Joined Apr 2010
Can anyone clarify if the 6mm dowel rod for the leading edges and etc is balsa ?
I just attached a spruce dowel to my leading edge , then realized that that might be an issue . First build ever for me .. so far i am having fun .. its taking me way longer then i would have thought lol thanks |
![]() oh.. standard time for building a wot next ready to fly is....... build it on saturday... fly it on sunday morning! David |
Joined Feb 2012
Prop Size
Hi
I am new to electric power flight. Fly gliders normally but was looking for an electric plane to build and have started constructing this model. What size prop would you recommend for model with a 2200kv brushless motor with 1000mah 3cell lipo. Regards |
A 6X4 prop is standard for a 2200kv motor but your motor is better suited to a parkjet
You should be looking for something in the 1200-1500 kv size so you can run a larger prop. Have a look here for newbies guide to RC electric power systems http://giantcod.co.uk/forum/viewtopic.php?f=15&t=267 Part 1 http://giantcod.co.uk/forum/viewtopic.php?f=15&t=268 Part 2 I use this motor in my Ugly Stick http://www.giantcod.co.uk/cf2215-120...-p-403800.html. Cheap, durable and powerful. Andy |
welcome to the wot-next club! your choice of motor is a bit over the top but it will work just fine.. the originals are way overpowered with the 1800kv i fitted and i rarely use full power.. they take off quite easily at just over half power so yours will be overpowered too... it should not be a problem! i use 8 x 3.8" slo fly prop on mine with a 30 amp esc you could try that as a starting point i use a 7 x 6 e on the same motor in my sea dart.. (and it howls like a banshea) so they will run a range of props i would recommend you use a soft prop mount/ shaft saver to mount your prop to the motor as this will save a lot of damage on landing. any questions? feel free to ask David |
Sorry to disagree with you David especially as this is your thread but I think that even a 7x4 prop would be too much for a 2200 kv motor unless it's a monster like my 120 gram NTM Prop Drive Series 35-36A 1800Kv motor that is rated at 65 amp max!
Here is Dr Kiwi's thread on a 2200 kv motor http://www.rcgroups.com/forums/showthread.php?t=1506550 and he agrees that a 6x4 is about the max. An 1800 kv motor would run something like a 7x4 or maybe a 7x5 with throttle management. It all depends on the esc & lipo capabilities. Andy |
Staffs, UK
Joined Nov 2003
Steve |
Joined Feb 2012
Hi Guys
Thank you for your responses. Sorry I made a mistake with my motor size it is a 1200kv ordered from this site : http://www.giantcod.co.uk/epower-221...tor-p-289.html Do you think the Propeller: 9x4.7(slow) would be OK for this model? Regards Terry |
sorry but i just assumed tk03 he had bought the same case size/power output as the 1800s i had used in the prototype wot next and that would be ok on an 8 x 3.8 i actually use 8 x 3.8's on a couple of my smaller case size 2200kv motors in my foam shockies... albeit on 2s thats the problem with generalisations eh! with the 1200kv he has bought.... not much in it between an 8 or a 9 x 3.8sf.. 50g of thrust for an extra amp of draw what size of esc have you bought? |
Hey guys, I am thinking of building this with Dollar Tree foam board (paper removed). I have some turnigy motors in 1500kv and 1700kv on (8x4 for 3s and 9x5 for 2s). Would this power be adequate? My wing span would be 30" due to the max width of DT foam. What type of Kfm wing would you reccomend? I was thinking Kfm2 or 4. Would I be better off folding it over and doing a traditional airfoil?
I'm looking for stable and easy to fly. This will be a trainer for my Dad who has been "hit" and "miss" on some of my other planes.
8x6apc prop 118 watts at 11.5 amps. 1500 3 cell lipo. flies like a rocket, so wouldnt be no prob on the wot next
| Thread Tools | |
| Wanted Wot Trainer | St3v3 | Aircraft - Fuel - Airplanes (FS/W) | 0 | Sep 29, 2011 08:06 AM |
| Discussion Trainer with aileron depron plan please... | luconedj | Beginner Training Area (Aircraft-Electric) | 1 | Apr 27, 2010 02:47 PM |
| Discussion Next model after aileron trainer? | norite | Beginner Training Area (Aircraft-Electric) | 10 | Jun 28, 2006 02:53 PM |
| Help! Next plane?....Need aileron trainer--- | TurkeyTx | Parkflyers | 8 | Feb 15, 2006 10:40 PM |
| Dandy Sport - aileron Trainer | CoClimber | Parkflyers | 143 | Apr 16, 2003 07:34 PM |
