 06:25 AM
insomaniac45 is offline
Find More Posts by insomaniac45
Not always grumpy!!
insomaniac45's Avatar
UK, Eastleigh, Eastleigh
Joined Jul 2010
hey guys, ive had a few more flights out of my wot next, and although im highly impressed by just how docile she is, i feel ive done something wrong.
all my rates are set to low,
my problem is that she climbs under power, and i have to apply alot of down elevator to compensate this climb, if i back the power off, so she can cruise at a steady pace, then she will fly nice and level.
my motor is set with no off set what so ever, but i did modify the design to give me a kfm2 wing,
should i just scrap that wing and build as per plan, the flat wing? (i built the kfm wing as i hav had great experience with them in the past with my BB, and i didnt have much in the way of being able to re-enforce the wing)
thanks
my setup atm =
1300mah 2s turingy lipos
1100kv supomodel bell type brushless
gws 0947 slo fly prop
insomaniac45 is offline Find More Posts by insomaniac45
Old Nov 19, 2012, 07:24 AM
how much is offline
how much's Avatar
Joined Jul 2011
Insomniac
the wot next is actually better built with its flat plank wing... the stiffer you make the wing the less docile it becomes..
the "constant climbing" is simply a result of the extra lift generated by the kfm section wing.
no need to build a new wing.... just add a couple of washers between the top two motor mounts and the bulkhead to give around 2degrees of down thrust to the motor and that should counter the extra lift
David
Old Nov 19, 2012, 09:19 AM
davidterrell80 is offline
Find More Posts by davidterrell80
AMA 986339 FCC KB5LAM/4
davidterrell80's Avatar
United States, VA, Round Hill
Joined Apr 2012
"Magnetic trees" ... brings back the maiden flight of my "Cartoon C-119"
short video...
C 119 Maiden Flight (0 min 57 sec)
davidterrell80 is offline Find More Posts by davidterrell80
Latest blog entry: Ace Wing Cores
Old Nov 19, 2012, 12:12 PM
Not always grumpy!!
Joined Jul 2010
lol at the magnetic trees
you should fly by me, i had a close encouter with a tree the other day, and all it did was spit my plane out...... i dont think they like the taste of foam round here
@ how much.. thanks for that fella, will give it a good go, and see how she goes. i thought it might just be a case of adding a couple of deg offset onto it.
my wing is increadibly rigid, thanks to the kfm construction and the re-enforcement i found from a cheap kite.
its only docile as she has very little in the way of throws.
once i have her flying as per description, and i have gotten a few hours under my belt, i will increase the throws to liven her up a little and take her off the leash
Old Nov 19, 2012, 05:27 PM
potshot is offline
Find More Posts by potshot
Vertical approach specialist
potshot's Avatar
Northeastern Illinois
Joined Mar 2009
I've proved hundreds of times that magnetic trees exist - with golf balls.
potshot is offline Find More Posts by potshot
Old Nov 20, 2012, 01:17 AM
Gently is offline
Find More Posts by Gently
Nederland, NB, Eindhoven
Joined Dec 2011
Yep, this is the result of my friend when he starts with flying....
Gently is offline Find More Posts by Gently
Old Nov 20, 2012, 04:01 AM
Not always grumpy!!
Joined Jul 2010
maybe you should tell him, learning to fly an rc plane is more mountaineering than piloting...
Wanted Wot Trainer St3v3 Aircraft - Fuel - Airplanes (FS/W) 0 Sep 29, 2011 08:06 AM
Discussion Trainer with aileron depron plan please... luconedj Beginner Training Area (Aircraft-Electric) 1 Apr 27, 2010 02:47 PM
Discussion Next model after aileron trainer? norite Beginner Training Area (Aircraft-Electric) 10 Jun 28, 2006 02:53 PM
Help! Next plane?....Need aileron trainer--- TurkeyTx Parkflyers 8 Feb 15, 2006 10:40 PM
Dandy Sport - aileron Trainer CoClimber Parkflyers 143 Apr 16, 2003 07:34 PM
