Old Feb 02, 2012, 04:38 PM
jarod120 is offline
Find More Posts by jarod120
Gets shakes if no FPV in 24hrs
jarod120's Avatar
Joined Dec 2011
Here is the latest Zephyr II to enter the fleet . I had goofed up the motor mount and built the wing upside down. I flipped the mount and finished the build properly. I'm running it with:
Dragon Link
1.2Ghz 300mw vtx
HS 645MG
ET OSD Pro Setup
GoPro Hero2
480 line CCD camera
Stock 1300kv motor and ESC
Graupner 8x6 folding prop
x2 11.1v 2250mah lipos
I vented the ESC cover. It should be enough to make a difference? I used motor magnets to button up the hatches. Everything turned out great! I can't wait to fly her, or enter her into a beauty contest
jarod120 is offline Find More Posts by jarod120
Old Feb 03, 2012, 10:29 AM
htran is offline
Find More Posts by htran
Joined Jan 2011
I disagree with 4 points.
1. SW is unstable at high speed (100km/hr+)
2. ZII is only difficult to launch if your CoG, throws and trim haven't been dial in correctly yet. It took 7 failed launches before mine were set, and now it launches with a gentle throw.
3. ZII stall speed whilst higher than SW, it is actually quite low.
4. SW tips stalls very easily when throws are too much.
Originally Posted by MK3 View Post
These are two VERY different planes. I have both. From what you're saying, it sounds like the skywalker is better suited for you.
Skywalker: Stable flying, slow or fast, low stall speed, ability to sight see with a pan/tilt camera, very long range and endurance, easy to launch, self corrects, will not do stunts unless highly reinforced
Zephyr II: Extremely fast, extreme maneuverability, high stall speed, does not self correct, long range, high altitude, wind resistant, difficult to launch, fixed cam view
IMHO
htran is offline Find More Posts by htran
Old Feb 03, 2012, 11:42 AM
MK3 is offline
MK3
Find More Posts by MK3
MK3
Aerial Loitering
MK3's Avatar
Joined Sep 2011
I never contradicted your points...
But for the sake of debate, yes on #2 but you can't deny it's still much more difficult to launch than SW
#3 I agree but it's still higher, that was my point
#4 ZII flat spins if flown incorrectly at low speeds
MK3 is offline Find More Posts by MK3
Old Feb 03, 2012, 08:51 PM
brosius85 is offline
Find More Posts by brosius85
never mind the boll⁣⁣⁣ocks
brosius85's Avatar
Australia, NSW
Joined Dec 2010
a flat spin with a ZII !!!??? now that i would love to see
brosius85 is offline Find More Posts by brosius85
Old Feb 04, 2012, 02:11 AM
citi is offline
Find More Posts by citi
Joined Apr 2008
So about point 2 what is your advice (setup) to succed the first or two time launches ?
citi is offline Find More Posts by citi
Old Feb 04, 2012, 06:06 AM
Ho-Jazz is offline
Find More Posts by Ho-Jazz
Taking care of business
Ho-Jazz's Avatar
United States, GA, Buford
Joined Nov 2009
^^^...COG at 9 3/8". Trim elevons flush with top of wing, then a few clicks up trim. 5 flights so far on mine, and it only has touched the ground when I land. Great lil wing!
Ho-Jazz is offline Find More Posts by Ho-Jazz
Old Feb 04, 2012, 06:30 AM
freshmint is offline
Find More Posts by freshmint
Joined Nov 2011
Isn't it suppose to be flush with the bottom?
freshmint is offline Find More Posts by freshmint
Old Feb 04, 2012, 11:34 AM
Ho-Jazz is offline
Ho-Jazz's Avatar
Joined Nov 2009
I believe it's the top. For what it's worth, that's how I did mine and it's flying great. I think I saw CK post up the same info somewhere.
Old Feb 04, 2012, 12:16 PM
pk surfing is offline
Find More Posts by pk surfing
United Kingdom, England, Darlington
Joined Feb 2011
Freshmint,
From the boss man himself, the maker of all things Zephyrish....
http://www.rcgroups.com/forums/showp...postcount=1086
Hope this helps...
PK
pk surfing is offline Find More Posts by pk surfing
Old Feb 05, 2012, 07:38 AM
htran is offline
Joined Jan 2011
No it's not, that's why I had the 6 crashes on launch.
According the Chris (who designed the wing), it should be flush with the TOP not he bottom, with a few clicks of up trim.
Old Feb 05, 2012, 07:42 AM
htran is offline
Joined Jan 2011
How is this for an effortless launch, no running start, no gold medal throw, just a gentle throw. No wobbling, no stall, smooth smooth smooth
http://vimeo.com/35242772
http://vimeo.com/35426882
Old Feb 06, 2012, 12:30 AM
dr_patso is online now
Find More Posts by dr_patso
N00b
Boise
Joined Mar 2009
I had my maiden flight today, and 2 more after that!
Ritewing Maiden (0 min 46 sec)
Ugh, I feel so dumb.. video makes me laugh though... picked a classic inspirational tune when nothing at all happens... I wonder why it kept going left. I was balancing it on my finger and CG felt perfect both straight and laterally...
EDIT: or my brother and friend just need a little more throwing practice?
dr_patso is online now Find More Posts by dr_patso
Old Feb 06, 2012, 02:35 AM
Locko is offline
Find More Posts by Locko
Locko's Avatar
Australia, WA
Joined Oct 2011
http://vimeo.com/36262921
Should look at early posts how to launch. Its a very easy one man launching Wing.
Locko is offline Find More Posts by Locko
Old Feb 06, 2012, 02:40 AM
N00b
Boise
Joined Mar 2009
i've seen all those. launching over the head seemed way too hard to actually launch it at the right angle for a first timer. I didn't think about this but i guess the plane would be easier to hold while it's going full throttle getting ready to be hurled over your head...
Old Feb 06, 2012, 02:43 AM
Locko is offline
Locko's Avatar
Australia, WA
Joined Oct 2011
I did the way in the video below, which most people who fly Z1 and z2 launch there wings.
It seem hard , but its not. I did it on my first wing launch. Easy as bro.
launching a zephyr (0 min 47 sec)
Build Log Building the ultimate Ritewing Zephyr ThomasWF FPV Talk 34 Feb 20, 2012 05:14 PM
Discussion wing thickness ritewing zephyr Herishi The Builders Workshop 2 Oct 05, 2011 08:36 AM
Discussion Ritewing Zephyr hobbycity motor nexstarselect FPV Talk 2 Mar 07, 2011 04:37 PM
