Old Feb 03, 2013, 02:06 PM
pablojaime is online now
Find More Posts by pablojaime
pablojaime's Avatar
Israel, Ashdod
Joined Dec 2009
Originally Posted by DoctorAudio View Post
Don't forget the ferrite cores.
More than 12" long I use two!
Ferrite on the servo wires? I hear that twisted wires do the trick for servos.
http://www.hobbyking.com/hobbyking/s...8-31DCA0EB5601
Pablo.
pablojaime is online now Find More Posts by pablojaime
Old Feb 04, 2013, 08:14 AM
DoctorAudio is offline
Find More Posts by DoctorAudio
Some call me the other guy!
DoctorAudio's Avatar
Milwaukie , Oregon
Joined Feb 2003
Ferrite do a great job at reducing the noise on the line.
Twisted wires is a way to filter out noise between to devices.
DoctorAudio is offline Find More Posts by DoctorAudio
Old Feb 04, 2013, 08:23 AM
Kloner is offline
Find More Posts by Kloner
Aerial DP
United States, CA, Lakeside
Joined Apr 2010
We had been working outside, was flying the zii over the hanger, but the stupid wind was howling, it was making unusable footage. The ss invited us in and threw my multi rotor at it......
Kloner is offline Find More Posts by Kloner
Old Feb 04, 2013, 01:48 PM
brucey is offline
Find More Posts by brucey
brucey's Avatar
Joined Apr 2011
Cool!
brucey is offline Find More Posts by brucey
Old Feb 04, 2013, 02:43 PM
Kloner is offline
Aerial DP
Joined Apr 2010
the day before that my friend was being interviewed for the superman viral video by Inside Edition..... i raided the place and setup RITEWING lettered planes all over the place. It had to be on some part of it........ Took the producers on a FPV ride with the zxl nex5 rig..... chicks always giggle, it's hot
Old Feb 04, 2013, 03:10 PM
Kloner is offline
Aerial DP
Joined Apr 2010
Old Feb 04, 2013, 03:41 PM
ROCKY2 is offline
Find More Posts by ROCKY2
TREES!!! Ouch!!!
ROCKY2's Avatar
Mexico, BC
Joined Jun 2009
ZXR First FPV Flight (3 min 55 sec)
ROCKY2 is offline Find More Posts by ROCKY2
Old Feb 04, 2013, 04:46 PM
klique is offline
Find More Posts by klique
Mum is the word!
Joined Jun 2003
That Damn thing is so unstable Rocky!!
Originally Posted by ROCKY2 View Post
klique is offline Find More Posts by klique
Old Feb 04, 2013, 04:55 PM
ROCKY2 is offline
TREES!!! Ouch!!!
ROCKY2's Avatar
Mexico, BC
Joined Jun 2009
i know man i have tried everything
Old Feb 04, 2013, 06:21 PM
bakon is offline
Find More Posts by bakon
I Toast Planes
bakon's Avatar
Joined Jul 2010
Originally Posted by pablojaime View Post
I must say it's not "my" idea , but it's 1.5mm or 2mm copper wire. the wire don't need to be too much rigid, important is the heat that the soldering can produce, if you have good heat, the copper will cut the foam like butter.. and the copper wire will not bend during work.
Pablo.
Awesome! I cant wait to give that a try. Here I have been hacking away at the foam with a razor like a neanderthal.
bakon is offline Find More Posts by bakon
Old Feb 04, 2013, 06:33 PM
bakon is offline
I Toast Planes
bakon's Avatar
Joined Jul 2010
Where do you guys suggest I put my batteries? As it is right now my Z is nose heavy and thats without my go pro and FPV camera. My current setup is in the photo.
Old Feb 04, 2013, 09:19 PM
NutBag is online now
Find More Posts by NutBag
NutBag's Avatar
Australia, QLD, Brisbane
Joined Oct 2005
My suggestions.... Build a lite ply battery box and run 2x 3000-3300s. Without a battery box the Z isn't going to last very long without getting battered and soft.
Have you covered the whole wing in lam under the black film? The weight of lam generally moves cg back.
No lam = crap Zed.
NutBag is online now Find More Posts by NutBag
Old Feb 04, 2013, 10:28 PM
bakon is offline
I Toast Planes
bakon's Avatar
Joined Jul 2010
No lam = crap Zed.
I've been meaning to build one of those boxes but I am trying to figure out where I would put it. And yes theres lam under the black film. But still if I put the box where the batteries are now I still should come out nose heavy. I dont think there is any way to slide them back any more then where they are now. Do people move them into the wings instead of the bay?
Old Feb 05, 2013, 12:03 AM
elliott000 is offline
Find More Posts by elliott000
Canada, BC, Vancouver
Joined Feb 2012
i think the extra 1400 mah is the problem. I have one of my z's with wing cut batts. I had it fully built and ready to fly and then laid the batteries on and cut right where they were perfect cg. Worked out great and it flies well. Havent crashed it yet tho lol. It has a plywood batt base aswell in the center where my rvosd is
elliott000 is offline Find More Posts by elliott000
Old Feb 05, 2013, 03:06 AM
NutBag's Avatar
Joined Oct 2005
You could build a box and cut/move it back into the rear bay some more.
The box will be stronger than the bit if foam currently there and support the wing halves very well if made correctly, just have to watch the thickness.
Leaves you less fpv gear room but that should be out in the wings for separation anyhow
Chris.
Build Log Building the ultimate Ritewing Zephyr ThomasWF FPV Talk 34 Feb 20, 2012 05:14 PM
Discussion wing thickness ritewing zephyr Herishi The Builders Workshop 2 Oct 05, 2011 08:36 AM
Discussion Ritewing Zephyr hobbycity motor nexstarselect FPV Talk 2 Mar 07, 2011 04:37 PM
