Old Nov 30, 2011, 02:43 PM
how much is offline
Find More Posts by how much
how much's Avatar
United Kingdom, England, Wigan
Joined Jul 2011
Stan
hooooge congrats on the Rolls.... thats what it is all about fella..
just point the nose up, kill the rates, open the taps and roll to infinity
am running 8x3.8 sf on 1800kv motor on 3 cells 1000ma..
it never ever sounds like it is strained or over loaded!
spends most of the flight at less than half throttle! (except for big climb outs as above)
try a smaller prop on 3 cells... it sort of sounds wrong.. but really works well
d
how much is offline Find More Posts by how much
Old Dec 01, 2011, 08:25 AM
dazza44 is offline
Find More Posts by dazza44
who put that tree there
dazza44's Avatar
Joined Jun 2010
stan im using same motor as you on apc 8x4
runs very well 618grams thrust im getting.
daren
dazza44 is offline Find More Posts by dazza44
Old Dec 06, 2011, 11:55 PM
VoyagerXll is offline
Find More Posts by VoyagerXll
VoyagerXll's Avatar
Bloomfield. Nebraska
Joined Jun 2009
daren
I have some 8X4 props that I will try; They are a lot more rigid than the ones I am using. I am guessing they will not deform with higher revs like the orange 9X5 i am using. We got snow here in central US and was -11 F or -23 C this morning so the weather has to improve before I fly again
BRRRRRRRRRRRRRR is cold
Stan
VoyagerXll is offline Find More Posts by VoyagerXll
Old Dec 07, 2011, 11:06 AM
domll is offline
Find More Posts by domll
domll's Avatar
Norwich.uk.
Joined Oct 2007
finally got my camera back, few pictures below, changed the colour scheme, do you recognise it??. Small addition was to add a 2" piece of depron at the LE and TE allowing me to locate the wing correctly every time. Thinking of adding UC. Not had time to fly and with the winds currently as they are be a while longer.
domll is offline Find More Posts by domll
Old Dec 07, 2011, 11:37 AM
how much is offline
how much's Avatar
Joined Jul 2011
Domll
that looks excellent... a quality build my friend looks a million dollars (cost about 50)
bet you are itching to go and fly it the weather has been and still is really awfull here in North West England, we are just above freezing with gales blowing day and night for over a week now with no sign of any let-up
i got a new sea-dart built and ready for test flying... come on weather!
David
oh nearly forgot... the location blocks you put on your wing could damage the fuselage if you catch the wingtip when landing
Old Dec 07, 2011, 12:19 PM
headlessagain is offline
Find More Posts by headlessagain
Reap the wild wind
headlessagain's Avatar
Bristol,UK
Joined Feb 2007
How about reducing the blocks to just 6x6mm strips which would be dislodged/broken in the event of a less than perfect landing?
Very neat build Domll
Andy
headlessagain is offline Find More Posts by headlessagain
Old Dec 07, 2011, 12:27 PM
domll is offline
domll's Avatar
Norwich.uk.
Joined Oct 2007
How much, didn't think of that..would be gutted. good idea headlessagain, will do that tonight so as not to for get.
yeh, winds not letting up yet although not as bad as your getting it, turned all southern and can't handle the cold so much now... got to be something to do with working in an office all day.
Old Dec 11, 2011, 06:16 AM
charlie01 is offline
Find More Posts by charlie01
Joined Nov 2011
Three-View Plans for WOT NEXT's 34" Plane
Hi All,
Is there a three view sketch to see what this bird looks like in 3-view please?
Thank you
charlie01 is offline Find More Posts by charlie01
Old Dec 11, 2011, 10:44 AM
Fly Boy3 is offline
Find More Posts by Fly Boy3
United Kingdom, Wales
Joined Jul 2009
Great log and build sequenceH.M..What sort of flight times should one expect. I am very conservative, so not a lot of aeros/ LoL.. Cheers
Fly Boy3 is offline Find More Posts by Fly Boy3
Old Dec 11, 2011, 01:17 PM
how much is offline
how much's Avatar
Joined Jul 2011
hi
i use 3 cell 25-30c 1000ma packs and get 10 minute flights depending on the use of the throttle.... you can fly it fast or slow and it is fun at any speed
David
Old Dec 13, 2011, 02:58 AM
flyonly is offline
Find More Posts by flyonly
Joined May 2010
Depron vs EPP
I am stuggling to find some Depron here in New Zealand. Can someone tell me if EPP would work ok?
flyonly is offline Find More Posts by flyonly
Old Dec 13, 2011, 03:25 AM
Reap the wild wind
Bristol,UK
Joined Feb 2007
I would think that EPP would work. Leadfeathers' Quick Stick is EPP http://www.rcgroups.com/forums/showt...=1215705&pp=50 and some have built with a KFm wing. You just might need to beef up the spar as EPP if not as rigid as depron
Andy
Old Dec 13, 2011, 04:12 AM
dazza44 is offline
dazza44's Avatar
Joined Jun 2010
epp works fine mine is built from it..
Old Dec 16, 2011, 07:06 PM
VoyagerXll's Avatar
Joined Jun 2009
It has been to cold here to do much flying so decided it was time to build another "Wot Next" I am building this one by using your plans only I scaled the plans down for a 20 in WS . I should get it done in a couple of days. I will post pictures when that happens.
Stan
Old Dec 17, 2011, 12:54 AM
how much is offline
how much's Avatar
Joined Jul 2011
Stan
looking forward to it Stan..
am working away again so not getting any building/flying done. its cold here too and we have just had our first snow. i might put a set of simple floats on the original prototype and try it off snow
David
Wanted Wot Trainer St3v3 Aircraft - Fuel - Airplanes (FS/W) 0 Sep 29, 2011 08:06 AM
Discussion Trainer with aileron depron plan please... luconedj Beginner Training Area (Aircraft-Electric) 1 Apr 27, 2010 02:47 PM
Discussion Next model after aileron trainer? norite Beginner Training Area (Aircraft-Electric) 10 Jun 28, 2006 02:53 PM
Help! Next plane?....Need aileron trainer--- TurkeyTx Parkflyers 8 Feb 15, 2006 10:40 PM
Dandy Sport - aileron Trainer CoClimber Parkflyers 143 Apr 16, 2003 07:34 PM
